    3 hours ago, Rover said:
     What do you mean with point 2: too many commas and curly brackets (not the correct order):
    - The number of curly brackets is OK
    - The order is correct
    - What about too many commas? I am using the commas the make clear what the end is of f.i. trueAct section. The commas do not make trouble, your parsing is fine!
    You are correct, I just use not to set the commas... sorry my bad. The format is correct.
    It looks like the debug screen is still in wintertime...
    7 hours ago, Rover said:
    Time stamp displayed by the system... may be you need to reconfigure the date in HC3.
    Yes, that was the solution! Changing from [2h] Europe/Warsaw to [2h] Europe/Amsterdam did the job (both in same time zone ?‍♂️).
    Strange that the time in the setting/general screen was correct before the reconfiguration...
    Is it possible to mix AND and OR in the Params_4 section?
    I want to use this construction on many commands:
    I mean: if (BackBalconyLux < 2000 and YardMainDoorLux < 2000 and day) or night then...
    But it's not works and seems parsed not correctly
    Yes of course
    for example (using your statement correctly - assuming day and night are global variables)
    " if {BackBalconyLux:value < 2000 and YardMainDoorLux:value < 2000 and &day:value=true} or {&nigh:value=false}"
    In general all conditions in curly brackets means "and",  while "or" uses between the brackets
    Like below
    Two formats are supported (any combination in between supported as well)
    1.       [if]{cond1 and cond2 and ….} or {cond1 and cond1 and ….} or..  - human readable
    2.       {cond1|cond2|…}{cond4|cond5|….}{..} - short format
    for more info please download Advance User's Guide  and refer to Conditional Parameters section in the document.
    Edited by cag014
    19 minutes ago, cag014 said:
    Yes of course
    Like below
    Thank you, it works! But only in the human readable format
    But here is another mystic, both conditions return false in 22:29 (i suppose from 21:06) but should return true:
    {$24clock:value<>?$sunriseHour+7200?~?$sunsetHour+3600?}
    {$24clock:value=?$sunsetHour+3600?~?$sunriseHour+7200?}
    Full part:
    How to fix this?
    Full part:
    How to fix this?
    Oops... thanks for finding the bug. It was fixed in AOQ (HC3/HC3l).
    Please copy/paste attached version 7.1
    In order to keep your configuration please copy from the line
    --======================Copy form here for updates=============================================================================
    to the end of your scene.
    Didn't find any problem with standard conditional format vs human format. Let me know what exactly the problem.
    In addition in this new version any action table (trueAct{}, falseAct{} and others) could have specific conditions. Please refer to attached Advanced User's Guide (Conditional parameters section)
    Also will release the new version shortly...
    Edited by cag014
    Thanks for the fix, I'll try it later.
    Quote
    AOS log don't recognise these brackets with standard format:
    /monthly_2021_04/1760443332_2021-04-1210_44_15.png.bc37df27dc1c0c4fd3691dfeb65cf6b8.png.442af96bd37d479dcb5d43afdbee2d93.png" />
    For this code:
    For this code:
    Now I can see that... there is no need for double brackets as this is not an array just formatted string
    "{`BackBalconyLux`:value < 2000|`YardMainDoorLux`:value < 2000|$24clock:value=?$sunriseHour+7200?~?$sunsetHour+3600?} {$24clock:value=?$sunsetHour+3600?~?$sunriseHour+7200?}"
    Edited by cag014
    Gag,
    you fixed my Logitec hub in HC2
    Regretly it does not work in HC3
    fibaro.call(829"changeActivityState")
    4 hours ago, Sjakie said:
    Gag,
    My Logitech still connected to HC2, can you post the Logitech device API on HC3? Let's see maybe they have changed the commands...
    Thanks, in HC3  I cant open it.
    In HC3 I download it as QA plugin.
    The device has no option to save as fqa
    //Sjakie
    But when you have connected to the Logitech, is it created some Childs?
    If so please post theirs APIs
    Edited by cag014
    21 hours ago, Sjakie said:
    Gag,
    If you try?
    I tried >>nothing
    also with stop, start, play, go
    //Sjakie
    yes it created Childs
    Cag how to find API? I can not open any Child or HUb main
    Hub connected
    Hub online
    I deleted Harmony plugin
    reinstalled Harmony plugin
    modified HT
    Test
    Nothing
    //Sjakie
    //sjakie
    nothing happens
