  2. Today
  3. I don't understand either, I didn't even suspect it at first. But when I reinstalled version 20.8, it worked again as before and everything is fine.
  4. Yesterday
  5. Don't understand that, the Geofence code is exactly the same.
  6. Hi! I restored version 20.8 and it is working properly again. I use an Iphone 12 ProMax and an Iphone 16. Both had the same problem.
  7. I have a basic beginner question and would appreciate if someone could confirm my understanding. As I understand it, there are currently at least two ways to integrate a Philips Hue LED light with Yubii Home Pro: Include the Hue light directly in Yubii Home Pro as a Zigbee device. In this case, only the basic functions are available. For example, I can switch the light on/off, dim it, and perhaps change colors, but I cannot access Hue-specific settings such as the power-on behavior (e.g., after a power outage, return to 25% brightness and blue color instead of 100% brightness and white). Use a Hue Bridge, include the Hue light in the Hue Bridge first, and then integrate the Hue Bridge with Yubii Home Pro. In this case, the full range of Hue functions and settings is available. At the moment, there is no way to access the full set of Hue functions by connecting the Hue light directly to Yubii Home Pro without a Hue Bridge. Have I understood this correctly? My particular requirement is to have the light return to a predefined favorite setting (for example, 25% brightness and blue color) after the power has been interrupted and restored. Thank you very much for your help.
  8. Last week
  9. I have no problems with geofencing with AOQ, using an iPhone 14 Pro.
  10. for now all you can do is: - send Fibaro coffee cup @m.roszak - switch back to ZW2 - change temporairy the way you using it, e.g. use the code still to unlock the panel, and then once unlocked two scenes to do something based on "user clicked on lock" and "user clicked on unlock". Lock key is 11, unlock is 12, e.g.
  11. Thank you for reporting this. We've forwarded your report to the appropriate department for review and analysis. If we need more information for analysis, we'll contact you via private message.
  12. The only reason would be that phones actually sends the events about arriving and leaving - and as we know, its a bit out of our hands - its based on the API of apple/google. I would try changing the radius definition of the point in location to something higher as a debug step.
  13. What version you've used before? If you rollback the previous version, is it works, OK? By the way I didn't change anything in the code. The geolocation trigger comes for mobile application, not generated by AOQ. In addition, I do have same issue. Interesting what Fibaro team has to say about it? @m.roszak any idea why it happens?
  14. Good Evening I am writing to report a critical bug affecting the FGS-213 Single Switch 2 after updating its firmware from version 3.3 to 3.4 on a Yubii Home Pro hub running firmware 5.210.12. Environment: - Hub: Yubii Home Pro, firmware 5.210.12 - Device: Fibaro Single Switch 2 (FGS-213), 3 units installed - Z-Wave Engine: 3.0 (ZW3) Steps to reproduce: 1. Perform firmware update 3.3 → 3.4 via Settings → Devices → Updates 2. Update completes successfully (status: "Fertiggestellt" / Completed) 3. Click "Reconfigure device" ("Gerät neu konfigurieren") as suggested by the UI Observed behaviour: - After reconfiguration, the device's Parameter Template is set to "No" (Parametervorlage: Nein) - The Parameters tab in the device view becomes inaccessible - Z-Wave Type drops from 3 to 0, SDK Version drops from 4.24 to 0.0 - Each additional "Read configuration" click further degrades the device profile - Endpoint XX.1 (Binary Switch, the actual switching channel with energy metering) is permanently deleted from Yubii — not hidden, but fully removed - Endpoint XX.0 remains and can switch the load, but has no energy metering capability - Energy reporting (Watt / kWh) is permanently lost until a full Exclude + Include cycle is performed Important note: The "Reconfigure device" button appears directly in the Updates view after the firmware flash completes, with no warning that it may destroy the device profile. This makes it a high-risk trap for end users. Additionally, I observed that on two of the three units, the firmware update did not complete at all (devices remain on version 3.3), despite the update process appearing to run. Requests: 1. Is this is a known bug and do you know if a fix is planned? 2. Anyone knows whether there is a recovery path short of a full Exclude + Include cycle? I am happy to provide log files, device IDs, or further technical details if helpful. Thank you for your help.
  15. sorry mate, i havent upgraded to zwave 3 engine just yet. looking @tinman post earlier looks like it doesnt work at the moment
  16. New version 5.0. Changed all the json names back because someone at Buienradar changed them AGAIN. Look for the first post to download and install or overwrite the code with the new code.
  17. Hello, do you have any idea, how to solve this problem without swiching back to zw2? I am able to arm house, but disarm without accessControlEvent doesnt work. It seems this keypad is cursed. In entry control mode is not possible call buttons, In access control mode is no longer possiible to call the scenarios.
  18. Seriously? Yep, Buienradar changed the json again, probably back to what it was. Looks like bullying the developer? Just disable the quickapp again, I will have to see what #@%^ they are doing.
  19. You can make a Lua script to modify the alarm panel configuration to use the API directly, no support for changing the configuration of the alarm zones via block scenes. Block scenes are more for control than configuration of specific aspects of the system.
  20. Hi @Willem-Jan , My understanding is that team already worked on that with you and there are some issues with reproducing on our side, without that finding a reason and ultimately fixing that is tricky. Seems like very individual case but we won't give up on that. We will still try to find a solution. At least for now, I suggest making a simple script that will reboot the hub if there is no connection with KNX IP bridge for 15 minutes (or something like that) - let me know if you need any help with that. PS If you will have the logs from this specific situation on new GA version please send them on PM, thanks!
  21. The API is live again, but Buienradar changed all the json data. So I changed all code to the changes Buienradar made to the json data. See the first post for the new quickapp file. You can install the new .fqa file or overwrite the code if you know what you are doing.
  22. Is it Possible to get a copy of your QA? Thanks
  23. Hallo. Wollte einmal nachfragen, ob hier noch jemand HC3/HC3L und Indevolt PV Anlage nutzt/hat? Ich habe mir zur Steuerung diverser Szenen und zur Übersicht im HC3 eine kleine QuickApp "gebastelt" die mir die wichtigsten Werte liefert (benutze 3 Indevolt SolidFlex2000) und kann jetzt somit über den Ladestand der Batterien meine Szenen steuern lassen. (z.B. wenn Akku SOC bei 75% darf Boiler heizen, unter 50% nicht). Ein Screenshoot ist angehängt wie die QA aussieht. Bei Interesse gerne melden. Hello. Does anyone here also use Fibaro HC3 and an Indevolt PV system? I'd be interested to know. Since I have three devices in my household and control various other devices with it, I've "built" a QuickApp that displays my systems on the HC3, including current values from the PV panels, battery levels with temperature and power output. This allows me to control a second, smaller QuickApp with a "switch" that allows devices to be switched on or off depending on the battery level.
  24. Is there any smart way to group all door/window opening sensors under the "ustawienia alarmowe"? Or does each sensor have to be configured individually? Unfortunately, using a device group is not possible as a condition for a scene, and in any case, the sensors are not grouped there in the way I would need. Is there perhaps another way to include all door/window sensors in the alarm configuration without having to add and configure each sensor separately? Or is manual configuration of every sensor currently the only option?
  25. Hi cag! I uploaded version 22 and since then the geolocation is not working properly. When I arrive home or any place, I first get a notification about arriving home, then leaving, and finally arriving home again, but sometimes, when I arrive home, I get a notification about arriving home and then leaving home. It's annoying because I use geolocation to arm and disarm the alarm system, and even if we're at home, the alarm is armed because of it. Do you have any idea what the problem could be? Thanks! [2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{265}T $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{260}A $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{257}T $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{266}A $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{264}A $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{263}T $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{258}T $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{259}A $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila leaves Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}A $geoAction[enter] ➯ skip turnOff{leaveHome} if not {leaveHome(false)=true}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}A $geoAction[enter] ↪ skip turnOff{everybodyLeaveHome} if not {everybodyLeaveHome(false)=true}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{265}A $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{257}A $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{263}A $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{258}A $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966} 152
  26. Thank you very much. I knew that it's possible!
  27. api.post("/plugins/updateView", { deviceId = <id>, componentName = <elm>, propertyName = <prop>, newValue = <value> }) So, you must know the component name.
  28. Good morning, as we know access to other quickapp function is easy: fibaro.call(id, name, parameters). I would like to ask the following: is it possible to access (write to) other's quickapp UI field similar way? Alter other quickapp UI field remotely?
  29. Earlier
  30. Thanks for the update. This info slipped my mind as 3.0 upgrade was not really an option till now. Very good news, anyhow.
