10 hours ago, cag014 said:
Have teste and works fine....
Any specific example?
Yes, here is the example.
{0, "$24clock",{state="value=18:00",timeSlot="w=1",trueAct={"&AttilaWork","setGlobal","Afternoon","{&AttilaWork:value=Night|&AttilaWork:valueModified>180}"}}},
    Correct, was an error using GV for modified time.
    Attached version includes your fix (no "\n"  in push notifications.)
    Is anyone uses GPS location actions?
    It seems that Fibaro has some delay on user location update... but overall works fine.
    Is it possible this version is the 9.9?
    The \n problem is solved.
    Edited by SmartLifeSystems
    Yes. I use GPS location.
    It works well for me. I don't see any delays at the moment.
    Yes, I use. But I think not the delay the problem, I think the radius more than 150m.
    The radius works fine for me... but again could be up to few minutes delay. What problem do you see?
    Another interesting issue, that iPhones somehow stop to report and you need to restart the application again.
    No... this is the v10.0
    I will try the app restart. What I see, I have set the radius to 150m, but for example sometimes, when I arrive to home, it senses earlier when I enter the circle. But it is not problem for me, because I set some delay for the gate opening.
    Did you manage to run v10.0?
    I think the location accuracy depends on your phone setup (Fibaro's app just gets the data). Try to use all available options to improve it  (like Wi-Fi, Bluetooth scanning and etc)
    The GPS location feature works fine on HC3, but I do see some delays at HC2 and HCL using old application.
    For next days will try to use Home Center new app with HC2 and HCL
    I think you need to uninstall the old app from the phone while using new app. or it could be an interesting idea to run both applications and to see if GPS performances better.
    Edited by cag014
    So I was the stupid. Working fine.
    {0,"`VoordeurSwitch`",{state="sceneActivation=`But4Double`",trueAct={
        {"&BelhoornActief","setGlobal","Ja;else;Nee","{&BelhoornActief:value=Nee}"}}}},
    {0,"&BelhoornActief",{initOnStartup=false,state="value=Ja",
        trueAct={{"&Statuslicht","setGlobal","BelhoornActief"},{"VoordeurSwitch","sendEmail,2","Belhoorn Actief"}},
    {0,"&Statuslicht",{initOnStartup=false,state="value=BelhoornActief",trueAct={ --=====Belhoorn actief
        {"`StatusLEDs`","setColor,255,255,255,0","0.5"}}}}, --WIT
    So I push a switch, after 13 seconds a GV has been set and 15 seconds later the light has been set because of the changed GV. Where did all these delays come from?
    Edited by Rover
    I think this is my bad... if you remember have added extra trigger for $24clock and disabled the standard refreshState trigger.
    Anyhow try attached version (both triggers in place)
    in addition:
    1. Added an option to skip time-span definition when not required.
    Standard format:
    {0,"DevID", {state="value=true", truAct{…}}},
    New optional format
    {"DevID", {state="value=true", truAct{…}}},
    A lot of crashes at HC2:
    And more. As I understood this due to changes in the sensors, but I did not add or remove any devices at this time
    in addition:
    Standard format:
    New optional format
    onInit not present in v10.1
    {"Voordeur","sendEmail,2","Voordeurstatus: @`Voordeur`>value"},
    `Voordeur` is a AEON DW-sensor.
    Why is @`Voordeur`>value" presented as "0" and not as "false"?
    Edited by Rover
    Ooops,
    Now everything there
    All crashes related to api.get() from HC2... looks like HC2 doesn't response well to API commands.
    Please reboot HC2.
