50 minutes ago, jgab said:
bat_devices:dID:bat > battLevel
залежить від того, що ви отримали подію заряду батареї, яка запустила правило, але ваше правило є правилом часу.
Щоб перевірити, чи всі пристрої мають рівень заряду акумулятора > battLevel о 09:00, виконайте
rule("@{catch,09:00} & min(bat_devices:bat) > battLevel => ....")
no, it doesn't work as it should! The reason is that I don't understand why it should work! With api, everything is easier, there all > or < work clearly, but here there is some kind of mysticism!!! 1000 firsts work, but this one does not want to do anything!!! MYSTICISM!
4 hours ago, fastvd said:
bat_devices = {70,104}
battLevel = 80
-- Check when device change bat state
rule("bat_devices:dID:bat < battLevel => post(#notifyBat{id=id})")
-- Check at startup
rule("for _,id in ipairs(bat_devices) do id:bat < battLevel & post(#notifyBat{id=id}) end")
-- Notify
rule([[#notifyBat{id='$id'} =>
log("Less than %s  battery charge of in room %s",battLevel,id:roomName)
all ok
I don't understand how these rules work and MAINLY - why do we post twice (#notifyBat{id=id}
I also do not understand this expression
bat_devices:dID:bat
we catch the word bat as value as power, but why dID?
Edited by fastvd
    No, it's not really mysticisms - even though it looks like that ;-)
    Lets' start with
    @{catch,09:00} we know , it starts the rule at 09:00 every day.
    bat_devices:bat given that bat_devices contains 2 devices = { 55,66}
    will return a table withe the battery levels of these two devices, ex.
    { 88, 99} if device 55 had 88% left and device 66 had 99% left.
    The min() function will return the smallest value from a list. In our case 88.
    So the smallest values is 88
    will then be true and run the action if the smallest battery_level in the list is still larger then 'battLevel' which was the wanted outcome. So this rule should work.
    For the other rules
    I explained the reason for :dID in an earlier post. It's just a convenience and you can write instead
    if you think it's clearer.
    The reason that why do we post twice post(#notifyBat{id=id})
    is because we have 3 rules. The first two checks the battery level and calls the 3rd rule to let that rule print/notify. This way we can let the 3rd rule act like a subroutine that we can cal from the other 2 rules to carry out the common task of notification.
    Understanding that we can post our own invented events (#notifyBat in this case) with arguments and let other rules trigger on that
    rule("#notifyBat ...
    is a very powerful construct in ER and allow us to write compact rules.
    Btw, the first rule triggers when any device has its batter level changed
    and the second rule loops through all devices at startup to check if any has a low battery_level.
    We unfortunately need 2 rules for these task as it can't be combined.
    Yes, you can poll device properties with the api but a large part of ER's efficiency is that we let rules trigger on events. In this case when a device's battery level actually changes. If we have 100 devices this much more efficient. Always, when devices have property changes, they emit an event to tell us that. The exception is that some properties only emit events when their properties change values over a certain amounts.
    For battery level I think that is the case. It can be that some devices only wake up once in a while to report it's battery level. ...and then an event is emitted, and events let ER trigger rules.
    I solved my problem with running the report at a specific hour by slightly modifying the rule with dead devices.
    Allegedly works! thanks again maestro!
    battLevel = 80
    rule([[@ {catch, 09:00} =>
    post(#notify_other{id=teleg_fastvd})
    rule([[#notify_other{id='$id'} =>
    local msg1 = { "Devices with a low battery:" };
     if id:bat < battLevel then add(msg1,fmt(' %s',id:name)) end;
      end;
      if size(msg1)>1 then
      fibaro.call(teleg_fastvd, 'sendMessage', table.concat(msg1,"\"), -700919895)
      else fibaro.call(teleg_fastvd, 'sendMessage', 'All batteries are normal', -700919895)
      end  ]])
    I also wanted to clarify: is there any limit on the number of rules in ER4 or recommended limits?
    Why am I asking: I have about 70 rules in one of QA (and I have 4 of them separately), and when I restart ER, I see their launch rather slowly in the console...or it just seems so to me))) that's why the question arose)))
    Well, you shouldn't judge it on the speed the console is updated. Have a look at the time logged instead.
    You could have a
    at the end. That way you could time how long it takes to compile and load rules.
    I may build that timing into ER in the next version.
    You could have a
    /monthly_2023_01/image.png.05bf7a0102e663ece862b5d6bffcf89b.png" />
    @fastvdI have 4 QA's with 113, 287, 105, 131, rules and they run , thanks to Jan, smoothly.
    Jan, in the resume of starting ER I see 0 errors
    in debug I have
    What is your definition of counting errors?
    I have a quick and easy question: I'm trying to make a timer to put a plug ON or OFF... Quite basic I know. I looked into past posts but could not find specific posts on how to handle variables (addition / multiplication /...) (I guess my tentative below is full of mistakes.. As it does not work).
    Any help welcome :)
    Edited by ndelaet
    in debug I have
    Well, it only errors when the rules are invoked, your errors are when the rules are define at startup, rule("....
    Can you post the whole rules (224-227)? It could be because some deviceID is wrong so the :value returns nil.
    Any help welcome :)
    First, to decrease timePhono with 60 you do
    timePhono = timePhone-60
    or
    timePhono -= 60
    So, I guess your rule could work with that change.
    I like to transform :central triggers to an event that is shorter to test against.
    This is another version, we just keep a counter of 30 and decrease it.
    Thanks a lot! This one is working perfectly (just removed 2 small typos with 'RemotePhono - RemotePhone')
    thanks! :)
    Edited by ndelaet
    Jan, indeed they are device errors.
    HC3 is running but not all devices are already connected. Still struggling with some other jobs to get the new apartment ready.
    Just curious if this was count as error in ER.
    Thanks for the answer,
    errors  count when rules crash when they execute. not when they load.
    Thanks!
    Jan I want temporary to see how it's evolving only a message if humidity change with 5%
    this does't work it will message by each change of value.
    Please advice
    There was a problem that when connecting HC3(master)+ HC3L(slave) from time to time the connection with
    the slave controller simply disappears. At the same time, the slave is physically available, it is available via ICMP protocol and via the web interface. A simple reboot helps. Here came the idea to send the reboot command through the API.
    I don't know how to do it
    in ER4 post overload request! You need to describe the authorization there.
    And don't forget to specify the "recovery" parameter: false, otherwise it will go into recovery mode.
    Well, the main thing is to distinguish that it is really not available. It can also be done through the API.
    If you make an API request http://10.1.44.185/api/service/slaves
    , then we see a list of all slaves and their "online" status: true
    This is where we need to find out whether it is true or false
    Jan, help please)
    Edited by fastvd
    Something like this could work - haven't tried as I only have one box...
    ERROR
    Have you set up the credentials for the slaves?
