On 10/14/2023 at 11:00 AM, jgab said:
Sorry, need more info. Both 'now' and 'sunrise' haven't changed for years...
Jan, Thanks.
Indeed problem was a faulthy GV.
@jgabHello Jan, we have two questions:
1. Does ER4 offer any possible way to update a Quickapp Switch device property upon another device state change? But only the state..this is the main problem. From inside a quickappp itself i can call self:updateProperty('value', true). This usually happens hand in hand with self:turnOn function. But we don't want to change the QA's state, when it gets turned on. We want to change its state, only when some other devices change their state. A simple example is a group of lights, that are controlled by this QA switch. When user turns on the QA switch, all the lights defined in a group will get turned on by a rule rule("QAswitch:isOn => lightsGroup:on "), but we need to control the QASwitch state upon the lightsgroup lights state, and not automatically set its state inside it's self:turnOn function. So if any light state in the lightGroup changes to true, then the QASwitch state should change to true. Is there any workaround? Or we need to define event listeners right insied the QASwitch quickapp, and listen to lightGroup devices state change, and right there set the QASwitch state with self:updateProperty function. I know, this is working this way, but i am wondering, if there is no other, more felxible way from ER4 somehow?
2. What us the pattern of interactivePush messages in ER4?
thanks ahead
    :state returns a list of the true and false states of the group and we loop over the list to see if there are any true values...
    (something like listAnd will be in ER5 as it will support property list filters... )
    27 minutes ago, Neo Andersson said:
    @jgab
    thanks ahead
    Oh, interactivePush - no, nothing special in ER4 - haven't had interactivePush working for me for a long time.
    There is support in fibaroExtra that is included in ER4.
    @jgab
    manual
    Is there a better way to express this, such as isOn isOff
    I'm not sure what you want to accomplish?
    Would you like to do
    to see if any of the devices was manual???
    No, you can't. But can do
    which will return >= 0 if any device was manual...
    Jan is there a way to accomplish?
    Humidity bathroom if value goes up > 2 it starts _Stand_2
    If value higher than 5 it start _Stand_3
    I want if the value was above 5 and comes down to stop the fan because it will take too long time to come back to start value.
    fyi average humidity apartment 8 degrees lower than bathroom
    You can keep track of the previous Afz_Badkamer_Delta, and then see if its going down or up
    Like
    Jan getting error
    2 hours ago, Sjakie said:
    Jan getting error
    Sorry, first rule should be an '&' instead of 'or'. I have changed in the post.
    @jgab thank you ,i will try :
    Hello. I haven't followed the forums in a while and maybe something has changed that I don't know...I'm running a new HC3 at my friend's and installed ER4 0.961 from scratch via QA Updater, v:0.67 and started porting some rules from my ER4 which is still dragging from version 0.5 and also updated to the latest... everything is fine with me, but with the new ER4 there is some problem... the elementary rule does not work! Maybe there are some changes or something is not installed correctly?
    I already did it even for the test... the point is that the message should come to me every day at 4:00 p.m., but if I even restart ER4 at, say, 5:00 p.m., the message should catch up with the time and go away... but it DOESN'T COME!
     telegram works 100%, because all other messages from ER4 arrive correctly... until I noticed a problem with CATCH
    rule(" @{16:00,catch} => fibaro.call(teleg_sasa, 'sendMessage', fmt('test'), -4000753263)")
    /monthly_2023_10/image.png.3c70aa8cdc7dce8cd58dc2da37022d90.png" />
    in the logs it says that this rule does not have a trigger! Although I do not understand how this can be, if we clearly have a POST or CATCH! especially since there are a LOT of such rules in other dozens of HC3+ER4!
    Edited by fastvd
    Jan, Thanks again!
    in the logs it says that this rule does not have a trigger! Although I do not understand how this can be, if we clearly have a POST! especially since there are a LOT of such rules in other dozens of HC3+ER4!
    Hi, yes there was a bug in the latest version of ER for catch that was introduced in the last fix - I have updated it now in v0.998 of ER4
    ER4 is version 0.998 now (0.961 is the log message for the fibaroExtra library used)
    The [not triggered] log message says that the rule has not yet been triggered - which was of course true when the catch was broken and didn't run the rule.
    @jgab
    Hello Jan.
    I think we can't achieve the proper functionality in ER4 for our case, or if you can find any solution, that would be nice. A simple scenario, that is commonly used in many many cases in my installations. So far we had to create separate quickapps for every such device.
    We have a realRelay (that opens the gate), a realSensor (that checks the gate state) and a quickappGate switch that wraps these together, and customer sees only the quickappGate.
    Our quickapps work like this at this point
    1. When user presses quickappGate, it turnsOn the realRelay , but without affecting the quickappGate status (the self:updateProperty is not called in the quickappGate turnOn function)
    2. When gate opens, the realSensor got breached, so we listen to that event in quickappGate and only now we change its status to true. So user sees if the gate is opened in real.
    The same goes for closing.
    So i wanted to achieve the same in ER, but i think it is impossible.
    Even with help of ER4, we need to create the quickapGate anyhow thats celar, (with removed "updateProperty" code line inside turnOn, turnOff functions), because that is the interface for user, but the advantage would be that we wouldn't need to code the functionality inside the quickapp but rather in ER.
    when i wanted to call
    rule(quickapGate:isOn=>realRelay:on ) --this doesn't work. I think this is because in quickapGate we removed the updateProperty from the turnOn function, so ER does not now, that the turnOn function is called as it monitors the value property of the quickapGate, and that did not change. (it should only change when the realSensor changes)
    In one workd, just confirm me please (just no not crack my head anymore) that this is achievable only like we do it now. In separate quickapps.
    10 minutes ago, Neo Andersson said:
    @jgab
    Hello Jan.
    Hey, everything is doable in ER :-)
    If your QuickApp is a binarySwitch it has 2 properties - a value property that is true/false used by the :isOn and :on and it also decides the icon in the UI (on-green or off-red)
    It also has a 'state' property that is also true/false - This property can be used to achieve what you want.
    You QuickApp must have the turn on and turn off methods, but it only updates the state property
    In ER you have rules
    So, the QAs ON button only sets the state and waits for the sensor to set the QAs value
    Now the QA goes to "off" when the sensor is off - your use case may require different
    You are a god..
    @jgab Jan this doesn't work, The line
    the rule triggers, but the right side does nothing. In quickappGate i have this
    Jan i have created 3 test devices, to test what is happening
    Just for testing, so i dont need to open/close my gate all the day. the same logic that you recommended is used here .
    However, when I change the testGateSensor state (created buttons to run updateProperty for the sensor, so i can test when state changes)
    So something really strange happens
    The testGateRelay also chnages to ON. For some reason
    This is from debug window.
    [true]>>'Rule:2[testGateSensor:breached=>testGate:value=true]'[21.10.2023] [12:54:23] [DEBUG] [QUICKAPP2311]:
    [false]>>'Rule:3[testGateSensor:safe=>testGate:value=false;testGate:state=false]'[21.10.2023] [12:54:24] [DEBUG] [QUICKAPP2311]:
    [true]>>'Rule:1[testGate:state==true=>testGateOriginal:on]'
    Ok, it turned out that it was an interesting issue...
    id:value=true does not translate to a property update for a binary switch, but to a :turnOn
    which calls your QAs QuickApp:turnOn function that only sets the state...
    To get around that, we need to set the properties directly, do
