    On 4/24/2023 at 10:31 AM, Rover said:
    Hi @cag014,
    sendEmail disabled by default to avoid sending emails or notification on each startup.
    To enable this, please add true (Boolean) at the end of the command in the tables (trueAct, falseAct and etc.)
    trueAct={{"Apparaten Aan","sendEmail,2","Stroomprijs: @`zonEnergie`>userDescription",true},
    By the way you can define initAct{} table, in this case any command in the table is executed on startup.
    Please use latest version 16.7(posted in this topic)
    Edited by cag014
    What to do to decrease the API POST time? It is high already for a long time.
    I have some Elero blinds in place and when I add them to my config, the log displays the following error:
    (35) Item ID 25 not found in the system.
    There also seems to be an issue with sunset/sunrise. Potentially following line leads to errors in the logs:
    [09.05.2023] [08:51:06] [ERROR] [QUICKAPP98]: main.lua:839: attempt to index a nil value (field '?')
            timeSlot="?$sunsetHour-(60*60)?~?$sunriseHour+(60*60)?",
    1. Are you sure you have device id 25? Could you please post the device API data?
    2. timeSlot works just fine, no issue found. Please post the entire line...
    2 hours ago, Rover said:
    Honestly never happened in my HC3. Could be CPU load, did you try to reboot?
    On 4/29/2023 at 10:34 AM, Rover said:
    I looks like there is still a problem:
    Hi @cag014, can you solve this?
    Don't follow you, what delay you're talking about?
        {"`NEST21`", '+NEST21',"if {&Verwarming:value=19} or {&Verwarming:value=21}"},
        {"`NEST19`", '+NEST19',"timerHeatOn,900","if {&Verwarming:value=19 and &Huisstatus=Thuis and `gasPrijs`:value>&cheapGas}"},
    The execution of the second line should be postponed for 15 minutes (the timer function), but it has been executed right after the first line showed:
    [29.04.2023] [09:00:42] [TRACE] [AOQ387]: jM{10}T  &SwitchScene:Global[Disarm] ↪ NEST21{NEST21) if{&Verwarming=19} or {&Verwarming(19)=21}
    [29.04.2023] [09:00:42] [TRACE] [AOQ387]: jM{10}T  &SwitchScene:Global[Disarm] ↪ NEST19{NEST19) if{&Verwarming=19 and &Huisstatus=Thuis and gasPrijs(1.1)>0.8&:cheapGas}
    After reboot HC3. Still pretty high isn't it?
    41 minutes ago, Rover said:
    3 hours ago, Rover said:
    Could the existance of some dead devices cause these slowness?
    Once the dead device detected the system suspends any communication with the device, but if somehow the code or user wakes up the device, it will resume the communication and will slow the system.
    Worst case scenario, that you have devices that sometime dead and wakeup over and over.
    The bottom line please do not wake up dead device, unless something has been done to solve the problem.
    Sorry, very stupid typo error , my bad
    Try attached
    The devices Licht1 and Licht2 are Fibaro wall switches. They are not always in the wall (Christmas light), but I want them working when put in the wall.
    Try attached
    It works! Thanx for the repair Cag.
    On 5/11/2023 at 3:30 PM, Rover said:
    AOQ will try to wake up any dead device that included in the jM lines to maintain proper control of the automation.
    If your device is dead occasionally, I suggest to solve the problem somehow. May be to add Zwave repeater or to use ZigBee wall switch, which has better coverage (based on my experience)
    If your switch in use for Christmas only, it might be a good idea to remove it from jM configuration when not in use. You can suspend the line w/o actually to delete it, so in the future you don't need to recall how it was configured.
    Edited by cag014
    It is nice that AOQ tries to wake up any dead device. But if you deliberately remove a wall switch, it should not wake up.
    Removal from jM configuration when not in use is a very poor solution with a WAF of 2 points. Christmas time: "the Christmas lights are not functioning, can you repair this?", "Yes dear, I have to change the programme." 😟
    Better solutions than removal from jM configuration:
    1- Wall switches are not waked up.
    2- Devices are not waked up by: jS2n: Kerstboom="62",notWakeup
    3- AOQ PARAMETERS: notWakeup = 62,316,398 (3 deviceID's)
    Hi, here are my replies:
    1. yes, this is the ID of the blind, json attached:
    /monthly_2023_05/image.png.401d947aff75f1d87f30954e35923115.png" />
    2. perhaps this is related to bad timnig? I have a movement sensor that switches on the lights in defined times. Issues seems to arise when switching off is scheduled to happen after this slot.
        {"`motionSensor`",
            {state="true",
            trueAct={"`light`","turnOn"},
            falseAct={"`light`","turnOff", "timerLight,90"}}},
        {"`motionSensor`",
            {state="true",
    Is it nice device?
    So, you want to be able to define list of devices that should be skipped during the wake-up process? You do understand that the devices that are dead won't respond to the commands? In other words, AOQ won't be able to operate correctly with these devices!
