Showing results for tags 'fgbs 222'.
Found 3 results
  1. Hello, I'm currently running into a strange problem. Running HC3 latest stable firmware 5.170.16 Besides other devices, I also have 2x Smart Implants on which I'm using the inputs. SI - ID40 works fine, inputs are very responsive SI - ID54 inputs do not change Both are connected to the same 24Vdc power supply next to each other. The inputs are just reed switches pulling IN1/IN2 to GND. Both running latest firmware v5.2 Both look identical, same security level S2A, Z-wave type 3 and SDK version 6.2, other params are identical. Both 'Input configuration = Monostable' Steps taken: Removed and re-added the device, no luck Replaced the FGBS-222 with a new one, the same behavior. Swapped the wire connector 40<>54, wiring is OK the SI-ID54 does not detect inputs There is one major difference: the working device was added months ago (I do not remember the exact FW version of HC3 at that moment), and the non-working device was added just recently. It seems that adding Smart Implants is not longer working for me.. Other devices like 'The Button' that I recently added are working straight away. The non-working SI also pop-up to the HC3 with a different icon set > see attached screenshot. Any ideas anyone?
  2. I had two Zipato RFID Readers. Both died nearly at the same time So there is no other RFID Reader with Z-Wave support available. Because of this I had to use a "normal" one and connect it to my HC2. One disadvantage is that I won't know which PIN code or which RFID has been used during last login! Here is my description how I did set it up. Maybe others will need this information too or somebody else has some improvements (mostly according the Fibaro Smart Plant). I am pretty sure that @petergebruers has some improvements for me I did search in the web for any solutions but could not find anything useful. Most persons did ask how to wire it properly and did not come up with a working solution or some others explained that it is working...but not how why have done it. So what is needed: I am using the new Fibaro Smart Plant FGBS-222, any RFID/PIN/Fingerprint Codepanel and a power supply. You can use a normal one (between 6V and 24V) or a special one for the codepanel if a bell, door lock, additional switch or something else should be used also. I did connect power to the codepanel (DC+) and to the Fibrao Sensor (P, red wire) and ground with Fibaro (GND, blue wire) and twice with the codepanel (GND and COM). Also I did connect the alarm wire of the codepanel with IN2 (green wire) of the Fibaro module and the NO wire of the codepanel with IN1 (yellow wire) of the Fibaro module. (Later on I will do some drawing). To make this working you will have to change the settings of the Fibaro module. For me it was working by using the scene activation. For this I did set up input 1 and 2 as mono stable (I think this is parameter 20 and 21), did put HC2 in associative group 2, disabled the two output connections (you don't have to do this I think), enabled "Key pressing and holding" for Input 1 and 2 (alias parameter 40 and 41) and that's it. Than you will have to write two scenes. Both should react on the scene child module of the Fibaro Smart Implant for the action "Key [1|2] HeldDown". Key 1 will get triggered if somebody authenticated successfully and key 2 will get triggered if the alarm (e.g. somebody tries to open the case) goes on. My use case will be to open the garage door or open the cellar door by entering the proper ID or using the right RFID chip.
  3. Hello, i bought a smart inplant fgbs 222 but when i add it i cant see all the parameters it starts with 24 and i need to change 20 and 21. it also needs a update but it does not show the firmware update button?
