    You need to write
    @22:00
    with a colon.
    @22.00, is like 22s after midnight and will be scheduled first at 00:00, so that's why you don't see the timer
    Sorry Jan for not reading well.
    If I create an error I get the message setup error(s) - fix and restart.
    In my case it stops running after posting test10=true
    My rule test3 is't executed.
    This is different as the QA "crash" earlier this was solved by re-starting the QA
    Yes, it seems you have spelled 'ruel' instead of 'rule' for some rule definition in main.
    Jan I created the error to see what happends. THe QA stops instead of fix  and restrat.
    Does fix mean I need to correct the error and if done restart?
    Edited by Sjakie
    add fix
    Yes, if there is an error when setting up the rules it will exit the main() function and ask you to fix it.
    When you fix it and save, the QA restarts...
    If there is an error later when the rules are running, it should not stop.
    In the next version if a rule throws an error 3 times the rule will be disabled - and a message logged that the rule was disabled due to too many errors.
    Great service Jan, thanks!
    21 hours ago, ChristianSogaard said:
    Hei Jan
    I tried to create a pair of rules.
    I have other rules for open/close of windows, so the close windows rule are linked to this open rule.
    Is there a better way to do this? (delay before closing the windows). - im not happy for the wait 30 min command.
    Well, in ER5 you should be able to do this
    You do all actions in one rule.
    The .mode('killOthers') at the end makes the rule so that if the rule is invoked again it will kill all versions of the same rule that is "sleeping".
    So if you press it once it will close them to 50% and go into a 30min sleep.
    If you press again before the 30min the new instance of the rule will kill the first that is sleeping and set to 50% again (no problem if it's  already 50%, yes?) and then start a new fresh 30min wait.
    Was that what you wanted?
    Hi Jan
    yes, looks good, Ill test it right away :-)
    and setValue will be value, right
    And Thank You :)
    Edited by ChristianSogaard
    Typo
    Hi Jan
    I have migrated 75/180 rules from Ev4=>5.
    I really like the rule and timer overview, Thank you :-)
    Is this this the right way to declare variables in EV5
    Would it be possible to have an exclude function in Ev4, like instead of u_ ?
    when having a lot of rules with rule([[ ... i cant use use the --[[ ]]-- to mark out
    @jgabDoes it mean that event4 will not be updated in the future?
    Yes, I will fix serious bugs in ER4, but no new features.
    11 hours ago, ChristianSogaard said:
    Hi Jan
    Well, one way is to enable and disable rules with the functions er.enable() and er.disable()
    If you declare the rules in a table, like this
    you end up with a table of rules, as the rule(...) function returns the rule object.
    By default the rules are enabled, but you can use the function er.disable(ruleSet)
    to disable all the rule in the table directly after they are defined.
    The advantage with this is that you can use enable and disable from within rules so you could have another
    rule that says
    rule("@10:00 => enable(ruleSet); wait(03:00); disable(ruleSet)")
    in other words, enable the rules for a certain time during the day.
    I have used this to enable special Holliday rules in the past, lightning etc. (there is something similar for ER4)
    The other simple(r) approach is just the put the rules within an if-then-else
    in main where you load the modules you set up a table with the "rule sets" you want to enable/disable
    Then in the local main in the modules you have an extra parameter, config
    Hi Jan
    This makes
    'matrix_kitchen' a global Lua variable
    It's better to make it an ER variable (only visible within rules) by declaring it as
    This assumes that in the beginning of main there is a declaration like
    There is still
    er.defvars(HT)
    to declare whole "home tables" with ER variables...
    Jan what I am doing wrong?
    Edited by Sjakie
    You need to give me more info
    is a valid rule - what is the rest of the rule?
    2 hours ago, jgab said:
    This makes
    There is still
    er.defvars(HT)
    from main
    from rule, and using var.
    but i get this error, (line 63 is  var.HueLampID_1012 = 1012 -- Skrivebord L)
    it compiles with HueLampID_1012 = 1012 -- Skrivebord L
    2 minutes ago, ChristianSogaard said:
    from main
    Yes, in the example main(er) that I provide there is an argument 'er' that is a Lua table with some pre-defined Lua variables and functions.
    The function starts something like this
    Here we define a local function 'rule' that is the same as the function er.eval(...)
    This is the function we use to define rules.
    There is also a table, er.variables, that we define a local alias for named 'var'.
    If that is setup correctly we can do
    We could also use
    but that's too long to type... ;-)
    If you use your modules you need to set it up in each local main() that you have...
    and then use
    Hei Jan
    I have a usecase for Ev5 i want to hear you about.
    I using 25 pcs Matrix switches and each
    Switch have 4 LEDs
    Im using the LEDs for background light and indicating different statuses - and the goal here is to avoid the background light (runs 4 times a day) overwrite the special status.
    I will maintain a Central Matrix LED Database from Scene
    Identifying Matrix can be done like this - or just manual in the first version
    Store Matrix LED in database in Global Variable HTassets in JSON format.
    Fase One…
    Event runner 5 will be the brain to execute events.
    Usecase…
    When changing LED Color in a Logic Group Matrix button, when an external event like “Outdoor Light control goes from Automatic to Manually”, and this is indicated by a red Matrix LED.
    Problem…
    Other Scenes/QAs like Day Color (Running 4 times a day) theme can overwrite this color.
    Idea….
    When initiating EV5, it generates a working copy from Global Matrix HTassets (JSON)
    Matrix Switch the Day Color theme in the Matrix Led are addressed through the working copy.
        local HT = json.decode((fibaro.getGlobalVariable("HTassets")))
        Util.defvars(HT)
        Util.reverseMapDef(HT)
    The LED asset value is removed from the working copy when Special status is given.
    [rule("fibaro.utils.remove(1000,rooms.all)") -- remove 1000]
    When the Light status goes back from Manually to Automatic. The LED asset value is added back to the working copy.
    [rule("add(rooms.all,1000)") -- add 1000]
    How can I add the Day Color theme to the LED asset, that was just copied back?
    My idea is - From the ROOM / Variable (Blue Color) I have the actual Color, that can be re-used for setting the right color to the LED asset.
    Like
    Rule(”terasse.lille.lys:isOff >> terasse.lille.Tryk1:color={$varrooms}; terasse.lille.Automation=false”)
    -- Day Color theme example
    rule([[$DayControl=='sleep' =>
            $varbaths = colorvalue.Normal;
            $varrooms = {0,0,0,16};
            $varcommon = colorvalue.Low;
            rooms.baths:color=colorvalue.Normal;
            rooms.rooms:color={0,0,0,16};
            rooms.common:color=colorvalue.Low;
    Would they be a good way to do this, or what do you think about this?
    On 11/20/2023 at 8:44 PM, jgab said:
    In next version of ER5 there will be 2 variables defined
    'uptimeStr' that gives a string with uptime in days hour and minutes.
    Ex.
    and uptimeMinutes that return the number of uptime minutes as a number.
    So, a rule like
    should work...
    I tried on version 0.300 - and i get no trigger -uptimeMinutes
    Hi Jan
    How do i do Util.defTriggerVar - in ER5
