    attached AOR version includes setIcon command and email,push notification fix when HC2 defined as a master controller.
    2 hours ago, cag014 said:
    @SmartLifeSystems
    Attached version includes an option to change icons of devices and scenes. (HCL, HC2, HC3). The command is setIcon
    Please make sure to provide correct icon ID
    1. device icon must be a number for all controllers.
    2. scene icon should be a number  for HCL and HC2 and Icon name for HC3
    Here an example how to do it in action tables:
    for devices:
    trueAct={"300","setIcon,1010"}
    trueAct={"400'hc2","setIcon,1010"}
    for scenes:
    trueAct=("_35","setIcon,scene_movie"}   --- HC3
    trueAct=("_35'hc2","setIcon,100"} -- HCL,HC2
    All standard parameters could be in use (delay,conditions and etc)
    Hi @cag,
    Sorry, but I get an error message.
    26 minutes ago, SmartLifeSystems said:
    Hi @cag,
    Ooops, my bad
    Fixed
    @SmartLifeSystems
    Sorry about extra "stupid" bug... when setIcon executed correctly it displayed as an [ERROR] instead of [TRACE].
    fixed
    3 hours ago, cag014 said:
    @SmartLifeSystems
    fixed
    How to get the number of an icon (HC3)?
    Edited by Rover
    place mouse cursor on the icon, press right button and choose "Inspect Element"
    Now go to http://<HC3-IP>/api/icons
    in device table find the icon name and use the ID: number.  Please not some of the names are in Polish....
    For scenes use the icon name without suffix .png. Like User1001.png use User10001
    Edited by cag014
    If I remove a Wall Plug, f.i. the Wall Plugs I am using in the Christmas period, mail notifications are sent that the device is dead or device wake up. in itself a nice feature.
    However it would be nice if devices could be temporarily inactivated while still present in jM lines, so that no notifications about dead status have to be sent.
    First of all, AOS,AOQ and AOR are monitoring all devices in the system  regardless if they are in use in jM lines  and notification sent in case they are dead.
    If you decided to remove device ( I understand you mean the device just disconnected from the power) I suggest to disable the device in the system. No notification will be generated.
    Yes I mean just disconnected from the power until next Christmas. But if I disable the device in the AOQ system, that means commenting the device in jS2n, all jM lines containing this device are complaining (f.i. the jM line turning off all 30 lights when going to sleep, inclusively the Christmas tree).
    So my request was to be able to disactivate the physically removed wall plug in AOQ, while all jM lines containing this device remains working independently of the state of the disactivated device.
    I tried today the working of Geofencing using my iPhone.
    {"$geoAction", {state="enter", trueAct={"Geofencing","sendEmail,2","Komt er aan"}, falseAct={"Geofencing","sendEmail,2","Gaat weg"}}},
    The result was:
    So two notifications after another when coming home, but no notification when going away from home.
    Edited by Rover
    23 hours ago, cag014 said:
    @SmartLifeSystems
    fixed
    Hi @cag014,
    I tested it. Working fine. Nice job! :)
    The result was:
    It happens sometime when your mobile phone suddenly sends previous and current location. (Might be depends on phone sleep mode... try to configure that the phone won't put the app to the sleep mode)
    The Geo-location is  totally depends on your fibaro app. on the phone.
    Based on  my experience  the new app. sends more precise data than old one.
    I think iPhone app less reliable than android also.
    is anyone that uses GPS functionality can provide more information about GPS performance?
    By the way if you're using Android phone, may I suggest  to install
    app and to send push notification (instead of email). In this case you'll hear voice (Text-to-Speech) notification about users' location (have found that's very convenient for me)
    Edited by cag014
    5 hours ago, SmartLifeSystems said:
    Hi @cag014,
    Thanks,
    I'm curious, what exactly it does for you? I mean in what kind of situation you need to change the icon on the fly?
    Edited by cag014
    10 hours ago, cag014 said:
    Thanks,
    I bought a Netatmo weather station. I change its icon depending on the weather.
    2 minutes ago, SmartLifeSystems said:
    Vettem egy Netatmo meteorológiai állomást. Az időjárás függvényében megváltoztatom az ikonját.
    And another notice.
    What is this warning message? It appears every ~5 minutes.
    A
    Edited by SmartLifeSystems
    And another notice.
    A
    It means your HC3 has slow communication ... Please check CPU and RAM.
    You can increase the limit from by defining the limit of the slaveApiTime (in ms)
            home={user="xxx",passwd="xxx",ip="10.0.0.1",slaveApiTime=600}
    Edited by cag014
    Is this possible? We have this problem with several devices.
    No, I I mean disable the device in the system
    If a device has been disabled in the system and present in jS2n, is this device then also conditionally disabled in a jM line, or is it true or false in a jM line?
    Edited by Rover
    It's still a live in jM lines, but as I thought you have disable the line?
    By the way to disable the line in jM doesn't mean to make the line as a remark. Set timeSpan  to negative value -1. (see below)
    {-1,"device",{state="true..........}}},
    Now all your lines with references will work as expected.
    No I have not disabled a line. I just want to remove wall plugs without disturbing the AOQ behaviour or disabling a jM line by -1.
    Situation: 30 devices are to be turnOff by one line (grouped device alias). If a few devices in that group have been disabled by system, what is then the resulting behaviour of the jM line? And what is the behaviour if these devices are not disabled by system, but simply physically removed from the wall?
    Situation: a jM line containes as condition the value of a by system disabled device. Resulting behaviour jM line?
    Edited by Rover
    I think you do have a point... I will add to check devices status , the question how to use this data?
    1. in displayed command to set note that the device is didabled?
    2. to remove the device from the jM list during initialization (and to display the list of disabled devices) and entirely to ignore it during operation?
    I think the second option is better solution.
    Let me know if you have any other idea.
    BTW - please notify that if the disabled device is part of conditions then the parameter value will be the last saved state always w/o any changes
    Edited by cag014
