    Strange works fine for me.
    Regarding the Edge, did you use the command line as described in DISABLE CORS doc? I mean running Edge with disable security option?
    No, I did not, but the Allow CORS extension in Edge shows that CORS has been disabled.
    1 hour ago, Rover said:
    Above you can see that I had already added a port number, what is working in Firefix with webeye 3.0, but not with webeye 4.0 (not implemented 501).
    No, I did not mean this debug information, but all the reporting lines of a working webeye.
    And the centered layout of the reporting lines is not very conveniant (was also in webEye 3.0), please put the reporting lines to the left.
    Edited by Rover
    in Edge CORS extension doesn't work
    Run Edge according to the doc
    "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --user-data-dir="C:\EdgeDevProfile" –disable-web-security
    Could you please post what lines we're talking about?
    I mean this kind of lines:
    but as you can see, this time the lines have been lined out to the left :-), but mostly they are centered :-(.
    Now I confused, these lines displayed in HC2 debug console, why you need them in webEye?
    The advantage of webEye is a full screen of the debugging lines, while the HC2 debug console shows a very small part of each line and the display time of the lines is very short.
    The webEye lines are visible as long as I do not Reload. But I want to have these lines visible over a longer time at all, also after Reload in webEye.
    Ok, now I see what do you mean.
    Please update your AOS with attached file
    This version includes many features as AOQ.
    Change-log:
    devPrt
    $stateTime
    timer
    $onTimer
    else
    operator
    setTimer
    setCondition
    Currently I'm working on documentation for that, but all above features could be reviewed in AOQ user guide (they are 99% percent the same)
    Regarding to keep debug lines for a long time, you need to change global
    tblRefresh  = 300 -- (seconds) table view refresh rate. 0-disable
    By setting to 0 (disable auto refresh) you can keep debug lines forever !!!  But no updates for the data table.
    Another option is to set for a few days
    tblRefresh  = 172800 (two days)
    At any point you can refresh the data table at scene, but the debug lines will be cleared.
    Edited by cag014
    Change-log:
    devPrt
    $stateTime
    timer
    $onTimer
    else
    operator
    setTimer
    setCondition
    Installed
    On 9/26/2025 at 5:51 PM, cag014 said:
    Sorry, version in progress... thanks for pointing out on that.
    AOS does not support number of global variables in one line for setGlobal
    You need to update them one by one.
    Does version 11.0 support it?
    Not yet
    • 3 weeks later...
    Is HC3 version 5.190.38 without problems with AOQ v20.8?
    Yes, works fine
    By the way regarding your question to update several global variables in HC2, you can do it using HC3 where HC2 defined as a slave hub
    Edited by cag014
    On 10/31/2025 at 9:09 PM, cag014 said:
    Yes, works fine
    Did not you make a comment in the HC3 forum that Geofencing does not work in 5.190?
    And the periodic restarts?
    Edited by Rover
    Yes, I did
    Why?
    On 11/8/2025 at 11:20 PM, cag014 said:
    Yes, I did
    Why?
    That means that the Geofencing with AOQ in 5.190 does not work and that AOQ restarts periodically also. That is not what I want.
    Edited by Rover
    The geofencing malfunction and periodically restarts reported by many users - regardless of AOQ
    This is not an AOQ problem, but looks like the new version issues
    Edited by cag014
    So better not updating HC3 to 5.190.38 if you want to use geofencing?
    There are some users reporting that Geofence is working...
    Up to you
    • 4 weeks later...
    Hi @cag014,
    I had a shocking experience:
    The house of my son and has family is fully automated for lights and security by means of a HC2 driven by an AOS scene (written and managed by me). Of course a make mistakes in writing AOS lines and then a debugging  error has been shown, but the operational scene is running for years when it is without errors from my side.
    At the moment we are visiting my sons family and they wanted to turn on the lights of the room by means of a wall switch coupled with AOS. But it stayed dark...
    I had a look in the debugging lines of AOS and I saw that the system was blocked (not crashed and rebooting) showing the next error line:
    (empty spoiler}
    [DEBUG] 15:05:46 2025-12-11 15:05:46.519409[ fatal] LUA error:/opt/fibaro/scenes/451.lua:1807 attempt to perform arithmetic on a nil value
    After this line blocked and empty.
    Please repair this severe security problem.
