    42 minutes ago, Sjakie said:
    Jan, possible to create sort button name, room or number? Hide unmapped?
    I have 427 devices so to search is difficult.
    If for devices select light it was visible but later I need to change in light color to see it back
    Thanks in advance
    Sorting of columns is coming. So id, name, and type?
    Maybe search on name too.
    v0.1.24 is out and hopefully fixes the Windows folder/config bug
    [0.1.25] - 2025-10-31
    Added
    • Device Management Sorting: Added sortable columns in Device Management panel
      • Sort by Status, ID, Name, or Type
      • Click same column again to reverse sort direction
      • Visual indicator shows active sort column and direction
    Fixed
    • Fixed device editing error: loadDevices is not a function
      • Changed to correct method name loadWidgets()
      • Device editing and type changes now work properly
    • Fixed device deletion error: renderFloors is not a function
      • Changed to correct path floorManager.renderFloors()
      • Device deletion now works without errors
    • Fixed Windows template discovery
      • Added check for _up_ folder next to executable (Windows bundling pattern)
      • Windows version now correctly finds template on startup
    • Fixed Settings dialog crash when config not loaded
      • Added null-safe access to homemapConfig properties
      • Settings can now be opened even if initial config load fails
      • Prevents "cannot read property 'name' of undefined" error
    • Fixed "config file not found" error on Windows
      • App now creates minimal config.json if template isn't found
      • Gracefully handles missing template directory
      • Creates necessary directory structure (widgets, icons) automatically
    Jan, perhaps also show the present version?
    It's in the about menu option.
    Jan, when I need a same Floor plan on my wife's iPad:
    Is this the best way?:
    install same version on iPad as on my MacBook
    copy homemapdata complete from MacBook >>> iPad
    Yes, you can copy homemapdata folder, but you can't run on iPad, it's an MacOS application.
    In the future I may make an iPad version...
    Ok thanks.
    Shall inform here to be patience. 🥲
    Deatr @jgab
    I just upgrade to 0.1.27 and I lost my 4 floors, replaced by your 2 examples.
    My config.json is still there so does it means that the application is now pointing to another location for the configuation file?
    Using th cogwheel, the path is as set in .env
    Trying to add any floor, I got the following error when Add Floor is pressed
    /monthly_2025_11/image.png.f4c9993d61635bffe6b10ab0ca228405.png" />
    Another little issue: if you suppress all existing floors then I do not see any menu to add a floor.😒
    On 10/28/2025 at 10:22 PM, jgab said:
    The app automatically creates a configuration folder
    Where it is located? Are you still using a config.json file? (I hope, in order to patch my own data in it)
    That's a bug, will fix.
    It'a using the path in the settings (cogwheel) The HC3_HOMEMAP env is phased out.
    You can see the path there and you can set it to your old I guess - depending on how old your folder is it may not be backward compatible. I would recommend to start over.
    So the config.json file is in the homemapdata folder, but you should not edit it by hand anymore. Devices and floors are setup with the UI. Only reason to go into the folder is to add your own icon sets in icons/* or your home made widgets in widget/*
    Oh me bad!!
    I modifyed config.json because I had 2 devices deleted and still on the floor map.
    I had a copy in another map
    It was't possible to delete in the device manager, not showed.
    Edited by Sjakie
    copy
    I have de-installed and re-installed the application.
     config.json as well as the /icons, /widget and /images are in directory '/myName'.
    Now HomeMap is again loading my 4 floors and I have got back all devices which were created previous version.
    Those for which I used your default widget and icons are displayed correctly and working.
    All others for which I created a widget specific json files and relatives icons are there but without any icon and do not work ;
    When I edit them, I cannot find my specific widgets.
    Where I need to locate  json files and icons for this user's widgets?
    Edited by Christb
    So
    So there was an issue when saving the icon sets name with a device, so it didn't make a difference between built-in, packages, or user icon set, the the icon set name was the same.
    It's fixed in the last version.
    In settings there is a new button to backup the homedatamap folder (save it as a zip somewhere else)
    • Like 3
    Making progress, HomeMap starts up in the iPad simulator and basic connectivity and menus work:
    /monthly_2025_11/ipad_progress.png.dd916303a2a3167dda23114bdf57b00f.png" />
    Still some way to get the details in place
    • Like 4
    Magnificent!!!
    Update to version 0.1.28 and have now all my devices with the default widget/icon.
    I have not yet found a way to add my own widget, icons. Could you help me on how to add:
    type light:
    'lustre.json' with icon 'offlustre.svg' and 'onlustre'.svg
    /monthly_2025_11/image.png.aae95d22b0255bd8a31b7975d21ca01f.png" />  image.png.fe8526974482f61d589cd427484458ad.png
    BTW : is there a limitation in the size of icon for user's icons?
    So each of the built-in widgets, ex "light" requires icons with specific names.
    If you set your device to use the built-in widget light it will use the iconSet "lightdim" as default.
    That is an iconSet shared between "light" and "lightdim" widget.
    The iconSet contains
    .icons/built-in/lightdim/on.svg
    .icons/built-in/lightdim/off.svg
    .icons/built-in/lightdim/half.svg
    "light" uses the on.svg and off.svg to show the on and off status.
    "lightdim" also uses the half.svg to show when the light is dimmed.
    You can add your own iconSet for a on/off light by adding
    .icons/lustre/on.svg
    .icons/lustre/off.svg
    If your device is set to widget built-in "light" you can set the iconSet to your "lustre" iconSet.
    The widget will then look for the on.svg and off.svg icons in .icons/lustre/* for its state icons.
    If your lustre is dimmable, you can set the widget to built-in lightdim and the have a half.svg in your .icons/lustre/
    If you make your own widget json you can of course choose your own icon names for the states, but the general principle is the same.
    Jan your background shows me now some icons more.
    Is it posible to select diferentes back groud for a group? So it will read the pannel quickly.
    If you need an iPad tester we can do it.
