Hi @cag014
I can confirm this now working and working a treat!! Thanks very much for this.
I do have another question.
I have a mix of Fibaro RGBW controllers 1st and 2nd gen and use these more than I use lights.
Could you please give an example how I can have these turn on when motion is detected and a global variable TimeOfDay is set to night rather than day. I have 2 block scenes that changes the global variable to night when a Fibaro sensor detects that the Lux drops below 150 and another for when when the Lux is above 250 and set the variable to Day. There is probably a way I can do this with your scene but not to sure how to. And I know the version 1 and 2 RGBW's are totally different the way they work and need controlling.
I have tried the below just for a test going on what I heave learned so far for RGBW version 1 and this is not working: -
Thanks once again,
Hal
Edited by Hallamnet
Hi @cag014
when you will replay to my messages about VMC ?
regards
  • 4 weeks later...
Hello someone here can help me on this code:
--========================== USER CONFIGURABLE PARAMETERS ===============================
gpsDevice={["999"]="UserName",["9999"]="skip"}
--=== jSon Parameters to number
jP2n={ outTempLim=25, homeTempLim=23,humLim1=65,humLim2=81,
     vmc1=20,vmc2=25,vmc3=55,vmc4=60,vmc5=95,vmc6=99}
--=== jSon String to name
jS2n={qubino=1147, ktLT=554, bathLT1=56, bathLT2=62, bathLT3=347, bathLT4=207,
bathHum1=51, bathHum2=66, bathHum3=143, bathHum4=213,
outTemp=3,homeTemp=365,
--=== jSon Main actions table
jM={
{5,"`qubino`",{state="`vmc1`",lineState="if{$24clock:value=21:00~06:59} or {$24clock:value=12:00~13:59} or {`outTemp`:Temperature>`outTempLim`}",
       timeLoopAct={"`qubino`","setValue,0"}}},
{5,"`qubino`",{state="`vmc2`",lineState="if {`bathLT1`,`bathLT2`,`bathLT3`,`bathLT4`,`ktLT`:valueModified>180}",
      timeLoopAct={"`qubino`","setValue,`vmc1`;else;setValue,`vmc3`","if{$isFalse:value=?@`bathLT1`>value+@`bathLT2`>value+@`bathLT3`>value+@`bathLT4`>value+@`ktLT`>value?}"}}},
{5,"`qubino`",{state="`vmc3`", lineState="if {`bathLT1`,`bathLT2`,`bathLT3`,`bathLT4`,`ktLT`:valueModified>180}",
      timeLoopAct={"`qubino`","setValue,`vmc1`","if{$isFalse:value=?@`bathLT1`>value+@`bathLT2`>value+@`bathLT3`>value+@`bathLT4`>value+@`ktLT`>value?}"}}},
{5,"`qubino`",{state="`vmc4`", timeLoopAct={"`qubino`","setValue,`vmc3`","if {`bathHum1`,`bathHum2`,`bathHum3`,`bathHum4`:value<`humLim1`}"}}},
{5,"`qubino`",{state="`vmc5`",timeLoopAct={"`qubino`","setValue,`vmc4`","if {`bathHum1`,`bathHum2`,`bathHum3`,`bathHum4`:value<`humLim2`}"}}},
{30,"`qubino`",{state="`vmc6`",timeLoopAct={"`qubino`","setValue,`vmc5`","if {`homeTemp`:value<`homeTempLim`}"}}},
{"`qubino`",{initOnStartup=false,state="value=300",lineState="if {`homeTemp`:value>`homeTempLim`}",timeSlot="true22:00, false06:45",
      trueAct={"`qubino`","setValue,`vmc6`"},falseAct={"`qubino`","setValue,`vmc5`"}}},
{"`qubino`",{initOnStartup=false,state="value=300",lineState="if {`qubino`:value<`vmc2`}",timeSlot="true07:00, false12:00",
      trueAct={"`qubino`","setValue,`vmc1`"},falseAct={"`qubino`","setValue,0"}}},
{"`qubino`",{initOnStartup=false,state="value=300", lineState="if {`qubino`:value<`vmc2`}", timeSlot="true16:00, false21:00",
      trueAct={"`qubino`","setValue,`vmc1`"},falseAct={"`qubino`","setValue,0",}}},
{"`bathLT1` and `bathLT2` and `bathLT3` and `bathLT4` and `ktLT`",{lineState="if {`qubino`:value<`vmc3`}", state=">0",
      trueAct={"`qubino`","setValue,`vmc2`"}}},
{"`bathHum1` and `bathHum2` and `bathHum3` and `bathHum4`",{ trigAll=true, state=">`humLim1`",
      trueAct={"`qubino`","setValue,`vmc4`;else; setValue,`vmc5`","if{`bathHum1`,`bathHum2`,`bathHum3`,`bathHum4`:value<`humLim2`}"},
falseAct={"`qubino`","setValue,vmc3","if {`qubino`:value=`vmc3`~`vmc6`}"}}},
{0, "$RAM",{state=">85",trueAct={{"RAM>85%","sendNote","Warning. \nSystem memory is $RAM% ",true},{"|$lineId|","setStateValue","80"}},falseAct={{"|$lineId|","setStateValue","85"},{"RAM<80%","sendNote","System memory is $RAM%"}}}},
{0, "$HC2onLine",{state="true",trueAct={"","tts","$dayTime, Home center is on line","{$24clock:value=?$sunriseHour+7200?~?$sunsetHour+3600?}{$24clock:value=?$sunsetHour+3600?~?$sunriseHour+7200?}"},falseAct={"","tts","$dayTime, Home center is off line"}}},
{0, "$internet",{state="online",trigAct={"","tts","$dayTime, Internet is $internet"}}}, ics
Regards
Hi no one can help me on this code ?
Very thanks
Hi
This thread is dead ?
Hi @cag014,
I have a problem with the timer function:
{"`CVketel`","turnOn"}, {"`CVketel`","turnOff","timerCVketel,?60*60?","if {`Thermostaat`:heatingThermostatSetpoint < @`TempThermostaat`>value}"},
results in:
[18.11.2023] [09:25:20] [TRACE] [AOQ387]: jM{9}T   Portable;283:Port Switch[2.Pressed] ➯ turnOn{CVketel)
[18.11.2023] [09:25:20] [TRACE] [AOQ387]: jM{9}T   Portable;283:Port Switch[2.Pressed] ↪ skip turnOff {CVketel}  if not {Thermostaat(19.0):heatingThermostatSetpoint<18.5TemperatuurHuiskamer:832>value}
I want to execute the condition after the delay from the timer and not immediately. What is wrong?
Hi @cag014,
What is going on? Are you O.K.?
    Hi to all,
    Lately have been extremely busy and have endless business travels.
    I am back day after tomorrow and will try to answer all topics.
    On 11/18/2023 at 12:53 PM, Rover said:
    Hi @cag014,
    results in:
    Please post related JM lines
    11 hours ago, cag014 said:
    Hi to all,
    Hi @cag014, good to see your reaction 😅.
    The related jM lines have been shown in the black line above.
    On 11/28/2023 at 10:53 PM, cag014 said:
    Hi to all,
    As You can see the condition of the turnOff command is false, that's why the timer doesn't start.
    Exactly what the problem is. The condition should be active after the timer delay and not immediately.
    Hi @cag014,
    After moving the jS2n line
    Kerstverlichting="`Kerstboom`|`OmasKast`|`Kookeiland1`|`Kookeiland2`|`Kerstwaterval`|`Hernhuters`|`Vensterbanklicht`",
    in file user_data to another file, the error shows not finding alias `Kerstverlichting`, while in the list of available aliases `Kerstverlichting` is present ?!?
    If the jS2n line is present in both files (or only in file user_data) then there is no error notification.
    The condition of the line is not for the timer but for the command therefore the condition active for the timer also.
    Don't know what version you are using, but there is a setTimer command to set/modify the timer condition or duration.
    Please try as below:
    Edited by cag014
    Hi @cag014,
    [07.12.2023] [17:15:55] [TRACE] [AOQ387]: jM{1}F   Hal;44:Beweging Hal[false] ➯ turnOff{GIA)
    [07.12.2023] [17:53:09] [DEBUG] [AOQ387]: Gathering information...32611
    Why has the AOQ initiated without a crash error notification?
    On 12/7/2023 at 7:24 PM, Rover said:
    Hi @cag014,
    There are so many errors could be done in jM lines, so it is impossible to simulate and catch all of them.
    Do you know what has been changed in user files that causes this problem?
    No, I have made a lot of changes in the last period.
    But a QA crash should be notificated anyhow with or without indicated reason.
    Not in HC3. Some LUA code errors (like in tables or json commands when values are nul) are failed with no error descriptions.
    Happens a lot...
    On 12/5/2023 at 10:58 AM, Rover said:
    Hi @cag014,
    Hi @cag,
    How to solve this?
    On 12/19/2023 at 11:50 AM, Rover said:
    Hi @cag,
    How to solve this?
    Unable to recreate the error.
    Could you please post the jS2n table you are using?
    The last line shows the alias of Kerstverlichting.
    When I move the jS2n lines to the jS2n={ table in the main file: no problems.
    Put also attention to the second last line: 2=Kerstwaterval=579 ?!?
