    Attached version includes command action states description in hcWebEye
    [20.01.2021] [11:24:01] [ERROR] [QUICKAPP372]: QuickApp crashed[20.01.2021] [11:24:01] [ERROR] [QUICKAPP372]: main.lua:1523: unfinished string near
    No... maybe same problem as @gggizmo, needs to reboot?
    By the way for the first time that you copy the code,  you'll see a random error but the program runs... that's OK in this HC3 version...
    Edited by cag014
    run errAct{} ?!?
    no display of okAct or errAct ?!>
    1 minute ago, cag014 said:
    Could you please post entire line?
    The entire line has been showed above.
    17 minutes ago, Rover said:
    Could you post debug window of commands sent to buzzer?
    Have tried to display errAct or okAct, but since these actions could be long and complicated it makes mess on the commands structure.... didn't find proper way to display it yet.
    22 minutes ago, Rover said:
    Try attached version
    Let me know if buzzer works
    Yes, works!! ?
    What was going on?
    Yes, works!! ?
    What was going on?
    Since you have errAct and okAct they replace current trueAct in buffer... this is a mistake from me, they should be executed in parallel to all other actions. Fixed...
    Does that also explain the "run errAct" in webEye?
    No... trying to find why it displayed in the wrong command.
    @Rover
    Attached version displays correctly the verification request, but in order to display errAct or okAct extra two columns should be added to the table.
    Since most of the commands are not include verification, do you think it necessary and must be included?
    Edited by cag014
    7 minutes ago, cag014 said:
    @Rover
    webEye display is correct now with correct indication of verification ?. I do not understand your question: why remove this nice display of verification, or do you mean if other commands then arming/disarming should also have verification indication? In that case I do not think so.
    Display of errAct and okAct would be nice to have a complete insight.
    The verification would be always displayed where defined.
    I meant the errAct and okAct display...
    Maybe errAct and okAct are used more then f.i. timeLoopAct. I think it is necessairy when operating a lot of devices within one command taking noticeable time per device, like arming/disarming. Although since your last timing miracles everything is super fast: arming/disarming in a few seconds and also putting all lights on/off in a few seconds! When I am thinking back to the HC2-slaves period where all this took more then a minute...
    Attached version includes dynamic columns arrangement and shows only columns of actions in use. It means if you don't use some action then the column is not displayed.
    So if you have errAct or okAct it will be displayed.
    In addition fixed an issue when using delay in conjunction with state condition, the status printed all the time till the command executed.
    One AOQ OK, other AOQ (the one with okAct/errAct):
    Edited by Rover
    What is in webEye the meaning of value TBR?
