    So, my first attempt was wrong. I've edited the previous post and are pretty sure it works now.
    Unfortunately we need 2 extra rules for the 'daiken flag' to keep track of if the value is within the interval...
    I have a feeling that it could be coded smarter....
    Jan, for a long time I wanted to ask about the implementation of two-way communication with telegrams. So that we can not only send various messages about the status of our house, but also be able to make requests, for example, about temperatures, statuses of various sensors, etc... in home assistant it is quite well implemented... there are some ideas on how to do it here ?
    Yes, it's possible.
    Create a Telegram Bot. You will get a bot ID.
    Install
    and set the BOT_ID quickAppVariable
    In ER inside main() you add something like the below. The TG_SUBS are a list of "topics" you want.
    If you send a message to the bot with
    /light hall on
    the 'light' is the topic.
    If you don't have a '/' the topic will be ""
    These are rules that allow you to do
    /light hall off
    /light hall on
    /light bed on
    /light bed off
    /light ?
    The last commands return "hall bed"
    and you get a response telling you if it was successful.
    29 minutes ago, jgab said:
    Yes, it's possible.
    Install
    /light hall on
    /light hall off
    /light hall on
    /light bed on
    /light bed off
    you wrote: Create a Telegram Bot. You will get a bot ID.
    bot ID - maybe you meant a token?
    well...somehow I managed to turn on the light...but I can't turn it off...there are a lot of errors in the bau logs...and in general, I didn't really want to send commands, but to have nice buttons...how to implement it correctly?
    On 3/4/2023 at 6:41 PM, jgab said:
    You could do
    The 'once' part will only be true when you cross 75 but it will not send a message unless value >= 80
    You want the combined above rule? The below could work... We only get a message when one of them goes over 80.
    There are 2 different ways for the push message depending on what id you have. See
    Thanks - I've put those in, will give it a test run over the next few days (it's very dry currently, but never stays that way for very long!)
    @jgab Is there a simpler way?it's for
    d
    Edited by lux
    Hello Jan,
    If I properly understod in arming scene
    partition 0 is whole house
    if I do
    The debug shows nicely all partions with their devices.
    Partion 0 ONLY shows devices listed in Partition 1
    Hello All
    from time to time i've got an error from one of my rules :
    the data are passes from node-red
    Are the data passed incorrectly , how to prevent it ? thnx for any advice.
    13 hours ago, domin12 said:
    Hello All
    After HA connection, it is easier to make quick app on HC3
    Jan, tell me how to use emoji in telegrams or push messages?
    About emoticons... the essence of the previous question is not how to send, but why they are decoded by the system, and in other cases they are sent as just text...
    here on the screenshots I used the watch emoticon, which in UTF-8 has the corresponding code \xE2\x8C\x9A
    In my 1st report, it decoded fine, and the other 2 came just as text...
    /monthly_2023_03/image.png.214ee69d84afae0fb0fb1cb480f4570e.png" />
    i found the problem...
    the whole problem is [[ here these square brackets]]
    if the rule is described through "", then everything is ok
    /monthly_2023_03/image.png.88dda40c4cee1b542e9cb3839bc9e88d.png" />
    Node red is working fine , just from time to time have this error,it doesn't do anything, the role continuously running
    /monthly_2023_03/image.png.16ac597696a04f4c2b9115e3ac768d03.png" />
    Edited by domin12
    Jan,
    r is listed in Global Variable
    Getting error
    Please advice
    Jan, any ideas how to fix this problem?
    \xE2\x8C\x9A are codes that a "..." string replaces with the byte values.
    That substitution doesn't happen in [[....]] strings
    Try
    18 hours ago, Sjakie said:
    Jan,
    Getting error
    Please advice
    Well, it's kind of a bug. You can't have #trueFor{rule=r,start=true} with r being the rule because the rule data structure is self-referring so when the rule is copied by the compiler it copy infinitely - which causes the stack overflow.
    I should add a rule index that you could match against - maybe next version. For now you can do
    Jan, awesome rule! Working nicely.
