    The attached version has an option to set actions based on users/mobiles GPS location.
    Please see GPS user guide.
    In addition the state definition has a default property "value" and not required in jM line. For example:
    Standard format:
    state="value=true"
    state="value>10"
    New optional format
    state="true"
    state=">10"
    This new format available for property "value" only. For any other properties, use standard syntax.
    Standard format is supported also.
    Edited by cag014
    1 hour ago, Rover said:
    This jM lines was triggert: {0,"`VoordeurSwitch`",{trigAll=true,trigAct={{"VoordeurSwitchHC3","sendEmail,2","@`VoordeurSwitch`>sceneActivation"}}}},
    but I was not aware that besides the desired sceneActivation triggers like  {0,"`VoordeurSwitch`",{state="sceneActivation=`But1Release`",trueAct={
    also a trigger batterylevel could occur. Why? the trigger was 92 (and the VoordeurSwitch has 92% batterylevel indeed), but why a trigger?
    Yes, in case no state defined then trigAct{} will be executed on any received value of any property. This feature designed to check device activity to verify it's not stuck.
    It looks like HC2 scenes still influences now HC3 devices, while all HC2 devices have gone to non configured after the migration to HC3.
    It is sure because the battery check scenes of HC2 are still functioning.
    Hi cag014,
    I want to thank you for GPS option, works excellent.
    But it doesn't support HC2 slave users and their location (works for HC3 only).
    Any Idea how to do it on HC2?
    To my opinion it will be very confusing to support slave's GPS because it could have same users, same places and you'll never know who is the user? I mean in which controller.
    But I have upgraded the AOS for HC2 to support geo-fencing also and you can run AOS on HC2.
    Currently AOS has been released and waits for Fibaro's approval.
    Let me know how it works on AOS?
    {0, "$24clock",{state="value=02:55", trueAct={
    {"$lineId","setTimeSlot","?3:00+(random(0,`RandomMaxTijd`)*60)?~","{$24clock:value=02:55}"},
    did not function this night, also
    {0, "$24clock",{state="value=04:00",initOnStartup=false,lineState={"if {&XRaamGloriaLamp:value=start}"}, trueAct={
    did not function. Why?
    [30.12.2020] [23:55:11] [TRACE] [AOQ372]: 9.3jM{74} T$24clock[23:55] => setTimeSlot,01:35~'{$24clock>HitteBijkeuken)  {$24clock:value=23:55}
    but no $24clock activity later also not at fixed time 04:00 while lineState value was valid.
    HitteBijkeuken is number 74 (cosmetic error I think).
    Don't see any problem with that, is it worked tonight ?
    Yes, it has worked tonight.
    Happy New Year cag ?
    Keep up the good work ?
    Happy new year to all....
    {$24clock>HitteBijkeuken) ?
    {$24clock:value>HitteBijkeuken}
    No, the jM line was:
    {0, "$24clock",{state="value=23:55", trueAct={
    {"$lineId","setTimeSlot","?00:00+(random(5,120)*60)?~","{$24clock:value=23:55}"},
    Result in Debug screen:
    jS2n: HitteBijkeuken="74"
    Today:
    Edited by Rover
    Today:
    Beside strange message in debug window ( I'll see what the problem is), is it works.
    What do you see in HCwebEye in timeSLot column?
    Yes it works! Like I said before it is a cosmetic "problem".
    {"`XRandomLichten`","setGlobal","stop","{$24clock:value>02:59}"}, --{"RandomLichten","sendEmail,2","Stop","{$24clock:value>02:59}"},
    {"`RandomLichten`","turnOff","{$24clock:value>02:59}"}}}},
    and
    {"Randomlichten","sendEmail,2","Randomlichten uit tussen 3:00 en 4:00"},}}},
    and
        {"`RandomLichten`","turnOff","if {&Lichten:value=Uit}"},{"`XRandomLichten`","setGlobal","stop"},}}},
    did not function again this night.
    Common functionality: $24clock.
    Hi @cag014,
    How can I set the next lines in one line? This lines doesn't work accurately, sometimes all the three lines run, but only the proper should.
    Thanks!
    {0, "$24clock",{state="value=18:00",timeSlot="w=1",trueAct={"&AttilaWork","setGlobal","Afternoon","{&AttilaWork:value=Night}"}}},
    {0, "$24clock",{state="value=18:00",timeSlot="w=1",trueAct={"&AttilaWork","setGlobal","Day","{&AttilaWork:value=Afternoon}"}}},
    {0, "$24clock",{state="value=18:00",timeSlot="w=1",trueAct={"&AttilaWork","setGlobal","Night","{&AttilaWork:value=Day}"}}},
    6 hours ago, SmartLifeSystems said:
    Hi @cag014,
    Thanks!
    Sometimes all the three lines run? It should run all of them all the time...
    Please take in considerations that hour =18:00 lasts for one minute! So during this minute the state will constantly changes between these lines.
    Could you please elaborate what you're trying to achieve....?
    By the way please see $dayTime user Keyword as defined in user_data.
    userKeyWord={{"$dayTime"},
        {function() return  os.date("*t",os_time()).hour<6 and "Good night," or os.date("*t",os_time()).hour<12 and "Good morning," or os.date("*t",os_time()).hour<18 and "Good afternoon," or os.date("*t",os_time()).hour<=23 and "Good evening," end}}
    You can remove word Good or to chnage the string to wht you need.
    Edited by cag014
    and
    and
    Few questions
    1. The second part (marked red) belongs to what?
    2. Are you sure the {&XRaamGloriaLamp:value=start} condition is true? Maybe add debug command at this time to verify the condition.
    3. Is it runs on HC3?
