On 2/12/2023 at 12:31 PM, jgab said:
I have modified the post Feb 6 to check for missing ip and warn about it
ok, let's simplify the problem. I noticed that the master-slave connection is not working very well....perhaps, to make it easier and more reliable, transfer the slave to a separate master and manage everything autonomously there!? But then everything would still be desirable to somehow centrally manage everything...that's why the idea of the so-called connection between ER4 came up...what is meant: there are 3 masters, each master has its own ER4, but in order to manage everything centrally, then make one ER4 is the master, and all other ER4s are slaves, and information/rules, etc., can be exchanged directly between ER4s.
Jan can you help me?
I have a QA and if I press  a button the deug show:
If I try in ER 311:btn=10 or 311:HDMI1  or   311:btn=HDMI1 n does not work.
Can you write the exact frase to execute?
    In ER you can't trigger on a button click in another QA (no event generated) The UIEvent is a local trigger inside the QA.
    If the QA updates some property as a result of the click you could possibly trigger on that.
    Jan, tell me how to describe in ER4 that there is no device in the system at all, which then gives us a failure in the operation of the entire system. The point is this:
    1) Since zigbee devices became available in HC3, I bought several temperature sensors and several relays for testing.
    2) At first, everything connects, everything even works, but then out of nowhere, they themselves are removed from the system
    3) And the situation turned out yesterday that my rule for turning off the pump based on room temperature did not work, since the device with id=789 simply did not appear in the system!
    4) Let's somehow describe it and output it to a separate variable, on the basis of which we will at least receive appropriate messages to understand that something needs to be done!
    The problem is that I only have one box so I can't test any code.
    If you have more then one ER QA on the same box it's easy to send and receive events between them
    QA88
    rule("66:isOn => remote(77,{type='lightOn',id=66})")
    QA77
    rule("#lightOn => log('Light %s turned on',env.event.id)")
    It would be possible to do something similar to send event to slave with an ER QA.
    Slave with QA 77
    So, you need uuid and integrationPin
    So this is to send event to slave, a bit unsure about the other way..
    QA88
    QA77
    Slave with QA 77
    Well, as far as I understand, this integrationPin is a secret of fibaro itself... but somehow the same home assistant according to the API works perfectly with HC3...
    Maybe just set it to nil and see if it works
    Well, if we have the ip and credentials for the slave one could use the normal REST api.
    I hoped the point with using the /slave api that we didn't need to ip and credentials because the slaves are already integrated.
    No, you didn't understand me. I'm just looking for the fibaro level slave integration workaround I described above that doesn't work very well.
    This question is really important!
    So did the code above work to send an event to a slave?
    There is an event that is generated when a device is removed that you can try to trigger on
    but it may be that this event is not generated if the device is removed by a bug...
    You could also check every minute if any device is removed like below
    1) So did the code above work to send an event to a slave? - I can't verify it, since I don't know integrationPin
    2) it's not a question of deletion, but whether there is a device with such an ID in general. I think it's better to go this way!
    ran this test code... just didn't understand where it got device number 4 from? I don't have such an ID in the system in general, and even less so in the list of local existingDevices
    /monthly_2023_02/image.png.e5d0fe1bc88d5efa19ba22256a88dbe2.png" />
    You should set existingDevices, it is populated with the existing device at startup.
    It's a list that is a key/value so {168=true,879=true,1286=true,1348=true} etc.
    When you made it into an array you got
    {1=168,2=879,3=1286,4=1348} and it couldn't find device 4 and posted the event.
    SO just leave it empty or if you for some reason want to pre-populate it add as {id1=true,id2=true, } etc.
    /monthly_2023_02/image.png.49d4f8a76249216b4478e1bf80d81ae8.png" />
    So what is line 161?
    /monthly_2023_02/image.png.f451b08f8c2e394939c5775d9cd52720.png" />
    It's your first line.
    If you need to populate the list the Lua syntax is
    {[168]=true,[879]=true,....
    ok, it didn't give an error...but again, it's not quite the same...this rule will detect when the device is actually removed, and we have to check if it EVEN exists with such an ID!
    Edited by fastvd
    yes, I already saw it myself..tmou edited the previous answer
    for the test, I replaced ID 168 with 68....I don't have a device with id=68 in my system...this is where I can check it!
    /monthly_2023_02/image.png.8b86308dbeac14dcee6817569ec15d6d.png" />
    Edited by fastvd
    In other words: how can you check if there is such an ID at all?
