25 minutes ago, Sjakie said:
if you want I can send in pm something I use for curtains but I have used something similar also for blinds
@Sjakie yes please! thank you so much in advance
This works as a charm for myIPhone.
for Iphone this works great
Home:
Rule.eval([[#location{id=20,property=219,value='enter'} =>
    $Locatie_Sjaak = 'Thuis';
        log('#C:aqua#  $Locatie_Sjaak is - Thuis');
        fibaro.call(1209"sendMessage""302 - Let Op: Sjaak is Thuis",817111904)
]]).start()
Away:
Rule.eval([[#location{id=20,property=219,value='leave'} =>
    $Locatie_Sjaak = 'Vertrokken'
        log('#C:aqua#GV $Locatie_Sjaak - Vertrokken');
        fibaro.alert('push', user, '302 -Let Op: Sjaak20 vertrokken')
]]).start()
12 minutes ago, jgab said:
Well, profile as not very well managed in ER4.
You need to get the id of the Home profile and then compare that id to the active profile's id. Like this
ah ok thanks. that seems simple enough.  I do have scenes that run tests on motion sensors to determine profiles such as Home/Away/Vacation etc so I guess I can use ER to trigger those scenes
Any suggestions on how i can use Weather to trigger blinds while i trouble @Sjakie to show me his examples? :)
this what I use, don't forget to create Global Variables.
--https://openweathermap.org/weather-conditions
    Well, ER4 doesn't have anything special for weather but it can react on system weather events.
    rule("#weather{property=<prop>, value=<newValue>, old=<oldValue>} => ....")
    What you can do is setup some trigger variables for some of the weather data you are interested in.
    18 hours ago, jgab said:
    Try to make a api.post('/service/reboot',{recovery=false}) outside the rule somewhere in main() and see if it works.
    ER just translates it to a standard Lua api.post('/service/reboot',{recovery=false}) and calls it.
    it's dont  work anywhere
    Edited by fastvd
    Then it's not ER's fault :-)
    I know that there has been discussions about api reboot and shutdown have had issues - have a search in the forum...
    thanks...i found lua command for this:
    fibaro.homeCenter.systemService.reboot()
    but that's not available from QuickApps ?
    Yes, that function is not available from QuickApps for some strange reason - only Scenes. Maybe Fibaro will add it to QuickApps in the future...
    @jgab
    Hello Jan
    Can we construct complex variables using rules? Can we uise rules for defining table type variables?
    12 hours ago, Neo Andersson said:
    @jgab
    Hello Jan
    Well, you can only have complex key-value tables where the key is a symbol - which means that you can't have a number as the key. (array table {'a','b','c'} has implicit number keys)
    rule("remoteButtonToBlinds = { office_remote_controller = { key3 = office_blinds1, key4 = office_blinds2}, livingroom_remote_controller = {key1 = livingroom_blinds1, key2 = livingroom_blinds2}}")
    works, so construct a symbol index to address the table
    rule(" ...  remoteButtonToBlinds[controller]['key'++keyId] ... ")
    In Lua in general it is usually not a good idea to have complex tables with numbers as key, because you have in effect created a table with holes in them (for entries with no index)
    Your remoteButtonToBlinds table will end up as  { [1]=nil, [2] = nil, [3] = office_blinds1, [4] = office_blinds2} in Lua
    The problem one can encounter is that we can't json encode the tables (json don't allow sparse arrays), and we can't loop over the tables with something like for _,e in ipairs(<table>) do ...
    ...but I understand your need and I have created those tables myself. See if you can use the 'key'+ trick above.
    In ER5 I allow expression as keys like Lua does... ;-)
    Jan i have tried your suggestion
    but it still throws the same error, table index is nil
    You'd couldn't use the computed index so take away the brackets and use a precomputed key (no 'ctrl'++...)
    ...or you build the table in Lua.
    This assumes that you already declared the office_remote_controller, office_blinds1 etc. with rules or Util.defvars so that they are visible in ER rules. The EV function fetches the declared ER variables.
    Then you can have easier rules I guess...
    Edited by Neo Andersson
    @jgab Hello Jan
    What is the best way to add 14 day to a given date (using rules)
    @jgab Hello Jan. The IF THEN END pattern for rule is || <condition> >> <action>. But how to append the ELSE logic? || <condition> >> <action1> else???? <action2>
    What is the syntax?
    thanks
    Well, the ||>> is already an if-then-else
    ...etc
    Note, no ';' after last expression in then-do-this
