1 hour ago, cag014 said:
Yes, it does... I made required changes and it does run on my HC3 lite
I mean version 9.7 and later  I released here.
AOQ version 9.5 doesn't support HC3 lite.
Will release updated version at download center soon.
Doesn't work even in version 11.2
    Have checked again... works fine
    Might be one thing is different, your HC3 lite probably is production box... my is for testers...
    May I ask you what is the serial number of your box?
    Edited by cag014
    HC3L-00000221
    /monthly_2021_03/1259849113_4.PNG.06520ab303580718cd39f7f128af31b4.PNG" />
    9 minutes ago, minsad79 said:
    HC3L-00000221
    As I thought, they have changed the prefix...
    please try attached version and let me know if it works
    It started working
    /monthly_2021_03/1867187499_5.PNG.e7a9e4d6da2d70101987d3f0049db899.PNG" />
    3 minutes ago, minsad79 said:
    It started working
    Great, let me know if you have any issues...
    Thanks for the quick feedback
    Yes, no problems for me after an update.
    I updated the HC3. The Satel alarm devices icons I can't change. Except for that, everything is all right.
    Uhhhh. @cag014! Have you got an idea?
    I have got a hard CPU values.
    I think normalized. I reboot my HC3.
    I updated the motion sensors, and I think that was the problem.
    Motion sensor update caused that ?!!
    There is no dull moment with Smart Home...?
    I updated yesterday, and now here is the next beta. Somebody tried? AOQ working fine on new beta?
    Honestly, I don't see any advantages of this release (see change log), unless you've memory problem. Looks like they did some major change on that.
    Have tried to visualize the flow of the All-in-one with the conditions... hope it helps
    Edited by cag014
    Hello Cag,
    In 5.070.42 my push messages arent working but your AllinOne is sending me messages about knack for some devices by restarting.
    Is this also connected on the admin acount?
    //Sjakie
    4 hours ago, Sjakie said:
    Hello Cag,
    //Sjakie
    Fibaro did it again... total mess with the push notification
    Now the user ID for notification is not available in QA (in scene only)
    Please change in user_data  user-ID to mobile ID.
    pushNote    = {true,"82"}
    Cag,
    In QA user ID is valid in my? case admin doest work.
    I dont see other users complaining.
    //Sjakie
    That's strange... for me user ID doesn't work, but mobile ID does!!
    Do you have mobile device assigned to admin account? If, yes could you try to use mobile device ID instead of admin ID
