adyboss 11
Here is my problem and what is happening with my automation scheme.
I am using the following:
- Fibaro HC2 - 4.160
- Fibaro TRV (radiator head thermostat with external temperature sensor)
- Danfoss Link RS Z-Wave (Room thermostat and temperature sensor)
- VD - Heating Override v1.3 - @Dave Harrison
- Scene 1 - Multi-room Call for Heat - @Dave Harrison - local threshold = 0.3
- Scene 2 - Room Thermostat Override - @Dave Harrison
- Scene 3 - Main scene for time based events control {v 1.2.5} - @Sankotronic
To become HOT I have to set the thermostat (or even the valve radiator) at 26 C (or more). I can hear again noise for opening valve and radiator become hot.
As high I set the Thermostat temperature, as more the Fibaro TRV is opening.
The correct way is to open the radiator valve (Fibaro TRV) as much it can and when the measured temperature (by temp sensor) will become closer to the set temperature (by thermostat), the valve will close (progressive to full close).
In this way will be avoided to run the gas central without heating the radiator because of closed valve...
Or as I've started... maybe I am wrong
Correction: 2. Kids room: Danfoss Link RS Z-Wave (set as main temperature sensor and main thermostat). I have NO radiator thermostat!
37 answers to this question
