43 minutes ago, jgab said:
This rule
is missing commas after the R1 and R2 keys
I will try to implement a better error message instead of crashing...
thanks, here another error, and i have no clue where to search
Gettiing this error
Last err: Expr Runtime: attempt to get length of a number value putprop for k,v in pairs(RGBW_data) do k:color = v.$globalColorMode.color end ^
Gettiing this error
This rule is working at my house
    does not work.
    Maybe you mean
    1 minute ago, jgab said:
    does not work.
    Maybe you mean
    Think about $globalColorMode as fibaro.getGlobalVariable("globalColorMode")
    Then
    doesn't make sense, but
    does...
    2 minutes ago, jgab said:
    does not work.
    Maybe you mean
    v.$globalColorMode.color working at home without a problem, but okay i will try here at customers house to use the other one.
    I'm sure it doesn't - unless you have an old ER5 with bad error messages for that case...
    4 minutes ago, Neo Andersson said:
    I think it's complaining about
    What is k?
    TRy
    What is k?
    TRy
    Is white and red defined as tables with 3 values?
    ...and I can conform that v.$globalColorMode.color
    works... but it is unintended and I would not use that - it may change in the future when I make stricter error checks in the parser.
    this is the table that it is looping through
    So, k:color = <something that is not a table with 3 values>
    will create the error message "Expr Runtime: attempt to get length of a number value putprop"
    SO what is red and white defined as?
    next version throws an error
    "setColor expects a table with 3 values"
    if k:color = <something that is not a table with 3 values>
    @jgab I have a pack man in the system who is consuming memory.
    It's hard to detect what is the cause, perhaps as with earlier fw of Fibaro?
    I notice that if usage of memory is high I need another meter to get in before light switching on.
    To avoid later switching on our lights I want if possible:
    in ER5 a rule if free memory < 10% HC3 should restart.
    3 minutes ago, Neo Andersson said:
    Yes, but where do you define it? They need to be defined before you define RGBW_data.
    If you run this
    just before
    Do you get the color tables?
    If you run this
    just before
    Ahh okay, that was the bad order,,,Ohh kinda difficult to find errors foe me..maybe when i will have an up and running VD code for ER5 one day.
    Thanks so far
    What number are you looking at?
    Free memory is ~%100-%Used space. So you mean %Used space > 90 ?
    yes is okay >90%
    50 minutes ago, Sjakie said:
    yes is okay >90%
    Something like this? checks every 5min
    @jgab
    Jan wich alarm rule should work, because none of them seem to work for me
    Thanks Jan, HC3 does't restart at all.
    46 minutes ago, Neo Andersson said:
    @jgab
    UPDATE, okay found in the desciption
    Ok, that is a command that needs credentials - which makes sense.
