Sorry it was't zero but Zero in the way of empty value.
    Can you post the rule with the "empty value" that caused the error for you?
    It seems to be a non-obvious error... and I get no clue from @systemfel's rule.
    1 hour ago, systemfel said:
    i think ther  is a problem whit the timers  This has workt before
    ---- Tänder inte belysningen om det är mer än 18 lux
    rule([[$Rum2_Dorr=='Open' & Rorelse_Rum2:breached & Lux_rum2:lux > 18 & $Rum2_auto_Tak=='Automatisk' & $Styrning=='On' =>
    log('Variabel Tak är Close Rum2 '); $Rum2_Dorr='Close';
    wait(00:00:03); log('Cassandra är nu Hemma'); $Cassandra='Hemma'
    log('Tänder inte belysningen i Rum2 Lux värdet är %s',Lux_rum2:lux)');
    error
    [2022-11-20] [15:06:11] [ERROR] [QUICKAPP936]: in Rule:240[$Rum2_Dorr=='Open' & Rorelse_Rum2:safe & $Rum2_auto_Tak=='Automatisk' & $Styrning=='On' => ...]: ./include/EventRunner.lua:1781: ./include/EventRunner.lua:1143: attempt to index a nil value (field 'timers')
    What version are you running?
    I have the same problém (ER4 v0.92)
    rule("HT.Venku_Vchod.PIR12V2SchodyVchodV:breached & (sunset-01:00..23:35) & HT.Venku_Garaz.Garazvenku:isOff & HT.Venku_Vychod.VYCHOD_1_Osvit:value<20 => log('HUE světla před vraty garáží budou zapnuty v době (sunset..23:35) po dobu 2 minut.', HT.Venku_Garaz.Garazvenku:value=90,HT.Venku_Garaz.Garazvenku:isOn, wait(00:02); HT.Venku_Garaz.Garazvenku:last>=00:02, HT.Venku_Garaz.Garazvenku:off)")
    This bug occurred in v0.92
    Error:
    in Rule:242[HT.Venku_Vchod.PIR12V2SchodyVchodV:breached & (sunset-01:00..23:35) & HT.Venku_G...]: ./include/EventRunner.lua:1781: ./include/EventRunner.lua:1143: attempt to index a nil value (field 'timers')
    ./include/EventRunner.lua:1137: attempt to index a nil value (field 'timers')
    I want to point my ptz camera to a specific position when a motion sensor is breached. This is the rule I use:
    It doesn't sent the url to the camera when breached. the log doesn't has an error, instead ig returns:
    [false]>>'Rule:4[motion:breached => http.get('http://192.168.1.108/cgi-bin/ptz....]'
    The url works fine if I paste it into a browser.
    Where am I going wrong??
    Jan, I hve had 2 rules with error
    This rule for other week number are running 10 weeks without any error but today it show error. One of the GV's was empty.
    Second same error but I can't remember which rule exactly.
    Regretley I created  later a backup so I can't see it anymore.
    Jan I can do a roll back 2 days to see if error is there also present? I need to save 6 QA's text before to do, just let me know.
    Edited by Sjakie
    add second rule
    Jan,
    rule error:
    The post is executing if I do separately without any error
    I tried a few things but I can't resolve this error
    Edited by Sjakie
    removed one rule
    Good morning. Ian, tell me what kind of error it is? It happened after the controller crashed...
    Tokenizer failed you have some invisible character(s) in that rule.
    Also possible if you use rule("      and you have spaces in
    Post your rule?
    Edited by Sjakie
    It seems to be some invisible characters. The error comes from ER don't understanding the "words" of your rules. That is usually when invisible chars snuck into the code.
    I will see if I can come up with some mechanism to kill automatically...
    You once created this scene for me, for similary issue
    1 hour ago, Sjakie said:
    Jan,
    Good news, I fixed the timers error in 0.94.
    The bad news is that I have fixed a lot of other things in ER4+fibaroExtra that could have introduced new bugs.
    Try v0.94 and let me know.
    /J
    Yes, and I will incorporate that in my rule parser.
    The log you show says [fals] and that is when the rule is triggered but the test (motion:breached) is false,
    so this log is from when the sensor turns safe - and then the action (http.get) should not run.
    Try just
    to see if the call is done.
    Try just
    I'm also wondering if you need some credentials (logins) to call this url? The browser can remember previous credentials you typed into the browser.
    thanks, but doesn't work either... I do need a user:password in the url, perhaps that's a problem?
    this is the rule:
    http.get('http://user:[email protected]/cgi-bin/ptz.cgi?action=start&channel=0&code=GotoPreset&arg1=0&arg2=3&arg3=0&arg4=0') = {"data":"","headers":{"CONTENT-LENGTH":"0","Connection":"close","Set-Cookie":"secure; HttpOnly","WWW-Authenticate":"Digest realm="Login to 10ea14149c49d01cf364a5a205d22ae7", qop="auth", nonce="440765063", opaque="c466d6f16664c0a02e7ac17b9392dfaa9df52326""},"status":401}
    Try
    where you replace <user> and <pwd> with the correct credentials
    5 minutes ago, jgab said:
    Try
    Sorry, and remove user:password from the url
    rule("http.get('http://192.168.1.108/cgi-bin/ptz.cgi?action=start&channel=0&code=GotoPreset&arg1=0&arg2=3&arg3=0&arg4=0',{user=<user>,pwd=<pwd>})")
    no difference.... still the status=401, even if I remove credentials in the beginning of the rule.
    Is it an https? browser usually auto upgrades to https.
    It also seems to be a WWW-Authenticate model.
    I'm not familiar with that. It seems to be some challenge/response model. Maybe someone else in the forum knows?
    Will ER4 v0.94 be available in QAUpdater?
    Jan, is it possible to have a kind of auto update button on your QA updater.
    If press button he will update all relevant QA's.
    In case it goes wrong we can go back to the last working version.
    Than it will be a very user friendly Updater.
    Thanks in advance
