11 hours ago, jgab said:
So
will trigger if $LuxNiveau1 sets to 'schemer' during the given interval.
Because it triggers at 15:30 it will also run the action if $LuxNiveau1 equals 'schemer' at 15:30.
That's were it goes wrong, the action always runs at 15:30, even if $LuxNiveau1 <> 'schemer'. That's were the problem is.
So, the question is, what do you want to happen at 20:00 ?
1. You want to run the action even if $LuxNiveau1 is not equal to 'schemer' ?
No, I want the action to run at latest at 20:00 or if it's 'schemer' but only in the timeframe 15:30-21:00. I know the timing conflicts between 20:00 and 21:00, I could set it to 15:30-20:00
2. You want to run the action even if the action have been run earlier (from 15:30 to 20:00) ?
no.
@jgaI did some extra testing:
This one works fine, it doesn't run the action at 9:19 if $testVar <> 'thuis'
so, works as expected
this one however, doesn't work as expected. It runs the action at 09:19 even when $testVar <> 'thuis'
I guess the OR function messes things up?
I do have other rules with the timing statement in an AND rule only, and that also works as expected.
Edited by emielstroeve
    You are right, the @09:30 causes the rule to trigger at 09.30, but when evaluated as part of another trigger it always returns true.
    The reason is that the @time was historically an exclusive time trigger in a rule. If there was a @time all other triggers were disabled. Over time that changed.
    However, @time always returned true when tested as it was obvious that it was called at <time>. Which is not true of course if triggered by other triggers.
    I have been aware of this short-coming/trade-off but I was reluctant to let @time test if the time was the current time. The reason is that when a rule is triggered and the test is actually run, it could be a second late, and the test would return false.
    However, after some thinking I have made a new version of ER where I do this test and I save the time the rule was expected to fire and compare against that time - thus it will always be correct if testing @time against firing time.
    Long story short. There is a new version of ER4 v.0.996, where @time return false if the rule is invoked and the time is not the same.
    Your rule, I expect, would then work because it would test the alternative $testVar=='thuis' path which then could be true instead.
    Thanks for helping to improve ER.
    ...and as soon as I posted I found a bug. v0.997 is the valid version.
    (we are getting close to v.1.0 ;-) )
    Jan, did I lost my startup tool?
    Rule.eval([[hal.door:isOpen | @now+00:00:08 => ????
    If I need to try some rules I am using @now+00+00+08 but in the latest update it does't start anymore.
    With what I can replace this delayed execution on start?
    Edited by Sjakie
    No, it doesn't work anymore. It was also a kind of hack as it had strange side effects - like triggering the rule again after 24 hours...
    The best way is to implement a test trigger variable.
    all rules that have  a " & test" will be started after 3 second.
    If you want to remove the startup test then just comment out the
    if you have several rules with different delays
    Jan, thanks but I have error:
    Yes I edited the post and added a ‘do’
    Jan, sorry to bother you but if I see this in debug:
    Can you do something with it  in ER4?
    With a QA I am able to import this info name it fa keuken.radar
    Rule.eval([[keuken.radar:isOn |keueke.radar:isOff => log('......   it will show nothing
    The action should be on/off or safe/breached
    Thanks ink advance
    Thanks ink advance
    I have no idea what this QA is doing. Please explain.
    With this QA you can import devices from home assistant.
    But not all devices are working correct.
    The developper is not responding anymore
    I have send the QA in PM
    Seems to be buggy and not updating the property of the binary sensor child QA
    Can you improve it?
    Hi
    In the eventrunner 4, in main , befor this line >   fibaro.event({type='_startup_'},function() I put this
      Rule.eval("{@@00:00:05, sunrise+03:00, sunset-04:00} => log('Ding Dong')")
    My intention is to print this log between sunrise+03:00, sunset-04:00 in every 5 seconds , but doesn't work
    Could you help me?
    2 hours ago, iTibor said:
    Hi
    Could you help me?
    Jan, this does't work and I have no idea why.
    I isolated the first part of trigger in () did't help
    If I remove the first part of the trigger it will show the execution of this rule.
    PLease advice
    PLease advice
    Tricky, my testvar approach need some modification. One needs to reset the testvar to false (test8 in your case)
    ...or try this
    Nope Jan no activation of the trigger
    When I wrote the command below, it worked well, but at some point, the notification stopped coming to my phone.
