13 minutes ago, Rover said:
All fine this night with v9.7 ?
After this third successful night with the timing function I declare the problem for solved ?
Yes, I think too.
Cosmetic issue:
The first and the second column are not really synchronyzed.
    6 hours ago, SmartLifeSystems said:
    I tried the command, but I think the os.Date don't working.
    I tested a simple line, but the AOQ don't do anything.
    Here is the line:
    {0, "$osDate",{state="value=&CalendarDate",trueAct={{"`cinemaSystem`","turnOn",""},{"`sonyTV`","pressButton,26","6"},{"`sonyTV`","pressButton,11","10"},{"Foci EB","sendPush,3370","Hamarosan kezdődik a &Calendar , bekapcsoltam a TV-t!"}}}},
    the osDate format is the Lua date/time %c.  i.g. = "Mon Jan 11 15:41:07 2021"
    Is &CalendarDate has same format?
    Could you post &CalendarDate value, I mean how it looks like?
    Edited by cag014
    Is &Calendar has same format?
    Could you post &Calendar value, I mean how it looks like?
    Yes it is.
    Edited by SmartLifeSystems
    5 hours ago, SmartLifeSystems said:
    Yes it is.
    Found the problem with CalendarDate... the resolution in this format is a second!, which can not be used in AOQ therefore have created a new keyword w/o seconds
    $actDate. Same date format but no seconds - resolution of one minute)
    Download attached version....
    Please change as following
    1. CalendarDate variable:
    fibaro.setGlobalVariable("CalendarDate",tostring(os.date("%a %b %d %H:%M %Y",e.startDate)))
    2. jM line:
    {0,"&CalendarDate",{state="value=$actDate",truAct..................}}},
    Regrading
    {0,"&Calendar",{state="value==Hungary", truAct......}}}, it does work. Could you please post the debug window (like below)
    Edited by cag014
    12 minutes ago, cag014 said:
    Megtalálta a CalendarDate problémáját ... a felbontás ebben a formátumban egy másodperc !, ami nem használható az AOQ-ban, ezért új kulcsszót hozott létre másodpercek nélkül
    $ actDate. Ugyanaz a dátumformátum, de nincs másodperc - egy perc felbontás)
    A mellékelt verzió letöltése ....
    Kérjük, változtassa meg a következőket
    1. CalendarDate változó:
    fibaro.setGlobalVariable ("CalendarDate", tostring (os.date ("% a% b% d% H:% M% Y", e.startDate))
    2. jM vonal:
    {0, "& CalendarDate", {state = "value = $ actDate", truAct ..................}}},
    Átminősítés
    {0, "& Calendar", {state = "value == Hungary", truAct ......}}}, működik. Feladhatnád a hibakereső ablakot (mint alább)
    I changed in the Calendar QA to your code. That is working fine, but I have got from the AOQ an error message.
    Please download the new version...9.8
    So, the $actDate is working fine. But here is my test line, and the value==Hungary is don't. No error message. What did I wrong?
    {0, "$actDate",{state="value=&CalendarDate",trueAct={"Teszt","sendPush,3370","Hamarosan kezdődik a &Calendar , bekapcsoltam a TV-t!","{&Calendar:value==Hungary}"}}},
    Ooops, it's misunderstanding... the "==" works as part of state not as a part of conditions....
    Let me try to implement that in conditions as well.
    @SmartLifeSystems
    Attached version should compare part of value in conditions also.
    Let me know if your jM line now  works
    Edited by cag014
    @SmartLifeSystems
    That's great! Working fine.
    If you don't anger, I repaired the \n problem in the push notifications. In the v9.9, every space vice was the \n characters.
    Hi @cag014, have any solution, code in the AOQ for example for the $actDate-20minutes?
    Could you please provide more info what exactly do you need?
    Is it related to &CalendarDate?
    Edited by cag014
    Yes. For example the &CalendarDate-20 min, turn on the TV.
    My suggestion is to shift the &CalendarDate -20 minutes.
    fibaro.setGlobalVariable("CalendarDate",tostring(os.date("%a %b %d %H:%M %Y",e.startDate-1200)))
    in case you need &CalendarDate for other purposes, just define new variable like &CalendarTime
    fibaro.setGlobalVariable("CalendarTime",tostring(os.date("%a %b %d %H:%M %Y",e.startDate-1200)))
    Edited by cag014
    Nice, thank you very much!
    @cag014, I have an another noticed. I think the lastModified command don't working.
    There is no  lastModified, you mean lastBreached ?
    Sorry, I mean valueModified.
    Have teste and works fine....
    Any specific example?
