1 hour ago, jgab said:
\xE2\x8C\x9A are codes that a "..." string replaces with the byte values.
That substitution doesn't happen in [[....]] strings
Try
rule([[#notify_power => log('Uptime *0.0f годин', (((ostime () -api.get('/settings/info/").serverStatus))/60)/60); fibaro.call(teleg_fastvd, 'sendMessage', fmt("\xE2\x8C\x9A Uptime
сисеми 80.0f годин', (((ostime () -api.get('/settings/info/*).serverStatus))/60/60),
error(
    Sorry, it was the grey box with code that was the solution ... use fmt with the watchIcon value
    error(
    Edited by fastvd
    In your log it looks like
    fmt (watchIcon 'Uptime системи *0.0f годин', (((ostime()-api.get('/settings/info/").serverStatus))/60)/60)
    but it should be
    fmt("%s Uptime сисеми 0.0%f годин",watchIcon,(ostime.time()-api.get('/settings/info/').serverStatus)/3600)
    but it should be
    this work, thanks!
    Edited by fastvd
    @jgabIs there a simpler way for
    If that scene works it should be able to replace it with these ER rules
    Thank You!
    D
    Edited by lux
    • 3 weeks later...
    Jan,
    I want to use some information from Home Assistent in HC3 because I have a device what is not compatible, Aqara FP1 Human radar
    It's working nice if I use HA to switch light on/off but I want to do that in ER where all my rules are.
    In Node Red I have a flow: device>>>HC3>>>
    -device selected from list>>state=enter
    In debug I see some info
    -HC3 name>>IP adres>>>log in name>>password
    In browser I can open NodeRed
    In ER I have enabled your Node Red lines :
    Nodered.connect("http://192.168.1.194:6335/ER_HC3")
    >>Result no visual reporting in debug
    Can you please write rule how to use the info from NR?
    Thanks in advance
    Hello Jan! Tell me how to track an error in ER4 in GENERAL and at the same time give a message in Telegram...the essence of the problem: from time to time some Zigbee devices disappear from the system and then the entire heating logic breaks down...and then we see an error in the console... so the idea came not to track a specific error, but ALL in general... and then we sit down at the console and see what has already broken!
    to capture ER errors do
    I don't think calling a non-existing device causes an error though...
    1) 100% that one of my automations is breaking...if necessary, I can illustrate...but that's not the point
    2) there is a clear grammatical error in your rule, which does not trigger the rule...
    rule("#er_error{msg=msg} => log('Error:%s,msg)") - missing closure '
    3) well, as far as I understood, %s should extract the error text itself, but it also does not work (
    Sorry, was a bit fast in typing this morning - I've edited the previous post (msg=msg should be  msg='$msg')
    Jan I have a problem, I use:
    Today at 07:30 I noticed the GV is still "Avond_Laat" instead of "Morgen_Vroeg"
    it skipped two time zones.
    I can't explain that - did the QA restart/crash? When you restart, do you see the rules load?
    Nothing passed QA changed Avon_Laat was more or less the last action in debug.
    After restart QA rules are loading and values normal as far as I can see.
    This is the second time I notice Avond_Laat was still active in the morning.
    So it seems like the QA crashes and don't restart, which is strange - is the box stable otherwise?
    Jan, if QA crashes It will try to restart. If QA restart or try to restart it will send push and telegram>>> Nothing between bedtime and breakfast.
    I did't notice any instability with HC3.
    Box is stable
    Ram 51% 7% Cache 28% Buffer
    CPU 10-20 peak 60
    5.140.17
    ER .994
