All-in-One Scene: How to do it Better
cag014
On 8/7/2021 at 10:28 PM, SmartLifeSystems said:
Hi cag! My little daugter's new hobby is to play with the radiator thermostat heads. I would like to set a notification if the set value changes. Do you have an idea how i can do it? I can't find the proper code. Thanks!
Hi cag! Can you look this problem?
  • On 8/14/2021 at 2:26 AM, Rover said:
    After refresh page I see some lines.
    What exactly do you mean by history lines?
    Here a snapshot of mine HC2
    That's what you mean history lines?
    Edited by cag014
    Is any change of the thermostat received in the system? I mean can you see the changes in the device in User Interface ?
    I can see the set temperature in the mobile app and on the webpage. I would like a notification about the change.
    Yes , that is what I mean. I did not see any lines, but after refresh page they were to be seen under the Data table auto-refresh etc.
    I had set tblRefresh to 0, but now at your value of 900 seconds.
    Edited by Rover
    On 8/14/2021 at 1:06 AM, Rover said:
    How to use HC-WebEye for HC2 with external IP?
    @cag014 please advice.
    Hi @cag014,
    Interesting riddle:
    Walli Dimmer has no interface centralSceneSupport (or sceneActivation) so  {"`Keukenverlichting`",{state="centralSceneSupport=2.Pressed2",trueAct= is not accepted by AOQ.
    But using centralSceneSupport in a scene, it works ?‍♂️
    If you receive the change then you can send notification (email/Push/Interactive Push or TTS)
    Since I don't know how you set the desired value for thermostat it's make it difficult to suggest right solution, but let assume your value is X
    {"`Therm`",{state="value<>X",trueAct={"Thermostat value changed","sendPush","Unexpected value change"}}},
    If you set the value using algorithm, I suggest to use global variable (e.g Tvalue), then
    {"`Therm`",{state="value<>&Tvalue",trueAct={"Thermostat value changed","sendPush","Unexpected value change"}}},
  • On 8/18/2021 at 4:49 PM, Rover said:
    Hi @cag014,
    Interesting riddle:
    Could you please post the Walli Dimmer properties and the scene...
    I tried this option, but I got the next debug message:
    {0, "{`livingRoomThermostat`}{`livingRoomThermostat1`}{`bedRoomThermostat`}{`bathRoomThermostat`}{`hallThermostat`}{`corridorThermostat`}{`diningThermostat`}",{state="heatingThermostatSetpoint<>15",trueAct={"In the $room the $name value has changed.","sendPush","The new teperature value is ..."}}},
    Using a GP is a workaround to trigger AOQ.
    Edited by Rover
    The devices list definition is wrong, try that
    {0, "`livingRoomThermostat`|`livingRoomThermostat1`|`bedRoomThermostat`|`bathRoomThermostat`|`hallThermostat`|`corridorThermostat`|`diningThermostat`",{state="heatingThermostatSetpoint<>15",trueAct={"In the $room the $name value has changed.","sendPush","The new teperature value is ..."}}},
    By the way  if any changed detected I believe you can set thermostats' set-point back to 15 instead of notifications (or in addition to notification)
    I don't know the command for setting point so as an example using "setPoint".
    {0, "`livingRoomThermostat`|`livingRoomThermostat1`|`bedRoomThermostat`|`bathRoomThermostat`|`hallThermostat`|`corridorThermostat`|`diningThermostat`",{state="heatingThermostatSetpoint<>15",trueAct={"$id","SetPoint,15"}}},
    Edited by cag014
    I tried your line, but the debug message I got.
    If I use the | character is that the and? It's not true? If I use this form, every thermostat head's value need change.
    No, this is a list of devices (not condition) and should create a line for every thermostat in the table.
    Have tried the line on my system - no errors!?
    Could you please post your jM lines?
    Edited by cag014
    On 8/19/2021 at 6:26 PM, Rover said:
    22 minutes ago, Rover said:
    Interesting is that the remoteController of the Walli dimmer has a CentralScene interface ?‍♂️
    Here is my line:
    {0"`livingRoomThermostat`|`livingRoomThermostat1`|`bedRoomThermostat`|`bathRoomThermostat`|`hallThermostat`|`corridorThermostat`|`diningThermostat`",{state="heatingThermostatSetpoint<>15",trueAct={"In the $room the $name value has changed.","sendPush","The new teperature value is ..."}}},
  • 5 hours ago, SmartLifeSystems said:
    Here is my line:
    That's strange...
    Could you please post properties of one of the thermostats?
  • 16 hours ago, Rover said:
    By triggering the jM line by the remoteController device of the Walli dimmer and doing the actions by the multilevelSwitch device of the Walli dimmer AOQ works for CentralScene activation!
    Let's try something interesting... download attached version and define state property using "+" sign..
    {"`wDimmer`", {state="+centralSceneSupport=2.Pressed", trueAct={....}}},
    Let me know if it works...
    Edited by cag014
