@jgabI want to creat a quickapp with more child devices looks like Single-point switch,Is there a portable way?Thank you!
Edited by lux
    Eh, I think I need more info - can you describe in more details what you have in mind?
    If you wan't to create one QA that controls other (child) QAs, you should as in
    If it's to control child devices from ER, this is the place - but I need more info.
    I pushed v0.994 with support for creating children.
    Ex.
    You define children with child(<uid>,<name>,<type>), if child already exists this does nothing.
    after all children are defined you call initChildren()
    This will create variables of the uids bound to the device ids
    It will also create a variable <uid>_D that is the child device object.
    When buttons are called on the child device it will generate #UI events, that you map to what should happen. In this case we update the value prop using the child object to true/false which is expected from a binarySwitch.
    When the child changes value prop we of course get an  :isOn trigger we can act on.
    If you remove the rule defining the child (ID1 in this case), the child device is removed too when ER is restarted.
    This makes it easy to create extra "GUI" devices for ER.
    Soon I will come with an update to improve the usage of child devices in ER (already realised that interfaces were missing)
    Ex.
    Interesting idea. could you share the examples of use cases?
    If you need an on/off switch to control some rules it's easy to define a binarySwitch QA to be the GUI.
    Now this is just for predefined QA types but I could add the possibility to create a custom UI I guess...
    @jgabthank you! This is a better idea. I am considering building another quickapp and children use eventrun rules but not build in eventrun. Can it be realized?
    Another question is whether this function can be integrated, or there is a better way. This is to get a single ID, or perhaps an array ID
    Ext: It looks too long
    room804_lamps = {getID('floorname1','roomame','devicename'),getID('floorname2','roomame','devicename')}
    Edited by lux
    On 1/7/2023 at 10:05 AM, jgab said:
    So, this I think is better. It handles custom report times better.
    rule("@21:00 => post(#timeReport{reset=true})") will log a report at 21:00 and reset the sum counters.
    rule("@21:00 => post(#timeReport{reset=false})") will report without resetting the counters.
    You could do a
    rule("497:off => post(#timeReport{reset=false})") to trigger a report every time you turn off the light  and see if it sums correctly.
    To do it for power usage you need to have the power usage x time, so if you have the time? I believe that @fastvd has experimented with power consumptions...
    This rule only differs between on and off. I have a Shelly plug that records TV consumption 24/7. About 5W in stand-by.
    Is it possible to record the time when the Shelly plug consumption is > 75 W?
    rule("#timeDevices:power>75 => lastOn[env.event.id]=now") doesn´t work
    Do you have an example for me?
    It's questionable if it's worthwhile to create the map tables - because you create new ones for every call. Only if you create the tables once outside the function so they are reused. Like this
    However, if you move around devices you need to recreate the map.
    If you don't call it millions of times I would do it simpler and skip the map tables
    It's a bit more complex as power is reported every time it changes - not only when it changes > 75.
    I think this could be the way - it still works with several power plus. If it's only one device the code can be much simpler
    @jgabDo I need to add this to eventrun.lua or main.lua
    In main, add it inside function QuickApp:main(), somewhere before you define the rules
    @jgabI will try this ,thank you , a question is : if i user quick app add Relay switch , the device not recognized in  homeassistant , but i add device switch , it will recognized,Is there any way to solve this problem , Thank you!
    I use this generation the device:
    Edited by lux
    @jgab
    it can't work ! need help ! thank you
    Edited by lux
    6 minutes ago, lux said:
    @jgab
    Sorry, it should be
    and it returns a table of devices so just
    lamps = getID(...)
    You mean a com.fibaro.multilevelSwitch ?
    If it's not recognised by homeassistant it's not so much that can be done on the HC3 side because you need to communicate the selected value somehow.
    @jgabthank you very much ! i try again! now it like this!
    Edited by lux
    Hi @jgab
    It doesn´t work. It gives me an error
    [26.02.2023] [10:38:27] [DEBUG] [QUICKAPP1093]:
    Sunday, February 26, ER uptime:0 hours Sunrise:07:21, Sunset:17:57 #Events handled :1 ,#Events matched:1 #Rules succeeded:0 ,#Rules false:0 #Rules error :0 Memory:1107.8kb [100% 100% 100% 100% 100% 100% 100%]
    [26.02.2023] [10:38:44] [ERROR] [QUICKAPP1093]: in Rule:4[timeDevices:power & powerLimit(env.event.id) > PLIMIT => lastOn[env.event.id]=n...]: ./include/EventRunner.lua:1802: ./include/main.lua:220: attempt to compare number with boolean
    [26.02.2023] [10:38:45] [ERROR] [QUICKAPP1093]: in Rule:5[timeDevices:power & powerLimit(env.event.id) <= PLIMIT => sumOn[env.event.id]= s...]: ./include/EventRunner.lua:1802: ./include/main.lua:220: attempt to compare number with boolean
    What can i do?
    On 2/26/2023 at 10:46 AM, KaWi said:
    Hi @jgab
    What can i do?
    Sorry, my fingers were too fast. I updated the previous post with a fix.
    Hi Jan,
    Sorry, but it doesn´t work. I still got the error that attempt to compare number with boolean.
    I just have some time in the office 😉and I have now used the following:
    PLIMIT = 75
      local powers = {}
      function powerLimit(id,dflt) -- return power when power goes over or under PLIMIT, otherwise return false
        dflt = dflt or math.maxinteger
        local pow = fibaro.getValue(id,'power')
        if powers[id] ~= tonumber(pow > PLIMIT) then
          powers[id]= tonumber(pow > PLIMIT)
          return pow
        else return dflt end
    This works perfectly.
    Thanks for your help 👍
    Hi there
    I am new to the HC3 and to the forum, so please forgive me if this has been answered elsewhere in this 200+ page topic ;) I have read as much as I could and am not sure of the answer...
    Context: I have two split system ACs in an area of my house that is frequently damp, they are wifi-enabled and report, among other things, indoor humidity via a QuickApp. When the humidity crosses above a threshold, I want to get a notification on my phone. However, I want to rate limit the notifications so they are not just continuously flooding my phone every time the sensor is polled (which another QuickApp, for Daikin integration, does every so often, I don't know the exact frequency but it's fairly frequent).
    I have this rule (x2)
    (the alerting is different to the examples here but I couldn't get the phone:msg syntax working, so I copied that from a LUA scene)
    This is fine except when the humidity is close to 80%, which causse the sensor reading to cross 80% repeatedly in a short time (80, 75, 80, 75... etc). Is there a way I can get a notification when the sensor crosses 80% the first time, and then only once per x minutes while the humidity remains high?
    I've seen the examples using again() but it doesn't seem to be quite what I want since I don't want the x minute delay on the first notification. I'm not clear if I use wait() at the end of the rule, whether it will block the rule from getting triggered again while it's waiting?
    A second question - I have 2 of these ACs (front room and back room). Currently I just have two separate rules but is there a clever way to collapse them into one rule, so that it triggers when either goes above the threshold, but then the timer applies to both after that (the rooms are next to each other, the humidity is obviously correlated).
    Thanks!
    Edited by bonhomme
    On 3/3/2023 at 7:11 AM, bonhomme said:
    Hi there
    Thanks!
    You could do
    The 'once' part will only be true when you cross 75 but it will not send a message unless value >= 80
    You want the combined above rule? The below could work... We only get a message when one of them goes over 80.
    There are 2 different ways for the push message depending on what id you have. See
