On 7/18/2023 at 9:50 PM, cag014 said:
Yes, the solution is trickier rather than complicated:
Please define necessary components (as an example or just use it)
global4local={false,gVarName="",varArray={pwrMode="init:idle"}} -- define local variable pwrMode
jS2n={MS1=430, MS2=345, lightSw=500} -- that's an example, please replace that with your real sensors and switch names and IDs
When one of the sensors detects motion, the lights turned ON and will be turned OFF 3 minutes after sensors back to safe. (Please change 180 seconds to your desired time)
 Now the tricky part. If you want to switch the lights manually, just make sure the lights are OFF (if the lights are ON, turn OFF by switch) and then turn the switch ON.  The lights will stay on until turned OFF by switch or after 2 hours (as you mentioned if the user forgot to switch it OFF). You can change the 7200 seconds to any other value.
In any case you need to make sure to turn OFF the lights, before it could be turned ON by switch (to set the &pwrMode to "idle")
This scenario works fine on latest AOQ 17.2 Please download attached version before running.
This version will be released "officially" in a few days.
Hi @cag014,
After installing v17.2 next debugging info showed up, even with dbgInfo =false.
How to stop this reporting?
    7 hours ago, Rover said:
    Hi @cag014,
    Oops, my bad...
    Please download attached:
    14 hours ago, cag014 said:
    Oops, my bad...
    TNX for the quick repair cag!
    I have used this solution with a Fibaro dimmer and a Fibaro motion sensor. The latter can be configured to have a delayed true -> false for f.i. 3 minutes, so an extra timer is not necessairy. For a dimmer has the triggering to be changed from state="true" to state="value<>0".
    Looks good, just change the timerLight,-1 to timerLight,x
    Edited by cag014
    @Rover
    By the way there is another new feature in this version.
    If you have too many lines in jM table (like I do), it is very difficult to find the line you want to change (at least it takes some time to found it), now you can open new files after user_data for specific scenarios.
    In example below I have added Boiler file for jM lines that taking care of boiler commands.
    Please note to add lines of the new files use:
    jM[#jM+1]={....................................}
    Very helpful concept to maintain jM lines. You can add files as you need.
    During the startup you'll should see a message that the lines of the new files are added - like that:
    [19.08.2023] [00:30:00] [DEBUG] [AOQ101]: loading jM from boiler file(s)...
    On 8/20/2023 at 4:28 PM, cag014 said:
    @Rover
    2 hours ago, Rover said:
    Hi @cag014,
    Indeed a very nice feature!
    But not yet without problem.
    Addition of one file is working O.K., but adding a second one shows an error with only one JM line:
    Yes, this is a bug... thanks.
    Fixed...
    Hi @cag014,
    Now we know that it is possible to have more jM-blocks, is it also possible to have more jS2n{}-blocks in order to put a jS2n{}-block in a jM-block?
    In that way it is possible to isolate jM-lines with related device specifications. Then it is easy by commenting out dead (not present) devices, like not connected wall switches, and the related jM-lines.
    Then it would also be nice if:
    jM[#jM+1]={
    jM line 1
    jM line x
    so an empty jM-block, would be legal and not an error.
    Why you need to include jS2n block in jM...
    There is no problem to continue to send commands to dead devices (of course the hub doesn't send any commands, so no real actions executed).
    Could you post a real -life example?
    I have made myself not really clear: I do not want to include jS2n block in jM, but I should like to have a jS2n block + a jM block into one file.
    F.i. I do have a experimental configuration with a set of devices and jM-lines communicating with this devices. After removing this configuration I need to remove the experimental devices from the jS2n block and the experimental jM-lines from the jM block. When these devices and jM-lines are bound into one file, only outcommenting all text of the file will remove the experiment.
    OK,,, so you want in extra files to have jS2n table also in addition to jM table.
    Sounds good request.
    Will do it.
    Will do it.
    TNX! Could you also make it possible to have an empty effective content in the file?
    jM[#jM+1]={
    jM line 1
    jM line x
    so an empty jM-block, and jS2n-block, in the file would be legal and not an error.
    Or, a possibly impossible solution, to make an extra file active/inactive by choice.
    Edited by Rover
    jM[#jM+1]={
    jM line 1
    jM line x
    For empty entire jM block just do it as follows:
    M[#jM+1]={
    jM line 1
    jM line x
    @Rover
    Attached version includes the option to mark jM block as you requested. In addition, you can define jS2n and jP2n tables in your new files. Use same syntax as for jM lines
    jS2n[#jS2n+1]={newDev=100,....}
    jP2n[#jP2n+1]={luxLimit=100,....}
    Please take a look at attached user guide document also for more info about setTimer command.
    This version has a new feature, an option to set specific condition for specific device(s). Once this condition is set, it will be always verified when the command executed for this device regardless of other standard conditions.  See setCondition in the user guide.
    The first line in Advanced User Guide includes links to the newest features.
    Please also go through the document and read everything marked pink (background). There are some new minor features like dbgCalc debug level and etc.
    On 8/27/2023 at 11:58 PM, cag014 said:
    @Rover
    Very nice, cag! 👏
    • 3 weeks later...
    Hi @cag014
    I am new the HC3 and giving your app a try but having a bit of an issue with the below line. Trying to set it up so that the light will tun on with motion but only between 16:00 and 08:00 when motion is detected: -
    When it runs, I am getting this in the debug: -
    I have also setup the jS2n table with the below and cannot get it to pick up the name. Guessing i am typing in something wrong somewhere when I try.
    If you could please point out where i am going wrong on these, that would be ace!
    Also, on a separate note, I have a lot of RGBW strips using Fibaro RGBW 1 and 2 units and would like to find out how I can action the same as above but just with RGBW strips where only white would turn on.
    Any help would greatly be appreciated.
    Thanks,
    Hal
    Please notice that all commands and rules are case sensitive.
    instead, timeslot it should be timeSlot.
    Edited by cag014
    To use jS2n names you need to iclude the names within backquotes.
    {0, "`KitchenEBM`",{state="value=true",timeSlot="16:00~08:00",trueAct={"209","turnOn",""},falseAct={"209","turnOff","180"}}},
    Edited by cag014
    Thanks for the reply on this. i will give this a go when i get home.
    This was my bad for copy and pasting from your original post with the examples on: -
     Noted for the future and will check the case going forward.
    Thanks for your time on this and I will let you know if I need anything more.
    Thanks again,
    Hal
