Hi
If I use multiple conditions why doesn't work?  In EventRunner4
  rule("@sunrise+07:00 & @sunset+00:10 & @@00:00:05 => log('apple ')")
this line in my interpretation must send messages between  sunrise +7 hours and sunset+10 min in every 5 seconds but,  only in this periods. But the sunrise and sunset criteria isn't applied. Why ?
Edited by iTibor
complete text
You request & so it will never be true!
sunrise+07:00..sunset00:10  this is between the two values
This conditions mean between 13.40 and  20.40  - or something like this, but this rule("@sunrise+07:00 & @sunset+00:10 & @@00:00:05 => log('apple ')")  now in 11.50 doesn't have to show on the debug line de log message Alma , but does , in every 5 sec.
My initial goal it is to run a scene in every hour but only between sunrise +3 hour and sunset
Edited by iTibor
This shows every hour between sunrise + 3 hour and sunset
Thank you very much . It's working.
How can I run a scene instead of printing a log message?
sceneID:start
@jgabIs this still usable?
On 7/9/2022 at 3:25 PM, jgab said:
New version 0.81 with a new experimental feature - user action events.
When someone interacts with a device in the app there are events emitted with the device and userid.
Ex. a com.fibaro.multilevelSwitch device with id 756.
When the user with id 917 turn on, off and changes dimming we get the events
Which means that we can create a rule like
rule("#user{id=917,value='action',data={id=756,actionName='turnOn'}} => log('Ann turned on the light')")
Beware that the normal event
is also emitted.
Also the order of the events seems to not be predictable. I've seen the #device event being fired after the #user event.
Anyway, will experiment more with it to see how it can be used.
Edited by lux
On 9/1/2023 at 9:15 AM, Sjakie said:
sceneID:start
Thanks!
I have experimented some strange behavior. If someone can take a look at it?
@Neo Andersson
Edited by lux
    Yes, the once(ext_lux_sensor:lux < 720) effectively disables the rule until the lux goes above 720 again (or you restart the QA and the rules start afresh again)
    You need 'once' less than you think...
    3 hours ago, lux said:
    @Neo Andersson
    Yes, the || >> is an syntactic way to express if-then
    Hello guys
    How can we access the value coming from an event on the action side of the rule?
    In case of log function it is evidently like
    I have tried event like this
    On 9/10/2023 at 5:02 AM, lux said:
    @Neo Andersson
    Yeah that is similar to
    Thanks anyway
    The $ tells the engine that it's a variable you want to match against. But then the variable is used without the '$' in the rule. It becomes a rule local variable bound to the matched value
    Thanks, meanwhile I figured it out, that strings can not be concatenated on the right side of the rule...
    Also found two examples in this topic, how to catch who accessed a door lock. I tried both, but none of them work. Is this a deprecated function, or i just didn't get the point?
    Yes, they can, but the operator is '++' not '..'
    '..' is reserved for time intervals.
    It seems that it kind of depends on the lock.
    Can you provide me of the log of the whole event. Like
    and see what it reports when you lock/unlock it?
    The format
    don't work (anymore), the event that should be generated is
    and what's available after myLock:access... are the properties in value
    The format
    Jan, we have some other unexpected behaviours here. Custmer asked as to play some welcome message when directors arrive to office, once a day, when the first person arrives. So we created a rule like this.
    Edited by Neo Andersson
    The format
    This is what a recieved
    Then you don't get an accessControlEvent from the lock - just a property change (and no user id)
    Well, if you at the right hand do <expr> & <expr> & <expr> ... it will stop when the first expr becomes false.
    My guess here is that broadcast() return nil - i.e. false, and the expression terminates and the CEO flag never gets set.
    Make broadcast return true or rewrite
    or alternatively
    or alternatively
    The second error doesn't make sense and I can't repeat it. You have some invisible unicode characters in that string?
    or alternatively
    or alternatively
    The use case to do something once a day when something happens is quite common and there are different ways to solve it. Using a global variable to remember if it's done like you do is on approach.
    One could also use something like
    Here we use a time period 6-9 and wrap it in a once(). This means that one time during the time period when the sensor is breached it will play the message.
    The problem we have with once is that if there is no more sensor breach until 6-9 the next day, it will not play as the once is waiting for the condition to be false before triggering again (that's why once is tricky to use...)
    We solve it by sending an event at midnight that "bypasses" the sensor and test the time interval, which will be false at 00:00 so it's enabled to return true again the next morning.
    In fact, @Sjakie and I spent some time on this some time ago and we come up with two solutions. There is an optional extra argument to once that is a time when the state should be cleared.
    so this also works.
    There was also the "invention" of the time interval that is only true once a day, using 3 dots '...'
    It's kind of a forgotten command but I checked and it's still there.
