    3 hours ago, Rover said:
    {"&tChangeScene","setGlobal","Arm timerArm,600","if {&tVertraagdWeg=Ja}"},
    The timer in this line does not function in AOS, but is accepted by AOS.
    Wat do I wrong?
    AOS version 9.6 does not support that. Just pure timer instead of delay - not supported when on the samel line parameter required.
    However, attached version V10.0 does (will be released soon)
    In order to keep your configuration, copy/paste new release into your scene from the line
    --=============== Copy/Paste form here to the end for a new release ===================
    to the end of the code
    Let me know if it works
    Edited by cag014
    jM:   {"&XVoorkamer|&XSerre","setGlobal","Stop"},
    result:
    [DEBUG] 15:18:12: Starting AOS - 10.0
    [DEBUG] 15:18:18: [ ] exception: /opt/fibaro/scene/451.jM hash table:19:
    {0,"$blank",{"state"="value=whatever","initAct"={{"&tVoorpoortAlarm","setGlobal","Uit"},{"&tAchterpoortAlarm","setGlobal","Uit"},
    {"&tBeveiliging","setGlobal","Uit"},{"&tAlarmKnipper","setGlobal","Uit"},{"&tAlarmstatus","setGlobal","Uit"},{"&tBlauwKnipper","setGlobal","Uit"},
    {"&tBlauwFlits","setGlobal","Uit"},{"&tChangeScene","setGlobal","Stop"},{"&tHuisstatus","setGlobal","Thuis"},{"&tVertraagdWeg","setGlobal","Nee"},
    {"&XVoorkamer|XSerre","setGlobal","Stop"}}}}
    (33) Global variable &XVoorkamer|XSerre or its value XVoorkamer|XSerre not found as global.
    What is wrong?
    In other lines with concatenated globals no problem at all...
    Edited by Rover
    Hi @cag014,
    The timer works 🙂
    [DEBUG] 17:19:18: Starting AOS - 10.0
    [DEBUG] 17:19:28: Arranging data table...
    26-Sep 17:19:17 AOSv10.0 AOS 9.6          sunHours 07:34~19:32    GMT +2
    Two versions at a time?
    Sorry, version in progress... thanks for pointing out on that.
    result:
    What is wrong?
    AOS does not support number of global variables in one line for setGlobal
    You need to update them one by one.
    Edited by cag014
    I got the idea that
    {"$blank",{state="whatever", initAct={
    is not working at all in AOS, I do not see any reporting of execution.
    I got the idea that
    What exactly you attend to do?
    $blank is a special placeholder with only one possible value: "blank".
    When you wrap $blank inside a time span definition, it becomes a scheduler:
    • The 20 means every 20 minutes.
    • $blank is used as the “device” to attach the loop to (state="blank" must be defined, any other value won't start the time loop)
    • timeLoopAct will execute on each interval tick.
    If you just declare $blank without a time span, its trueAct or falseAct or initAct will only run once at initialization (when the QA loads).
    If your goal is to run something only once at startup, you could use $initMode as a condition in statements "if{$initMode=true}"
    • Use $blank + time span → recurring interval actions.
    • Use $blank alone → runs once at init.
    • Use $initMode → explicit startup actions.
    I want to use $blank alone for → runs once at init. It was your advice on this forum at 11/15/21:
         The initAct={} has same format as trueAct={} or any other action.
         Since you probably don't have any specific device to set the jM line, so use $blank keyword
         {"$blank",{state="whatever", iniAct={"`sImplant`","<set relay command>"}}},
    I suppose that the iniAct commands are to be seen in the debugger text, but there is not one initAct action to be seen.
    initAct not iniAct   (should be init with t)
    Have tested that and it works
    Just now, cag014 said:
    initAct not iniAct   (should be init with t) : I know, it was your text
    Have tested that and it works : But why is nothing to be seen in the debug part?
    It shown in the debug console.
    jM line
    {"$blank",{state="whatever", initAct={"","tts","started"}}},
    debug console
    [TRACE] [AOQ32]: jM{1} $blank[blank]  tts{"started"}
    jM line
    debug console
    Yes, I see it now.
    TNX cag
    Edited by Rover
    • 3 weeks later...
    New
    has been released.
    Edited by cag014
    Hi @cag014,
    I know you have posted once an AOQ or AOS icon, but I cannot find it.
    Could you please post it again?
    8 hours ago, cag014 said:
    New
    has been released.
    Works for HC3 in Firefox.
    in Edge:
    Did you disable the CORS?
    Please follow instructions in DISBALE CORS user guide
    2 hours ago, Rover said:
    Hi @cag014,
    The icons aoqon and aoqoff are in download section of the AOQ.
    Edited by cag014
    Yes, I have disabled the CORS. The HC3 in
     on Firefox is working, but not the HC2 ("not implemented"). Maybe the port addition to the IP-address is a problem.
    By the way, with
     3.0 the HC2 with the same IP-address with port is functioning O.K. on Firefox.
    How do I accomplish in
     that the debugging lines are not vanishing after some time, but stay forever or until I want to delete them?
    By the way, with
    If you are forwarding a port, it must be included in the IP address.
    Port 80 is the default HTTP port and does not need to be specified.
    For any other port, append it to the IP address (e.g., http://192.168.1.10:8080).
    Do you mean line like that?
    Above you can see that I had already added a port number, what is working in Firefix with webeye 3.0, but not with webeye 4.0.
    No, I did not mean this debug information, but all the reporting lines of a working webeye.
