Showing results for tags 'rfid keypad'.
Found 3 results
  1. I had two Zipato RFID Readers. Both died nearly at the same time So there is no other RFID Reader with Z-Wave support available. Because of this I had to use a "normal" one and connect it to my HC2. One disadvantage is that I won't know which PIN code or which RFID has been used during last login! Here is my description how I did set it up. Maybe others will need this information too or somebody else has some improvements (mostly according the Fibaro Smart Plant). I am pretty sure that @petergebruers has some improvements for me I did search in the web for any solutions but could not find anything useful. Most persons did ask how to wire it properly and did not come up with a working solution or some others explained that it is working...but not how why have done it. So what is needed: I am using the new Fibaro Smart Plant FGBS-222, any RFID/PIN/Fingerprint Codepanel and a power supply. You can use a normal one (between 6V and 24V) or a special one for the codepanel if a bell, door lock, additional switch or something else should be used also. I did connect power to the codepanel (DC+) and to the Fibrao Sensor (P, red wire) and ground with Fibaro (GND, blue wire) and twice with the codepanel (GND and COM). Also I did connect the alarm wire of the codepanel with IN2 (green wire) of the Fibaro module and the NO wire of the codepanel with IN1 (yellow wire) of the Fibaro module. (Later on I will do some drawing). To make this working you will have to change the settings of the Fibaro module. For me it was working by using the scene activation. For this I did set up input 1 and 2 as mono stable (I think this is parameter 20 and 21), did put HC2 in associative group 2, disabled the two output connections (you don't have to do this I think), enabled "Key pressing and holding" for Input 1 and 2 (alias parameter 40 and 41) and that's it. Than you will have to write two scenes. Both should react on the scene child module of the Fibaro Smart Implant for the action "Key [1|2] HeldDown". Key 1 will get triggered if somebody authenticated successfully and key 2 will get triggered if the alarm (e.g. somebody tries to open the case) goes on. My use case will be to open the garage door or open the cellar door by entering the proper ID or using the right RFID chip.
  2. Hello, I started to install a rfid keyboard with a FGBS01 to make a keyboard for the alarm. I installed, wired and configured everything, but.... it doesn't work.After 2 days of tearing my hair out, I came for help ? I suspect an error in my cabling that is below: > Drawing A My objective is - use the bell button to include it in an arming scene - use the code to disarm. But here it is, when I set the IN1 input to Binary NC (or NO for that matter) it doesn't detect a change of state. And at the doorbell I have almost nothing that passes (0,6V ????) So I've revised my wiring and I'm thinking of doing this, but I hesitate between these two solutions: > Drawing B1 or > Drawing B2 Is either of these two solutions good? Anyway, I think my wiring is not good. And by dint of trying everything, I changed the configuration in the HCL 20 times. You will have understood it, I am lost, and by dint of trying everything that was going through my head I am completely in the fog now. Thank you for your help
  3. Hi I have created 2 lua scenes to arm and disarm the alarm and this is triggered by a switch The intention is to replace the switch afterwards with a RFID keypad to trigger the 2 scenes I can arm and disarm the alarm with the switch So this is working .. no,problem so far But when the alarm is triggered to go off I can not start any scene any more So I can not disarm the alarm with the swicth anymore as the scene does not start anymore "Do not allow to stop Scene while alarm is running" is on But it not the same as "do allow to start Scene while alarm is running" The only way I found to disarm the alarm is via the PC, tablet or smartphone after giving the pincode I want also to disarm the alarm with the scene triggered by the switch ( RFID Keypad) Any ideas how to do it Thanks
