In this window
Jan, offcourse I use latest version.
When I open settings did't change anything >> safe it will give notification to change the path!
Than it will not open my own floorpan but the program likes your floorpan more than mine.
It seems that there is still an issue with path when saving settings after changing the background color:
After reload I have this messages:
/monthly_2025_11/image.png.0f9653346b03623900641b292f256989.png" />
Normal as I deleted your 2 default floors...
Also because the action to save settings changes the config.json to your default model, not keeping the one I had in /USERS/ASUS/homemapdata
Restauring from last backup, I got back my settings with the right config.json
In Windows , what is your defaul location for config.json?
Did you change its name to settings.json?
May I propose a little enhancement: Is it possible in Device Management View to have an additional button to limit or not device list to only "visible"=true?
