    22 minutes ago, SBK said:
    Will ER4 v0.94 be available in QAUpdater?
    Yes, it's available.
    Should be - did you press REfresh ?
    /monthly_2022_11/2022-11-21_11-42-38.jpg.051b89a8b5adb50612c42074e93fe551.jpg" />
    Yes, I forgot and that was the problem. Thanks
    3 hours ago, emielstroeve said:
    thanks, but doesn't work either... I do need a user:password in the url, perhaps that's a problem?
    this is the rule:
    http.get('http://user:[email protected]/cgi-bin/ptz.cgi?action=start&channel=0&code=GotoPreset&arg1=0&arg2=3&arg3=0&arg4=0') = {"data":"","headers":{"CONTENT-LENGTH":"0","Connection":"close","Set-Cookie":"secure; HttpOnly","WWW-Authenticate":"Digest realm="Login to 10ea14149c49d01cf364a5a205d22ae7", qop="auth", nonce="440765063", opaque="c466d6f16664c0a02e7ac17b9392dfaa9df52326""},"status":401}
    So, it's a challenge response authorisation. Unfortunately I don't have access to any such device so it's difficult for me to try to hack something together.
    Here is a guy that implemented www-authentication for the HC2 (incl. HTTPS MD5 encryption). Maybe something to be inspired by.
    5 hours ago, jgab said:
    It seems to be some invisible characters. The error comes from ER don't understanding the "words" of your rules. That is usually when invisible chars snuck into the code.
    I will see if I can come up with some mechanism to kill automatically...
    My rule:
    --2) We make a trigger for the temperature in the rooms
    --2.1) Marketing
    Util.defTriggerVar('temp_mark_Trig')
    rule("mark.temp:value => temp_mark_Trig=mark.temp:value")
    --3) It is variable, whether air conditioners should work on HEATING at all.. operating range -5 to +20
    Util.defTriggerVar('AC_heating_ON')
    --3.1) If the temperature outside for 3 hours is less than 20 degrees, then permanent AC_heating_ON=true
    rule("trueFor(03:00, temp_street_YR < 20) => AC_heating_ON=true;log('It's cold outside, so the boilers can work for heating, on the street C° %s=',temp_street_YR)")
    --4) If the temperature in the room for 10 minutes is less than 20 degrees, then the permanent true is vice versa, if it is more than 21 --roughly speaking CLIMATE CONTROL
    --4.1) Marketing
      Util.defTriggerVar('mark_heat_ON')
    rule("trueFor(00:15, temp_mark_Trig < 20) => mark_heat_ON=true; log('It's cool in the marketing room, С°=%s',temp_mark_Trig) ")
    rule("trueFor(00:30, temp_mark_Trig > 21) => mark_heat_ON=false; log('The marketing room has heated up, С°=%s',temp_mark_Trig) ")
    --5) At 9 a.m., turn on the air conditioner for heating at 21 degrees, if the permanent mark_heat_ON and AC_heating_ON are TRUE
    --5.1) Marketing
      rule ([[@ {catch, 09:00} & 08:59..09:01 & wday('mon-fri') & mark_heat_ON & AC_heating_ON =>
       hub.call(mark.AC1, 'setThermostatMode', 'Heat');
        wait(00:00:10);
        hub.call(mark.AC1, 'setHeatingThermostatSetpoint', 21);
        log('Working report AC marketing-1: morning turning on AC, because it is cool outside and in the room, C° %s= on the street, inside %s=',temp_street_YR,temp_mark_Trig);
        fibaro.call(teleg, 'sendMessage', fmt('Working report of AC marketing-1: morning turning on AC, because it is cool outside and in the room, C° %s= on the street, inside %s=',temp_street_YR,temp_mark_Trig) , -720852615)
    --6) During the working day, check whether heating is needed every 10 minutes
    --6.1) Marketing
    rule([[@@00:01 & 09:31..17:31 & wday('mon-fri') =>
      || (mark.AC1:thermostatMode=='Heat' | mark.AC1:thermostatMode=='Auto') & !mark_heat_ON >> hub.call(mark.AC1, 'setThermostatMode', 'Off'); fibaro.call(teleg , 'sendMessage', fmt('Work report AC marketing-1: I TURN OFF AC, because the room is already warm, on the street C° %s=, inside %s=',temp_street_YR,mark.temp:value), -720852615)
      || mark.AC1:thermostatMode=='Off' & mark_heat_ON >> hub.call(mark.AC1, 'setThermostatMode', 'Heat'); fibaro.call(teleg, 'sendMessage', fmt('Working report of AC marketing-1 : I TURN ON AC, because the room is already cold, on the street C° %s=, inside %s=',temp_street_YR,mark.temp:value), -720852615)
    These rules worked well for about 2 weeks, and yesterday after overloading HC3, such errors began to appear + rule 6 does not work correctly, namely, it turns off the AC, even when the temperature is lower! The !mark_heat_ON variable is not actually taken into account
    Edited by fastvd
    6 hours ago, emielstroeve said:
    no difference.... still the status=401, even if I remove credentials in the beginning of the rule.
    Can you try this in a separate QA (not ER) and see if you get any output? Change the user and password at the bottom
    If it works we can clean it up and make it useful in ER.
    About rule 6, add an debug statement to see what mark:heat_ON is
    Ex.
    || (mark.AC1:thermostatMode=='Heat' | mark.AC1:thermostatMode=='Auto') & log('!mark_heat_ON:%s',!mark_heat_ON) & !mark_heat_ON >> hub.call(mark.AC1, 'setThermostatMode', 'Off');
    hi @jgab it doesn't work.....
    log:
    [21.11.2022] [17:15:17] [DEBUG] [QUICKAPP539]: test ER 539
    [21.11.2022] [17:15:17] [DEBUG] [QUICKAPP539]: OK
    [21.11.2022] [17:15:18] [DEBUG] [QUICKAPP539]: OK
    [21.11.2022] [17:15:18] [DEBUG] [QUICKAPP539]: GET Reply:
    In the success handler in the beginning of the code, if you add the status message, what statuses do you get?
    Better, lets look at the complete response
    On 11/20/2022 at 5:00 PM, jgab said:
    What version are you running?
     iam running the latest  0,92 att the time
    i think ther is a new bugg  this has workd befor . if i have 2 sensors  in  one rule  it dosent work any more
    i think somting has happend  whit this line  in the update  whit the timers   it workd in 0.92  and i have done noting att all bute uppdat the Eventrunner 4
    rule("trueFor(00:02,{Dorrsensortvatt,Rorelse_Tvatt}:safe) & $tvattstuga == 'Auto' & $Styrning=='On' => log('#C:Red#Tvättstugan Belysning är nu släckt');Bel_TakTvatt:off ")
     i have 2 sensors   one dorr and one motion senor  in the same rule
    This rule works  its  lowring the lights
    --Lampan Dämpas 1 minut innan den ska släckas mellan 06:00-21:55 ---
    rule("trueFor(00:01,Rorelse_Tvatt:safe) & 06:10..21:58 & $tvattstuga == 'Auto' & $Styrning=='On' & Bel_TakTvatt:isOn => log('#C:Yellow#Tvättstugan dämpad till 10%');Bel_TakTvatt:value=10 ")
    and the door sensor is working.  I have anoter rule whit 2 sensors that behaves the same..
    Edited by systemfel
    Yes, that was the type of bugs I was worried for - a cut and paste when I was moving functionality between ER and fibaroExtra.
    I pushed v0.95 that fixes that bug.
    Thanks.
    /J
    Thanks.
    /J
     Tack själv  :)
    Jan error occurred today see "warn" for the first time
     In version v0.95
    V0.94 no error
    Edited by Sjakie
    three QA's also same error
    log:
    Hi @jgab
    This solution works perfectly! Added the url in the ip variable, user/password and there we go!
     In version v0.95
    V0.94 no error
    pushed v 0.96 with a fix.
    The error means that you have a rule with invisible characters in them.
    It will log a warning and the rule.
    If you want to ignore it do
    39 minutes ago, emielstroeve said:
    Hi @jgab
    Funny, that's what I based my code on but I couldn't get it to work with the test site
    so I made some small changes....
    I would recommend that you wrap it up in a global Lua function and put it in a separate QA file in ER4.
    Name the QA file U_something
    The "U_" prefix will prevent the updater to remove the QA file.
    Make a function ex.
    and then call it from your rule
    Jan, awesome!!!!!!!!
    I see a few (30) rules with illegal characters.
    How to find?
    How to find?
    Can you post one of the logs?
