    Yes, it's marking that you have some extended (invisible) iso chars after => in the rule.
    ?? How can it hapen, and how to solve? Just delete and rewrite?
    Yes, delete the text around from "}" to after the "=>" and retype it.
    Happens me quite often when I type "}" on my Mac keyboard.
    @jgab Jan, you have checked this for me already, but this still doesn't work.
     As far as it concerns the windowOpened proeprty i can say that it is definitelly posted by the system, as i was checking this property for years using fibaroExtra without any problem.
    Do you have any clue where to find the problem?
    To monitor the triggers by the system is not an option for me, as i can't sit infront of the PC all the day and waiting for it to happen, and this trigger can not be evoked artifically i think.
    Some tips how to catch the origin of the problem?
    Is it possible that this event is not fired in the system after the fw update? I doubt it, because in main panel notification section there is the warning message from the system.
    Edited by Neo Andersson
    In the event pattern you shouldn't have value ==  '$value'
    You should have value = '$value'
    @jgab Thats the difference. For me 6 hours of searching..no result...For you.. 1 minute
    I have a picture of you on my office wall 😁
    Thats why the proposal to use ER5 it has a much better error notification.:)
    Hello Jan,
    How to send http post using rule? i didnt find any example for POST
    What is wrong with this ?
    Hello. I make a mini-calendar for myself so that I don't forget some chores around the house. and faced the problem that I don't know how to describe the rule so that it would work for me once every 3 years, let's say on September 1...
    Every 3 years? You will keep your HC3 that long? :-)
    Ok, assume, September 1, - you have to decide what time, in the morning, in the evening? Let's assume 07:00
    There is no good way to check a list of years so we do a Lua table with the years of interest...
    Jan, i need to create a rule that will check devices lastChanged property and when it is older than one day, it should report it.
    So in ER5 we can create our property, what i did, and it works, so i can get lastChanged property value from a device (if it supports it)
    How canwe create a rule that will monitor this property for a list of sensors? I created this one,should this work?
    No, :lastChanged applied to a list of devices will return a list of last changed times of the devices.
    The other problem is that lastChanged don't generate an event when lastChanged grows so we can't do a trueFor either.
    The simplest way is to check every hour and see if any devices hasn't changed for 24 hour
    and if so, filter out the devices with a :last > 24 and log them
    Now if any sensors has a :last > 24 it will log them every hour...
    Jan i am getting error
    [04.12.2023] [14:14:46] [ERROR] [ER1163]: [Rule:1:2]>> [Rule:1:@@01:00 & max(allSensors:lastChanged) > 24:00 => local devices = [ _:lastChang..] Runtime: ./include/vm.lua:89: attempt to compare number with nil gt
    @@01:00 & max(allSensors:lastChanged) > 24:00 => local devices = [ _:lastChanged > 24:00 in allSensors]; log('Devices with lastChanged > 24:00 %l',devices)
    Yes, lastChanged is not a property of a device. It's the second value you get when you do fibaro.get(id, prop).
    Also, the lastChanged as reported by fibaro.get is the epoch date of the change - we want the difference between now and the change date.
    Anyway - you don't need to define the property, the :last property is already defined and return the number of seconds since the last change - so my example should work as is.
    • 1 month later...
    On 11/10/2023 at 3:14 PM, jgab said:
    @jgab Jan this apporach seems to me incorrrect.
    || x > 5 >> dosomething
    || x == 5 >> dosomething
    || true >> dosomething
    Doesnt that mean the last part will run always? regardless of anything..becuase true is always true, so it will run even if x > 5  and x == 5 i think
    || true >> dosomething
    No, ||>> becomes an if-then-else chain where it only runs the first statement that has a true test.
    By having a true as test in the last branch that will be done if none of the previous have tested true.
    • 4 weeks later...
    Hello. Thanks to you, I'm using er4 well.
    This is the phrase I use to run the boiler.
    rule("BO.DR:isOff & BO.DRT:value<4 => BO.DR:on")
    It is allowed to be turned on when the room temperature is less than 4°C.
    Can you set a range of indoor temperatures to turn on the boiler?
    For example, I only want it to be turned on between 0°C and 4°C.
    0-4 including...
    • 1 month later...
    i wonder  how can i get too show time in the msg  when the  temp was  triggerd ?  or sent  ?
    tanx
     rule("GaragetTemp:value <= 1 & month('oct-may') & garagevarme:isOff => wait(00:00:05); Thomas:msg=log('Frys risk !!! Startar fläkt i garage %02.f grader',GaragetTemp:value) ; garagevarme:on ")
    tanx
