    I have pushed v0.98 with some new logging stuff.
    We can add .print() to a rule defined and it will now print some more info
    Ex.
    rule("754:isOn & $YY => log('C')").print()
    will print out the rule and list the triggers that is used to trigger the rule.
    After each trigger listed there is the time the rule was last triggered with that specific trigger.
    In these neither the device 754 or the global 'YY' have triggered the rule yet.
    If you have a 'daily' rule like @sunset it will list the time and the last time it was invoked.
    I have added this at the end of my main()
    It will print out a custom startup banner and then list all the rules and then some info
    Then it adds an hourly task that prints the info again.
    The colors for banners, rules and info can be controlled with setting these variables inside main()
    Note, that the custom banner is set to blue explicitly with the printBanner command.
    • Thanks 2
    Jan, this looks awesome! Give a lot more info without adding log(............
    Thanks!
    On 12/1/2022 at 3:12 PM, fastvd said:
    still figured out how to take into account the manual operation of the thermostat. who is interested, write...
    Jan, thanks again for a great program!
    Because I don't have any thermostats myself and thus haven't dived into the details how it operates I'm not really the right person to solve it. Hopefully someone else in the forum has some ideas?
    I have got an error when i start upp the eventrunner.
    the error mess
    [2022-12-04] [12:32:59] [ERROR] [QUICKAPP1033]: in Rule:343[@{catch,22:00} & 22:00..06:00-1 => log('Det är Natt nu'); $TOD='Night']: ./include/EventRunner.lua:1798: ./include/EventRunner.lua:1501: attempt to index a nil value (local 'ev'
    The rule . i have done  Notting too the rule
    -- Script 6 ----------------------------TimeofDay--TOD-------------------------------------------------------------------------------------
      rule("@{catch,06:00} & 06:00..10:00-1 => log('Det är Morgon nu'); $TOD='Morning'").start()
       rule("@{catch,10:00} & 10:00..18:00-1 => log('Det är Dag nu'); $TOD='Day'").start()
       rule("@{catch,18:00} & 18:00..22:00-1 => log('Det är Kväll nu'); $TOD='Evening'").start()
       rule("@{catch,22:00} & 22:00..06:00-1 => log('Det är Natt nu'); $TOD='Night'").start()
    the error mess
    Well, the @rule has gone through some changes.
    The problem is that you shouldn't add .start() to a @rule in general. You already have the catch added which makes the rules run when defined (if time have passed). Now they will potentially run twice at startup, both for the .start() and for the 'catch' which is a bit unnecessary.
    So, I would recommend to remove the .start()
    However, I have corrected the code so it will not give an error in the next release but I'm working on some more stuff to add before I push the next release.
    Oki tanx jang i will remove .start()
    I have some custom buttons in the ER. How can I prevent them from having to be recreated after an ER update?
    Jan, I have a question for you...how can we not just compare 2 numbers in the rule, but let's say so that the rule is true, so that one number is not just bigger or smaller than the other, but bigger than  specific number...
    for understanding: start the boiler, not just when the temperature in the room is less than the one set in the climate panel, but 2 degrees lower (the key issue here) than the one set in the climate panel!
    in other words, a controlled delta!
    Edited by fastvd
    This rule will trigger the diff is 2 degrees or larger. We wrap it in a once(...) so it will only trigger the first time it goes above 2. For the rule to trigger again the value has to be lower then 2.
    Unfortunately not at this moment.
    I think that if you have some custom buttons and labels it would be best to create a separate QA with the buttons and labels and that sends events to ER and that gets updated from ER.
    I can post a template for such an QA if you want?
    In the future I may add an "ignore UI" button to QAUpdater.
    Not necessary. I have two ERs running. The number of buttons is still manageable.
    Another question: How can I change the default setting fibaro._pushMethod = 'push' to fibaro._pushMethod = 'simplePush' ?
    As in
    , it does not work
    At the moment I am manually changing line 1420 after an update in EventRunner
    As in
    , it does not work
    ~1420 it should look like
    and it should work when setting
    inside main() - before that it may be set back by the line at 1420..
    What do you change to what when it works?
    I uncomment the Original-Line (1420) and insert the new Line (1421).
    This is my main()
    I reset line 1420. But it doesn't work.
    I have same problem. Simple push defined in main doesn’t work.
    @KaWiand @petrkl12 you were right - it was a stupid bug - fixed in v0.99
    /J
    Hello jgab,
    I tried the new version ER4 0.99 with QAupdater.
    It ended with an error
    [ERROR] [QUICKAPP1866]: , trying to fetch
    36 minutes ago, SBK said:
    Hello jgab,
    Sorry, too early this morning. forgot to add tag to git repo. Now it should work.
    /J
    Hello jgab
    I have the next error:
    Main() ERROR:./include/EventRunner.lua:2092: attempt to call a nil value (global 'checkForDST')
    Do I have to enter something additionally in Main()?
    23 minutes ago, KaWi said:
    Hello jgab
    Pushed v0.991 with a fix.
    As said in
    "EventRunner - now it works again!" :-)
    Thanks for your help jgab
