On 2/11/2026 at 11:36 AM, cag014 said:
Do you mean different behavior depending on how the light was turned on — whether it was activated by motion or switched on manually?
Yes, that one.
On 2/28/2026 at 1:52 AM, Rover said:
Yes, that one.
I have found it:
    BTW, if you're using latest AOQ, you can identify if the switch turned on/off manually.
    See 🔍Detecting Manual Switch Activation (Physical Source Type) section in AOQ user's guide
    for example,
    {"`light`",{state="true",trueAct={"`light`","turnOff","1800;else;30","{`light`:srcType=physical}"}}}
    • 3 weeks later...
    for example,
    Is AOS getting the same function?
    In the next release
    • 2 months later...
    I am using now AOQ version 21.8. What is the last version?
    Edited by Rover
    the lates released version is 22.0
    New version coming in the next few days! It includes device activity monitoring (ZWave, ZigBee...) to help make your hub rock-solid.
    Edited by cag014
    Hi cag! I uploaded version 22 and since then the geolocation is not working properly. When I arrive home or any place, I first get a notification about arriving home, then leaving, and finally arriving home again, but sometimes, when I arrive home, I get a notification about arriving home and then leaving home. It's annoying because I use geolocation to arm and disarm the alarm system, and even if we're at home, the alarm is armed because of it. Do you have any idea what the problem could be? Thanks!
    [2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{265} $geoAction[enter]  skip setGlobal{&Noncsi}  if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{260} $geoAction[enter]  skip sendPush{GPS}  if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{257} $geoAction[enter]  sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{266} $geoAction[enter]  skip setGlobal{&Noncsi}  if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{264} $geoAction[enter]  skip setGlobal{&Attila}  if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{263} $geoAction[enter]  skip setGlobal{&Attila}  if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{258} $geoAction[enter]  skip sendPush{GPS}  if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{259} $geoAction[enter]  sendPush(Noncsi,Attila) 'GPS','Attila leaves Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}  $geoAction[enter]  skip turnOff{leaveHome}  if not {leaveHome(false)=true}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}  $geoAction[enter]  skip turnOff{everybodyLeaveHome}  if not {everybodyLeaveHome(false)=true}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{265} $geoAction[enter]  skip setGlobal{&Noncsi}  if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{257} $geoAction[enter]  sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{263} $geoAction[enter]  skip setGlobal{&Attila}  if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{258} $geoAction[enter]  skip sendPush{GPS}  if not {$geoLocation(Feri papa)=HC3-00003966}
    152
    Edited by SmartLifeSystems
    What version you've used before?
    If you rollback the previous version, is it works, OK?
    By the way I didn't change anything in the code. The geolocation trigger comes for mobile application, not generated by AOQ.
    In addition, I do have same issue.
    Interesting what Fibaro team has to say about it?
    @m.roszak any idea why it happens?
    Edited by cag014
    The only reason would be that phones actually sends the events about arriving and leaving - and as we know, its a bit out of our hands - its based on the API of apple/google.
    I would try changing the radius definition of the point in location to something higher as a debug step.
    I have no problems with geofencing with AOQ, using an iPhone 14 Pro.
    Hi! I restored version 20.8 and it is working properly again. I use an Iphone 12 ProMax and an Iphone 16. Both had the same problem.
    Don't understand that, the Geofence code is exactly the same.
    I don't understand either, I didn't even suspect it at first. But when I reinstalled version 20.8, it worked again as before and everything is fine.
    Hi @cag014,
    Using v22.0:
    {5,"943",{state="value=false", onClock=true, initOnStartup=false, timeLoopAct={{"945","turnOn"}, {"945","turnOff",30}}}},
    produces a timeloop while state="false":
    It does not matter if state = "false"or "true", the looping is going on. This should be different according to the Advanced User Manual.
    Indeed, some issue with the onClock=true.
    Meanwhile remove onClock=true. Should work while fixing the bug
