Netatmo Indoor Air Quality Monitor QA 2.0
   (0 reviews)
Netatmo Indoor Air Quality Monitor QA standalone v2.0
INTRODUCTION
Netatmo Indoor Air Quality Monitor QA brings complete integration of Netatmo Indoor Air Quality Monitor (coach) to HC3, HC3Lite and Yubii Home users with support for more than one monitor.
PREREQUISITES
  • Fibaro HC3, HC3Lite or Yubii Home with firmware 5.150 or greater
  • One or more Netatmo Indoor Air Care Monitor (coach)
FEATURES
  • Complete integration of Netatmo Indoor Air Quality Monitor(s)
  • Only one QA is needed for multiple Netatmo Indoor Air Quality Monitors
  • Smart update system that follows Netatmo Indoor Air Quality Monitors cloud updates
  • Netatmo Indoor Air Quality Monitor measurements are shown on child devices added for each measurement of all monitors
  • QA has built in multi-language support with 32 languages included. QA can use HC selected language or user can select any other available language.
DOWNLOAD PACKAGE CONTENT
  • Netatmo Indoor Air Quality Monitor QA v2.0
  • Netatmo Indoor Air Quality Monitor QA User manual v2.0
  • Icons set
INSTALLATION & UPGRADE
IMPORTANT NOTE - Due to upload file type restrictions imposed by Fibaro for Quick Apps, after downloading file with FQA extension, change this extension to ZIP and then unzip package. In this ZIP package you will find PDF User manual, Netatmo Indoor Air Quality Monitor QA v2.0 Standalone.fqax and folder with icons. Please follow User manual for installation & upgrade. I hope that Fibaro will remove this limitation in near future since there is no such limitation on Fibaro Marketplace and even here for Virtual Devices.
NOTE - I know that some users will not like that this QA is encrypted. Since license is now changed to donationware, I can send original code or even unencrypted QA, but only to users that will donate. Thank you for understanding!
TERMS AND CONDITIONS
Permission to use, copy and distribute this software and its documentation for educational, research, personal use and non-profit purposes, without fee and without a signed licensing agreement is hereby granted, provided that the copyright notice, with "Terms and conditions" and "Disclaimer" appear in all copies, modifications and distributions. It is strictly forbidden to sell, rent, lease and/or lend this software for profit without prior consent from the Author.
DISCLAIMER
VERSION HISTORY
  • 1.1 - first public release as open source.
  • 2.0 - second release with changed licese to donationware. For more details please check below.
LOOK & FEEL
Enjoy coding and your new Netatmo Indoor Air Quality Monitor QA! :-)
Sankotronic
Edited by Sankotronic
New version uploaded
What's New in Version 2.0   See changelog
Version 2.0 changes:
  • IMPORTANT – Changed license from open source to donationware
  • Added variable auto_name which is by default set to value false and main QA will not change child devices to default names, but will keep names set by user.
  • Added variable connection which value is set by QA depending on the connection status. If connection to Netatmo servers is OK then variable is set to value true. If there is problem with connection, e.g. refresh token is not valid anymore or there is no internet connection etc. then variable is set to value false.
  • Adjusted authentication process to the latest changes done by Netatmo. User need to add app under My apps section on Netatmo connect and will be provided with client id and client secret needed for refreshing tokens. Also, refresh token can be then generated and pasted to the QA variable. The QA is now monitoring validity time of the access token and refreshes it only when is needed.
  • Added QA icons setup variable main_icon. If set to 1 then QA will not set main QA and child devices icons so user can setup icons manually. If user import all 17 icons and then setup first imported icon ID to this variable then main QA and child devices icons will be set as soon as the QA is restarted. In case icons are setup then child devices for CO2, wind and gusts speed and rain will also change icons to reflect current measurements.
  • QA is now checking if option "Use the new views in mobile application" is set adjusts HTML tags for labels accordingly.
IMPORTANT NOTE - Due to upload file type restrictions imposed by Fibaro, after downloading file with FQA extension, change this extension to ZIP and then unzip package. In this ZIP package you will find PDF User manual, Netatmo Indoor Air Quality Monitor QA v2.0 Standalone.fqax and folder with icons. Please follow User manual for installation & upgrade.
