Showing results for tags 'zxt-120'.
Version 1.0.0
116 downloads
This is a simple VD+Scene to control ZXT-120 AC controllers. I use it because of 2 factors: 1) You can control everything on one screen instead of 3 devices in HC2 interface 2) it is visible in Home Center app (ZXT-120 is not visible natively yet) It supports heating and cooling modes and fan speed. You can see current status as well. Setup is very simple: VD - just put ID of the child device of ZXT-120 which controls temperature into the "Port" field of VD Scene - You have to put IDs of three child deviced of ZXT in the triggers field annd the same ID into "Options" part of the scene. Also put VD ID inn the "Options" part. Maybe it can be useful for some of you. ZXT-120.zip -
Version 1.0.0
119 downloads
ZXT-120 is an IR extender for air conditioners, but it can be learned up to 20 defferent ir code for multimedia. The process of learning of zxt-120 is written in its manual, but i want to show a way to use that codes in fibaro HC. For this purpose we have to change the virtual device IP Address with your HC ip, and write 80 in TCP port box: You can change the buttons according to your custom multimedia device (here we made a TV control): Now you have to change commands for corresponding buttons. For example for first button: Authorization code is your username:password in 64Base format. admin:admin => YWRtaW46YWRtaW4= We can learn up to 20 code according to this list: Use this command for changing mode : /api/callAction?deviceID=107&name=setMode&arg1=0 For setting temperature (in cooling mode): /api/callAction?deviceID=107&name=setThermostatSetpoint&arg1=2&arg2=23 For setting temperature (in heating mode): /api/callAction?deviceID=107&name=setThermostatSetpoint&arg1=1&arg2=21- 1 comment
- remotec
- multimedia
(and 3 more)
Hello. I have a Remotex ZXT-120 for controlling the AC/heat. Is it possible to make it aviable to the Haeating panel for a zone? Viritual device with LUA or something? All I need is the Heat and Off.
- 2 replies
- heating panel
- ac controller
Hello fellow Automaters, I have a problem with a brand new ZXT-120 from Remotec that should control my LG AC unit. Before I found this device I had it set up with a dry contact from LG and a relay switch from Fibaro. It was only allowing me to turn the AC on or off to the state chosen by remote. It wasn't that bad but was also giving me many issues. Switching dry contact mode was disabling LG remote at all - so when time of the year was changing and I wanted to switch from heating to cooling it was very annoying to go through the process - especially that it wasnt very intuitive and required turning the POWER of the device off (which meant disabling electrcity at all in my apartment) But to the point: I have just received my new ZXT-120 from Remotec. The device HW version (found on the sticker) is 1.80. It is working in FLiRS battery mode. When I add it to my HC2 though (4.161Beta) it is being discovered as a version 1.20. I got 4 devices discovered (as per attached pic) and i can communicate with it. Version 1.20 codes only support 4 different codes for LG ACs (parameter 27), while version 1.80 supports 8 or 9 different codes. For me - only the 4 old codes are available from within HC2 parameter 27 (the max value set there is 512, while 1.80 new parameter codes exceed value of 512). The 1.20 old codes do not support some of my AC functions like FAN, and FAN Speeds. I am not sure that it also sends correct commands to my AC unit. I have tried to remove/add it 6 times already. Also With Wide Network Inclusion mode and without it. The standard troubleshooting I did included adding within 10 cm from HC2 and from normal location. It just discovers it as a version 1.20 and there is nothing I can do to change the required parameters. Version 1.80 has also additional code that is below 512 (464 - squared in the pic) but also not available for version 1.20 Has anybody faced that issue? Can you guys help please?
[TUTORIAL] Control Multimedia with Remotec zxt-120
marshal posted a question in Other Devices / Third-party devices
ZXT-120 is an IR extender for air conditioners, but it can be learned up to 20 defferent ir code for multimedia. The process of learning of zxt-120 is written in its manual, but i want to show a way to use that codes in fibaro HC. For this purpose we have to make a virtual device, and fill its IP Address with your HC ip, and write 80 in TCP port box: Then make buttons according to your multimedia device: Now you have to write commands for corresponding buttons. For example for first button: We can learn up to 20 code according to this list: Use this command for changing mode : /api/callAction?deviceID=107&name=setMode&arg1=0 For setting temperature (in cooling mode): /api/callAction?deviceID=107&name=setThermostatSetpoint&arg1=2&arg2=23 For setting temperature (in heating mode): /api/callAction?deviceID=107&name=setThermostatSetpoint&arg1=1&arg2=21 -
Hi guys, is there a lua command to soft reconfigure a device. I'm trying to write a script to test the IR code sets of a remotec zxt-120 v1.6 aircon controller, but given a soft reconfigure is required after every code set change, it would be easier with a lua script
