    You could do something like this
    When the variable 'contactSpec' is set to a value it overrides what DayControl is set to. When contectSpec is set to false or nil it will trigger the rules again but it will use the DayControl.
    post #alarmOn and #alarmOff to set the alarm colors and go back to the DayControl colors. etc.
    Thank You Jan - im not sure that this will work.
    eg. when the alarm LED are enabled, that would be Led 29,31,33,35,996,998,1000,1002 in rooms.common showing blink red..
    so 29,31,33,35,996,998,1000,1002 need to be immune for next DayControl change...
    Perhaps i should have a rooms.alarm, and Rooms CO2, and then move the 996,998,1000,1002 from rooms.common to rooms alarm when alarm is armed ?
    rooms = {
                    all         = {996,998,1000,1002,101,103,105,107,137,139,141,143,77,79,81,83,113,115,117,119,53,55,57,59,161,163,165,167,89,91,93,95,245,247,249,251,221,223,225,227,185,187,189,191,125,127,129,131,173,175,177,179,41,43,45,47,416,418,420,422,65,67,69,71,149,151,153,155,29,31,33,35},
                    rooms       = {101,103,105,107,89,91,93,95,125,127,129,131},
                    baths       = {161,163,165,167,185,187,189,191},
                    common      = {996,998,1000,1002,137,139,141,143,77,79,81,83,113,115,117,119,53,55,57,59,245,247,249,251,221,223,225,227,173,175,177,179,41,43,45,47,416,418,420,422,65,67,69,71,149,151,153,155,29,31,33,35},
    Edited by ChristianSogaard
    Typo
    On 12/26/2023 at 9:49 AM, jgab said:
    This will create a fibaro global GasCounter if it doesn't already exist.
    Every night at 23:59:55 it will record date, total consumption and daily consumption.
    The first day you run it, it will only get a total and not a daily.
    GasCounter will be a Lua list with
    { {date = <date>, total=<value>, daily=<value>}, {date = <date>, total=<value>, daily=<value>},...
    sorted so that the most recent date is first in the list.
    If the list exceeds 360 entries it starts to prune the oldest dates from the list.
    Hi Jan
    Just wondering. iRules has been running for two nights but GasCounter is still empty
    I dont have any logs, as they are overwritten
    8 minutes ago, ChristianSogaard said:
    Hi Jan
    Oops, this rule
    will set GasCounter to {} every time you restart ER... ;-)
    Well, just remove the rule...
    rooms = {
    Hei Jan
    (contactSpec | $DayControl) == 'Wake-up'
    This is an OR rule, right ? contactSpec OR $DayControl == Wake-up ?
    I understand the triggervar the .start() ect but not the When the variable 'contactSpec' is set to a value it overrides what DayControl is set to.
    if rule([[(contactSpec | $DayControl) run at 0800 because $DayContro is triggered and contactSpec = CO2 then both are true, right , but only equal to one thing ? - that will not be an overrride,
    Typo
    On 12/21/2023 at 1:43 PM, jgab said:
    @jgab Jan this throws me errors..i dont understand it
    [Rule:101:#ERerror{id='$id', msg='$msg'} => installerUser:msg = msg:gsub(' ',' '):g..] Runtime: table is 'string' for array reference
    #ERerror{id='$id', msg='$msg'} => installerUser:msg = msg:gsub(' ',' '):gsub('
    2 hours ago, Neo Andersson said:
    Sorry, bug. Pushed v0.95 with a fix.
    @jgab Jan is there a way to use variable defined in a rule as a LUA global variable?
    i have a variable installerUser that is both used in rules and in other functions. Should i create it twice?
    Lua global variables can be read from within rules but you can't assign them values from within rules.
    Jan, I had a typo
    ER5 disabled rule correctly?
    Quick App crashes
    Unknown Error
    I can't imagine it's ER5 should be Fibaro
    btw this QA crashes on a regulary base and according debug no further errors.
    Edited by Sjakie
    16 minutes ago, Sjakie said:
    Jan, I had a typo
    Quick App crashes
    Unknown Error
    'oonkamer' is nil. Should it be 'woonkamer' ?
    Yes I corrected the typo but this was to inform you QA crash after rule disabled.
    Ah, ok. It's ~1min30s afterwards so it may be a coincidence... I'm keeping my eyes open to see if it happens to me too but nothing yet. Are you running short of memory?
    At this moment not at all.
    usage 56% buffer 7% cache 27% free 10%
    it's higher as earlier  usage around 49%
    Jan how I can get in debug the value if it change 0.1 degree?
    Jan, can you check my QA1442? It's giving me now almost every time QA crash after saving, around 10 times this morning?
    Ok, PM me the QA
    @jgabHelloo Jan
    I am looking for some functions, abbreviations in ER5
    1.  getting gateway name (master)
    2. sending email / probably only to admin's email
    3. getting device parentID/parentName (if device has any)
    I have created custom functions for them, but if they are in ER5,i will use them rather,.
    On 12/28/2023 at 8:40 AM, ChristianSogaard said:
    Hei Jan
    Hi Jan - i tried trigger the rule to check the logs :-)
    Im getting
    Runtime: calling 'false' - wrong number of arguments to 'insert'
    [29.12.2023] [22:41:55] [TRACE] [ER2059]: [Rule:2:1]>> TRUE #daily{2} -> @22:41:55 => local gc = $GasCounte..
    [29.12.2023] [22:41:55] [ERROR] [ER2059]: [Rule:2:1]>> [Rule:2:@22:41:55 => local gc = $GasCounter; local today = {date=osdate("%Y-%m-%d"), total=GAS_ID:value}; table.insert(gc,1,today); if size(gc) > 1 then today[1].daily = today.total - gc[2].total end; if si..] Runtime: calling 'false' - wrong number of arguments to 'insert'
    Jan in General tab there is an option to export data.
    Can I activate it in ER5?
    If yes is it also possible that timestamp can be a date I can read?
