Showing results for tags 'door lock'.
door lock Yale Lock not completing sync process
suds32nz posted a question in Other Devices / Third-party devices
HI Still no luck with my lock, do you need to remove it and re add it to get the slots to work. Have a yale lock - Touchscreen Digital Deadbolt - SYEDDB/220/NZ Works fine as a lock ie lock unlock. Device kind:Door lock Producer:ASSA ABLOY Version:83.32 Configuration:Device configured Thanks -
I had two Zipato RFID Readers. Both died nearly at the same time So there is no other RFID Reader with Z-Wave support available. Because of this I had to use a "normal" one and connect it to my HC2. One disadvantage is that I won't know which PIN code or which RFID has been used during last login! Here is my description how I did set it up. Maybe others will need this information too or somebody else has some improvements (mostly according the Fibaro Smart Plant). I am pretty sure that @petergebruers has some improvements for me I did search in the web for any solutions but could not find anything useful. Most persons did ask how to wire it properly and did not come up with a working solution or some others explained that it is working...but not how why have done it. So what is needed: I am using the new Fibaro Smart Plant FGBS-222, any RFID/PIN/Fingerprint Codepanel and a power supply. You can use a normal one (between 6V and 24V) or a special one for the codepanel if a bell, door lock, additional switch or something else should be used also. I did connect power to the codepanel (DC+) and to the Fibrao Sensor (P, red wire) and ground with Fibaro (GND, blue wire) and twice with the codepanel (GND and COM). Also I did connect the alarm wire of the codepanel with IN2 (green wire) of the Fibaro module and the NO wire of the codepanel with IN1 (yellow wire) of the Fibaro module. (Later on I will do some drawing). To make this working you will have to change the settings of the Fibaro module. For me it was working by using the scene activation. For this I did set up input 1 and 2 as mono stable (I think this is parameter 20 and 21), did put HC2 in associative group 2, disabled the two output connections (you don't have to do this I think), enabled "Key pressing and holding" for Input 1 and 2 (alias parameter 40 and 41) and that's it. Than you will have to write two scenes. Both should react on the scene child module of the Fibaro Smart Implant for the action "Key [1|2] HeldDown". Key 1 will get triggered if somebody authenticated successfully and key 2 will get triggered if the alarm (e.g. somebody tries to open the case) goes on. My use case will be to open the garage door or open the cellar door by entering the proper ID or using the right RFID chip.
I'm planning to buy a door lock but I need your support to know wish device should I buy also I need it to be compatible with keypad and video doorbell
Hello Dears, I have a Yale door lock (YDM 3168) with a z-wave module which was added to an old defective HC2. I replaced HC2 and I am trying to add this door lock to it but I am not able. As far as I know I need to reset the z-wave memory to be able to add it to a new HC2 as the other Fibaro devices, but I don't know how. I deleted the credentials from the Yale door lock but it still does not work. Anyone has an idea about this issue?. In addition, I noticed a new section 'to add a lock' in the last update of HC2. How can I use it to add my Yale door lock? Thanks in advance
Hi everyone, Firstly, I apologise for asking questions that I am sure everyone has asked. In a nutshell I have bitten on more than I can chew on a massive home renovation and want to install Fibaro however am going to have to do this myself. I have some knowledge of how this all works but need a ton of guidance. I am based in London and below is what I was hoping to do and if I can get advice on what products to look into etc that would set me on the right way… and please assume you are talking to an idiot and dumb everything down J Task 1 – Lighting From my understanding the Dimmer2 module will work up to 250w however I must have dimmable bulbs installed. However, for my hallway lighting which on each floor (ground, first floor and loft) I have a 3 way circuit to turn lights on and off, do I need to install a separate dimmer module to each of the circuits behind the switch (as I was planning on have a 3 way switch) OR do I have to install a relay switch to each of the circuits? Task 2 – Underfloor heating I will be installing water underfloor heating downstairs (5 zones off the same manifold) and then electric underfloor heating in the bathrooms upstairs and the loft. I really am confused on how I can integrate this into the system. What underfloor heating do I need? What valves do I hook up to the manifold…how can this control the temperature? How do I wire the thermostats for the electric UFH and how can temperature go up and down? Task 3 –Electric gate and intercom I am planning on having a gated front with an intercom. I want to be able to get notifications on my phone should someone press the buzzer so I can speak to them and let them in if needed remotely.. I also want thobes to open the gates when I press it. Is there a certain motor I should buy? Certain intercom system? Task 4 – Air con I want to either install or run all the pipework and fit the actual units at a later date (depending on how I am getting on with costs) so want to know what air con systems are fibaro compatible? I want the units in the ceiling with grills so everything is hidden. I understand that I could use modules (figuring out how to wire them is another story) however I want to go with the easiest and most straight forward options given it will be a self fit. Task 5 – radiators I want to be able to control the tempreture of certain radiators, can you confirm all I need is a danfoss radiator valve? Task 6 – front door lock I was locking at installing a front door lock that can be opening with a code and with your phone. Any specific locks that you would recommend? i want to be able to override it should it not work so that is important to me Task 7 – cinema room Basically I am going to have a cinema room in the loft. I will be installing sonos throughout the house and have over 10 zones. However, in my loft I want to be able to control the tv, set up lighting scenes for when I hit pause etc. I don’t see how just a relay switch can do this as I need to control the tv, sky etc. Can I please get information on this? I understand I am after a lot however I have tried doing a ton of research prior to taking up your time so really would appreciate the help on how I can do each of the above along with information on EXACTLY what I need given I am based in London etc. Thank you in advance. Kind regards, Taj
