hello everyone, hello Jgab... I haven't come to the forum for a long time, I haven't played with a smart house, because it was summer.. it's time to overload my mind.. but unfortunately or fortunately it's already autumn and I need to work a little bit... I haven't followed the forum for the last 4-5 months, so maybe my idea has already been implemented somewhere...
still: there is a problem that HC3 lite from time to time disappears/falls off from wifi... I myself, who doesn't know, am a communicator, an Internet provider to be exact... and we have a simple thing called WATCHDOG for such cases.. .that's why I came up with an idea, can somehow implement this simple mechanism at the level of ER4...
if I don't forget, sometime in the spring, we raised the topic of controller overload through ARP, and even tried to reboot the remote...
well, the trigger is also not difficult to come up with... you can use the system that I use to monitor whether the phone is at home... ARP requests in another QA on some router mac, say... or I think that JGAB is an even more elegant option will offer...
@jgab
Hello Jan,
Please check on this..
I am running out of answers. This doesn't trigger
The rule should trigger whenever the global variable dayPart chanhes to 'night' and the automation_office switch is turned on. For some reason it never triggers.
BTW the dayPart global variable is also updated in ER4. Can it be somehow related to the problem?
(I have douuble checked the global variable and it is nicely updated , also the switch is ON)
    11 hours ago, Neo Andersson said:
    @jgab
    Hello Jan,
    Do you see the sourceTrigger events from global-variable 'dayPart' and/or the sourceTrigger from the automation_office device turning on?
    Only when (at least) one of those events are emitted the rule will trigger.
    Note that sourceTrigger events are only emitted when a global var or devices changes value - not if it "changes" to the same value...
    If you see the sourceTrigger events, do you see the rule being triggered but returning false?
    Ex.
    no, its independent.
    So, do you see the sourceTrigger when the variable is updated?
    Could it be that you want the rule to check the conditions when the QA starts up, and 'dayPart' is already 'night' and the device is already on? Then you need add .start() to the rule.
    Ex.
    The source trigger events are not there. (i believe, there are hundreds at this point)
    So i think your last suggestion is the problem. I need to use the start function. I thought, start function evaluates and runs the rule when the QA loads, and later the rule is not active anymore, but apparently this is not the case. So we will use the start function with every rule we have, if it means, that
    all the rules will be evaluates at the beginning without having the rule triggered, and later the rule will do his job like before.
    In this case, i think using the start function is more or less inevitable, if we want to have correct device behavior even if some rule evokers has already been triggered before.
    Thank you
    Thank you
    Yes, because rules only get triggered when something referenced in the head of the rule is changing (time rules like @ and @@ are handled similarily  and there are special "sourceTriggers" emitted when their times comes up...)
    For some rules we want to run .start() when the QA restarts, because we want to trigger rules where the condition is already true.
    However, we don't want to do this for all rules. Therefore the .start() is optional.
    Be also aware that rules using trueFor will only watch from when the rule is triggered (or .started). If a device has been on for hours and we have a rule trueFor(01:00,device:isOn) it will start to count that hour from when the QA was restarted, not when the device was last turned on.
    @jgab
    Hello Jan.
    What is the pattern for trueFor, when i am checking on multiple devices same property? Does it use OR or ANY logical connection between device states?
    How should we format it?
    Example with 1 device
    Example with 2 devices - Can we use this for multiple devices.
    If so is this evaluated as
    or it stands for
    2nd question
    Is there any performance difference between these two calls? (or any difference)
    and
    Edited by Neo Andersson
    12 hours ago, Neo Andersson said:
    @jgab
    Hello Jan.
    or it stands for
    When you test a property on a list of devices {....}:prop, the semantic depends on the :prop
    {...}:isOn            -- OR
    {...}:isOff           -- AND
    {...}:isAllOn       -- AND
    {...}:isAnyOff    -- OR
    {...}:safe           -- same as :isOff
    {...}:breached  -- same as :isOn
    {...}:isOpen      -- same as :isOn
    {...}:isClosed   -- same as :isOff
    {...}:isDead      -- OR
    It will get the property of each of the devices in the list and apply the logical operator and return a boolean
    {77,88}:isOn
    is thus equal to
    77:isOn | 88:isOn
    but
    {77,88}:isOff
    is equal to
    77:isOff & 88:isOff
    The logic is that a room with one lamp on is lit, but a room with all lamps off are dark.
    Most other :prop will just return a list of the prop values
    Ex.
    {44,55,66}:lux
    will return a list of the lux values, ex
    {200,300,200}
    Therefore you can do stuff like
    rule("luxSensors={44,55,66}")
    rule("average(luxSensors:lux) < 200 => lamp:off")
    2nd question
    and
    There is no performance diff for the execution of the rule.
    However, the first rule will be triggered also when the luxsensor changes value, the second rule will not.
    So, it depends on what you want.
    If you are "unlucky" the second rule may trigger on a breach, but the lux is < 2000 and nothing happens.
    ...a second later, while the sensor is still breached, the lux changes to 3000, but the rule will not be triggered - and you
    have a breached sensor and a lux >= 2000 but your rule doesn't run.
    Sometimes, you don't care for such cases or you only want to use the lux as a test and then it's ok to just have rule 2.
    {...}:isOn            -- OR
    {...}:isOff           -- AND
    {...}:isDead      -- OR
    {77,88}:isOn
    is thus equal to
    77:isOn | 88:isOn
    but
    {77,88}:isOff
    is equal to
    77:isOff & 88:isOff
    Ex.
    {44,55,66}:lux
    {200,300,200}
    ..."When you test a property on a list of devices {....}:prop, the semantic depends on the :prop"
    @jgab Jan,are you sure is it true for a trueRef rule too? Because i have some difficulties when i use this approach with trueFor rules.
    1.)
    this will evaluate as 'Turn off the light when both sensor1 AND sensor2 are safe for 5 min' ?
    2.)
    You wrote
    {...}:isOn            -- OR
    {...}:isOff           -- AND
    {...}:isDead      -- OR
    And how can we add some different logic, if the ER4 pattern doesn't fit for our goal. What if I want to use {...}:isOff    with OR logic operation? Can we explicitly define it inside the rule like
    1.)
    yes, it's :safe and not :isSafe
    and it will return true when both have been safe for 5min. Not that if any of the sensors goes breached during the 5min the counter restarts...
    2.)
    You wrote
    {...}:isOn            -- OR
    {...}:isOff           -- AND
    {...}:isDead      -- OR
    No, that's why we have :isAnyOff that tests with an OR. There are a few :props that return booleans and I think I have them all covered.
    There :safe,:breached,:isOpen,:isClosed are just aliases for :isOn,:isOff so you can use
    if you need to...
    You could do your own custom tests if you need
    The :value will return a list with the boolean values of the sensors in the list.
    Our custom function counts the number of true and checks if they are in the majority...
    We can use that expression inside the trueFor if we want (trueFor can take any expression returning a boolean)
    No, that's why we have :isAnyOff hat tests with an OR. There are a few :props that return booleans and I think I have them all covered.
    if you need to...
    One more thing.  How to use the same approach that we use in case of isAnyOff in case of blinds? There's no isAnyClosed pattern...
    Okay, meanwhile you updated your answer with the custom function, so that can be used in case of situtaion that are not covere by ER's  predefined patterns. This goes for blinds i assume.
    No, but because :isClosed is an alias for :isOff you can use myBlinds:isAnyOff
    I may add the :isAnyClosed alias in the future...
    as a hack you can add this in main()
    and you have an alias isAnyClosed that is the same as isAnyOff
    Thanks Jan
    @jgab
    I have added this function to eventrun. Does eventrun have its own method
    18 minutes ago, lux said:
    @jgab
    Well, if you have a list of devices
    You can do
    It will call turnOff on all devices, but calling turnOff on a device that is already off is (usually) no problem.
    For turnOn it may be a problem...
    Some multilevelSwitches may behave differently when they are turned on. Some keep their last state and some turn on full brightness - so that could cause an issue when calling turnOn on an already turned on multilevelSwitch. I don't think this is a problem for most z-wave devices, but some QuickApps may change the brightness level when turning on an already turned on device...
    You could in ER do
    ...but you could also keep your own lua functions.
    The problem with your code is that binarySwitches have a true/false value if they are on or off, and multilevelSwitches have an integer where 0 is off. EventRunner takes care of that when testing :isOn
    @jgab thanks !
    If use a lot of for _, D in ipairs (myDevices) do d: isOff&d: on end“
    Will it bring about some strange problems?
    Edited by lux
    1 hour ago, lux said:
    @jgab thanks !
    No, no problems. One way to create something like a reusable function out of it is to do
    Good idea, thank you very much
    Edited by lux
    @jgab
    It seems that there is no way to use toggle for curtains
    My use of  blind: toggle  is invalid
    @jgab rule("#turnOn{ids='$ids'} => for _,d in ipairs(ids) do d:isOff & d:on end")
                     Do i need to create a new function for dimming lamps or strips?
    now i user this:
    am i true?
    Edited by lux
