    Sorry, my fault. Try this one
    there was no error...but in the logs in the console I see that:
    "HC3L-00018156","ip":"10.1.44.163","online":false
    although it is now ONLINE from the web interface
    /monthly_2023_02/image.png.4ce41e49c455cff3bd639e1a3570bd5c.png" />
    Sorry, had some debug code in there
    I removed in from the previous post.
    /monthly_2023_02/image.png.814ae2a6efc39cdefd0df0a973f5f6bb.png" />
    Error(((
    Edited by fastvd
    any idea?
    2 hours ago, fastvd said:
    any idea?
    can you replace 'checkSlaves' with this and report what you get?
    This is very confusing - and the error message didn't help is it doesn't have a line number 😕
    I believe we are not getting what we think from the api call. Can you add a debug line in checkSlaves
    can it be that you don't get the serial ?
    important that you change the line
    fibaro.post ({type='slave', id=s.serial, online=s.online, ip=s.ip, cred=slaveCredentials[s.serial]})
    to
    fibaro.post ({type='slave', id=s.serial, online=s.online, ip=s.ip, creds=slaveCredentials[s.serial]})
    e.g. creds instead of cred. However that's not the main problem.
    I think we don't get the serial number.
    we could try with the id. you have to fill in the full id.
    to
    error(
    /monthly_2023_02/image.png.77564ea6afc91844a23069226dc4ca26.png" />
    maybe it makes sense to write a simple version, without automatic substitution of all data?
    Can you add the debug line so we see what you get from the api call?
    I see now that you spelled slavecredentials with lowercase, should be slaveCredentials
    /monthly_2023_02/image.png.60272dc569b042fc26562dda368c8c62.png" />
    Edited by fastvd
    I'm not a programmer, but somehow I got the idea to look at what the query returns to the sls table... I don't know if I described it correctly, but it didn't seem to give an error... but what it did could be the reason...
    sls:null
    /monthly_2023_02/image.png.648c55ea4562da152110d4af3c0d7035.png" />
    Edited by fastvd
    Turns out we are not allowed to access the /service/slaves api the normal way. Need to dd creds for your HC3 in the code
    XXXXX/YYYYY
    /monthly_2023_02/image.png.45eb771b3e8f32286dc31089900e2fbe.png" />
    Edited by fastvd
    Hmm, the code I posted contained a lot of strange characters...
    This compiles for me
    Now it does not issue errors, and even sees which slave is currently offline. But I don't see something that triggers the reboot slave rule
    p.s.: I manually specially disabled the wifi connection with one of the slaves...
    Edited by fastvd
    Again. The new function does determine if the controller is online or not...but the next rule, which is supposed to restart the slave controller, then it doesn't work(((
