    That's new . what AOS version you are running?
    11.0
    Since the jM lines are part of the code I am unable to find the error
    Could you please post the error line 1807 as shown in your post?
    The nearest and last backup of AOS was 2025-12-16. Because a did a number of changes after this date I have not precisely knowledge of the linenumber of the start of your system at the time of the problem. In these last backup of 2025-12-16 the linenumber of --========================== USER DEFINED FUNCTIONS =============================== is 1000.
    The change of number of linenumbers between 2025-12-11 and 2025-12-16 could be about 30 lines or more (and not less), so line --========================== USER DEFINED FUNCTIONS =============================== could be between 1010 and 1030.  I show now the lines 2798 until 2858:
     function initTable(callType)
      local cTime,dType,devNum,delSpace,i,j,jv,k=os.date("%H:%M",os_time()),"devices",0,{"property","state","timeSlot"},0,0,"",0
      getIntValue();jGps.user={};jGps.data={};jGps.ios={}; if not gpsDevice then gpsDevice={} end
      for _,j in ipairs(fibaro:getDevicesId({roomID=0,type="iOS_device"})) do tmpStr=rF
         if tostring(api.get("/devices/"..j)["properties"]["Push"])=="true" then jv=jv..j..","; tmpStr="<font color=darkgreen>" end
         noteList.sendPush[tostring(j)]=tmpStr..fibaro:getName(j)..eF end
      if not pushNote[2] or not pushNote[2]:match("%d+") then pushNote[2]=","..jv end
      for _,j in ipairs(api.get("/users/")) do noteList.sendEmail[tostring(j.id)]=j.name..":"..j.email:gsub(j.name,"");jGps.user[tostring(j.id)]=j.name:match("%w+") end
      if not eMail[2] or eMail[2]:len()==0 then eMail[2]="2" end
      if callType=="getUsers" then return end
      initMode=true;fibaro:debug(ygF.."Gathering "..wF..api.get("/settings/info/")["hcName"].." - "..api.get("/settings/info/")["serialNumber"].."</font> system information...</font>")
      for i,j in pairs(api.get("/panels/location")) do
        jGps[tostring(j.id)]=j; jGps[tostring(j.id)].address="address"..j.id
        if j.home==true then jGps.data={timestamp=os.time(),geofenceAction="NA",userId=2,deviceId=999,locationId=j.id} end
      jIcons=api.get("/proxy?url=http://127.0.0.1:11111/api/icons")
      local dp=api.get("/devices/")
      for i,j in pairs(dp) do
        j.id=tostring(j.id);jDid[j.id]={}
        jDid[j.id].name=j.name;jDid[j.id].idType="Z.Device"
        jDid[j.id].enabled=j.enabled
        if j.type=="iOS_device" then jGps.ios[tostring(j.id)]=j.name end
        jDid[j.id].room=(j.roomID==0 and "Unassigned" or api.get("/rooms/"..j.roomID)["name"])
        if tostring(j.properties.dead)=="true" and j.enabled then
            gData.numDeads=gData.numDeads+1
            jF[j.id]=jF[j.id] or {total=1,reason={"onInit"..os.date(" %d %b %H:%M",os_time())},enabled=true,nack=0,id=inId,dead=true}
        jDlist["cmd"..j.id]=tableSortByKey(j.actions,"primeSort")
        if j.parentId and j.properties.nodeId and j.id~="1" then
          if j.parentId>1 or j.remoteGatewayId>0 then jDlist["numDev"]=jDlist["numDev"]+1;jDlist[j.id]=j.properties.nodeId;jDlist["nId"..jDlist[j.id]]=os_time()
          else jDlist["pId"..j.properties.nodeId]=j.id;jDlist["mId"..j.id]=true;jDlist["phDev"]=jDlist["phDev"]+1 if j.properties.batteryLevel then jDlist["batDev"]=jDlist["batDev"]+1 end end end
        if j.isPlugin then jDid[j.id].idType="Plugin";jDlist[j.id]="plugIn";jDlist["plugIn"]=jDlist["plugIn"]+1;jDlist.pinId=jDlist.pinId..","..j.id.."," end
        if j.type=="virtual_device" then jDid[j.id].idType="V.Device";jDlist[j.id]="vd";jDlist["vDev"]=jDlist["vDev"]+1;jDlist.vdId=jDlist.vdId..","..j.id.."," end
      end --for i,j in pairs(api.get("/devices/"))
      for i,j in pairs(api.get("/scenes")) do
          jDid["_"..j.id]={};jDlist["scenes"]=jDlist["scenes"]+1
          jDid["_"..j.id].name=j.name; jDid["_"..j.id].room=(j.roomID==0 and "Unassigned" or api.get("/rooms/"..j.roomID)["name"])
          jDid["_"..j.id].idType=j.type:gsub("com.fibaro.","")
          if j.autostart==true  and j.runConfig=="TRIGGER_AND_MANUAL" then jDid["_"..j.id].idType="Auto-"..jDid["_"..j.id].idType end
      prtLine(ygF.."Initializing jS2n{}, jP2n{}, global and userKeyWord{} tables...</font>")
      if not jM or type(jM[1])~="table" then sceneAbort("(40) "..rF.."Attempt to access jM hash table (a nil value)"..eF,{"not defined"},{".jM hash table","See error below"}) end
      if #userKeyWord[1]~= #userKeyWord[2] then sceneAbort("(41) Number of elements in array doesn't match. <br>Array 1 has '<font color=wheat>"..#userKeyWord[1].." elements</font>'<br>"..json.encode(userKeyWord[1]).."<br>Array 2 has '<font color=wheat>"..#userKeyWord[2].." elements</font>'<br>"..json.encode(userKeyWord[2]),{"not defined"},{".userKeyword table:","See error below"}) end
      for i=1,#userKeyWord[1] do if userKeyWord[1][i]:sub(1,1)~="$" then sceneAbort("(42) keyword '"..wF..userKeyWord[1][i]..eF.."' missing prefix sign'<font color=wheat>$</font>'.",{userKeyWord[1][i]},{".userKeyword table:",json.encode(userKeyWord[1])}) end end
      parseCmd();jmNum=tostring(#jM):len()
      for j=1,#jM do
         if type(jM[j][1])~="number" then table.insert(jM[j],1,0) end
         if jM[j][3] then
            for i=1,#task.state do
              if jM[j][3][task.state[i]]~=nil then
                  if type(jM[j][3][task.state[i]])~="table"  then jM[j][3][task.state[i]]={jM[j][3][task.state[i]]} end
                  if type(jM[j][3][task.state[i]][1])~="string" then assertType("(104)",jM[j][3][task.state[i]][1],task.state[i],"string",j) end
                  if not tostring(jM[j][3][task.state[i]][1]):find("%b{}") then
                      sceneAbort("(105) Syntax error in "..wF..task.state[i]..eF.." statement: "..wF..tostring(jM[j][3][task.state[i]][1])..eF.."<br>Please review and fix.",
                      {tostring(jM[j][3][task.state[i]][1]),task.state[i]},j) end
          end --if jM[j][3] then / for i=1,#task.state do
         jM2n[j]="{"..irF..jM[j][1].."</font>, <font color=darkgrey>\""..jM[j][2].."\"</font>...}"
         jM[j][2]=jM[j][2]:gsub("[%s+]? and [%s+]?","|");jM[j][2]=jM[j][2]:gsub("[%s+]?,[%s+]?","|")
      end -- for j=1,#jM do
    I hope this information will be enough to determine the problem.
    Hello everyone,
    Could I ask for help with a problem sending PUSH messages? After updating the QuickApp AOQ system to version 20.7, the sendPush field in the jM table in the user_data tab was working, but suddenly it stopped, and the system displays a message in the debugger that this function is missing. I've read that the API parameters have changed (please note that I'm not a programmer) and I don't know how to resolve this.
    I'm attaching a fragment of the jM table and a screenshot from the debugger.
    Best regards, and I'm asking for help....
    fibaro.alert) has been changed in a new version.
    I will release a new AOQ version today with the fix
    Meanwhile you can use attached version below
    Edited by cag014
    Great - thank you very much for the quick response :), your script is great...
    Regards, Darek
    Edited by dareszek
    Hi @cag014
    After updating to the newest version it complains about below row:
    {0, " $blank",{timeSlot="true ?$sunsetHour?, false ?$sunriseHour?",
    trueAct={"&IsDayTime", "setGlobal", "false"}, falseAct={"&IsDayTime", "setGlobal", "true"}}},
    [DEBUG] [AOQ3694]: Parsing jM{32} hash table data...[2025-12-24] [09:11:35] [ERROR] [AOQ3694]:  [24 Dec 09:11:30] AOQ369421.7 jM hash table:29:~: {0,' $blank', {......
    {0,"$blank",{falseAct={"&IsDayTime","setGlobal","",false,true},timeSlot="true?$sunsetHour?,false?$sunriseHour?",trueAct={"&IsDayTime","setGlobal","false"}}}
    (18) Action's 3rd field in 'setGlobal' is empty.
    Field should include action's valid data.
    [2025-12-24] [09:11:35] [WARNING] [AOQ3694]: QA is terminated. Please refer to Advanced User’s Guide for more information.... and restart AOQ
    It's strange that it worked before.
    What do you mean by {"&IsDayTime","setGlobal", "", false,true} - The data field is empty, which is incorrect.
    The correct format of the action should be
    {"&IsDayTime","setGlobal","false",true}
    Command format:
    • param1: global variable name or list of names
    • param2: action (always setGlobal).
    • param3: value to assign.
    So, instead of
    it should then be
    no
    instead of
    should be
    {"&IsDayTime","setGlobal", "false"}
    the 4th parameter true forces the command to run on init
    By default setGlobal runs on init , so true is meaning less
    Thanks @cag014 (You dont need to answer today since it christmas!)
    The problem is that i dont have {"&IsDayTime","setGlobal", "", false,true} , even though the error message says that..
    This is the line i have (that doesnt work now):
    {0," $blank",{timeSlot="true ?$sunsetHour?, false ?$sunriseHour?",trueAct={"&IsDayTime","setGlobal","false"}, falseAct={"&IsDayTime","setGlobal","true"}}},
    Thank you for finding the bug.
    Please try attached version
    Let me know if it works and I'll release it in the forum
    Edited by cag014
    Now it works!
    Thanks @cag014!
    The problem was active again 🤢
    [DEBUG] 12:30:50: jM{55}T  Beveiliging:449:SmartIn2[8.59>8] ➯ if lineState{&tSlotUitgeschakeld=Nee} then
    [DEBUG] 12:30:50: jM{55}T  Beveiliging:449:SmartIn2[8.59>8] ↪   setGlobal(&tSlotUitgeschakeld, Ja)
    [DEBUG] 12:30:50: 2025-12-22 12:30:50.528712 [ fatal] LUA error: /opt/fibaro/scenes/451.lua:1815: attempt to perform arithmetic on a nil value
    Line 1815:
    jTime[tName]={orgData,(jTime[tName] and timer:find("[+-]") and jTime[tName][2]+tonumber(timer) or os_time()+tonumber(timer)),devId..":"..tName,(jTime[tName] and jTime[tName][4] or os_time())}
    Could you please post the jM line?
    looks like the line includes timer....
    ng(mStr):gsub("[%(%+%-%*/@&%$]", function (a) return a.."%" end) end
     function setTimer(actData,devId,act1,act2,act3,orgData,devStr,cmdStr)
        local dact3,tName,timer=actData[3]:match("timer%S.*,[+-x]?(%b??)"),act3:match("(timer%S+,)([%d+-x]+)")
        if dact3 and jD[devId].dbgCalc then
            dact3=" "..doTheMath(dact3,devId,"parse"):gsub(" ",""):gsub("<[/]?mark[%d+]?>",""):gsub(".-<small>",vF.."?"):gsub("</small>","").."?"..eF
            dact3=dact3:gsub("[$&]:",function(a) return a:sub(1,-2) end)
        else dact3="" end
        tName,timer=act3:match("(timer%S+,)([%d+-x]+)")
        timer=timer:lower():sub(1,1)=="x" and "x" or timer
        act3=act3:gsub("(timer%S.-,.*)",""):gsub("^%s*(.-)%s*$", "%1")
        orgData[3]=orgData[3]:gsub("(timer%S.-,.*)",""):gsub("^%s*(.-)%s*$", "%1")
        if (act2=="setTimer" or timer:find("[+-]")) and not jTime[tName] and timer~="x" then
            lastAct(trueFalseColor[false]..devStr..act2..qrF..(act2=="setTimer" and "" or " aborted").."{"..tName..timer.." is not active}</font></sup></font>",devId,fibaro.error)
        else
            if timer=="x" then
                lastAct(trueFalseColor[true]..devStr..cmdStr.."{"..(jTime[tName] and ygF or lpF).."cancel "..tName:sub(1,-2)..eF.."}</sup></font>",devId)
                jTime[tName]=nil;onTimer=onTimer:gsub(tName,"")
            else
                onTimer=onTimer..(onTimer:find(tName) and "" or tName)
                tmpNum=timer:find("[+-]") and cF..jTime[tName][2]-os.time()..eF..timer or timer
                if act2=="setTimer" then
                    tmpNum=(timer=="+0" and jTime[tName][2]-os.time() or tmpNum)
                    jTime[tName][2]=(timer:find("[+-]") and jTime[tName][2]+tonumber(timer) or os_time()+tonumber(timer))
                    if actData[1]:match("%b{}") then jTime[tName][1][4]=actData[1] end
                    lastAct(trueFalseColor[true]..devStr..act2.."{"..ygF..tName..tmpNum.."s"..eF..dact3..(#actData[1]>0 and " 🔛<font color=#9ACD90>"..parsDev(actData[1]):gsub(":value","")..eF or "").."</font>}</sup></font>",devId)
                else
                    lastAct(trueFalseColor[true]..devStr..act2.."{"..ygF.."*"..parsDev(actData[1],act3).."*"..eF.."}</sup></font>"..vF.." by "..eF..grF..tName..tmpNum.."s "..dact3.."</font>",devId)
      end --==================================== setTimer
    line 1815 :
    Edited by Rover
    I mean jM line that has the timer command....
    for example:
    {,"sensor", state="true", falseAct={"light","turnOff","timerTest,30"}}},
    After the Update, my log if flooded with these lines, can you help?
    aoqVer=21.8
    [28.12.2025] [14:32:12] [ERROR] [QUICKAPP98]: QuickApp crashed
    [28.12.2025] [14:32:12] [ERROR] [QUICKAPP98]: main.lua:4769: attempt to concatenate a nil value (local 'newValue')
    Edited by PSi
