This night it has worked (v9.6).
@cag014 I changed this line.
else fibaro.alert("push",uId,ctlChar(subject..""..body,"\n","\\n")) end end
I deleted the \n characters between the subject and the ..body.
In this way in the push notification the \n characters is not there.
Working fine.
    Working fine.
    What was the problem???
    When the AOQ sent the notifications, between the subject and the message, puted \n characters.
    @Rover
    Didn't find anything wrong, but might be AOQ with many lines is too busy and could miss the time.
    In attached version have added extra trigger (every 15 seconds) to run through lines.
    Let me know if it helps
    @SmartLifeSystems
    The \n is still exists in this version and the reason is that it works fine in old fibaro application. Will try to find out proper solution in next release.
    5 minutes ago, cag014 said:
    @Rover
    @SmartLifeSystems
    If I deleted the \n from the next line, working fine.
    This is the original line:
    else fibaro.alert("push",uId,ctlChar(subject.."\n"..body,"\n","\\n")) end end
    The AOQ has need this \n?
    Edited by SmartLifeSystems
    Honestly it's just to distinguish between subject to body of the message.
    Will try to find out different approach... maybe to include subject in parenthesis like
    (Subject): body message
    Do you have any suggestions?
    Edited by cag014
    I think, dont't need the \n between the subject and the body in this line. Only the "" characters. I testing since some days, and working correctly.
    12 hours ago, cag014 said:
    @Rover
    @SmartLifeSystems
    All fine this night with v9.7 ?
    Talking about subject and body:
    Why is the subject in an email not showed up as subject, but get a title "Bericht van Fibaro" (Message from Fibaro)?
    Yes, this problem exists since the beginning of HC3. Have reported about that. no answer....
    That's interesting on my phone (Samsung - android) I don't see "\n" character, but actually new line works!???
    Is it iPhone?
    Is it iPhone?
    Yes, it is iPhone, and working without the \n.
    Hi @cag014,
    Have you any idea, how can I set example the os.Date-20 min?
    And I have another interesting question. I integrated the Football Euro20 calendar in the HC3. This events save a global variable.
    Examples for the variable:
    Hungary - Portugal [Euro2020]
    France - Germany [Euro2020]
    Croatia - Scotland [Euro2020]
    Hungary - France [Euro2020]
    Can I use for trigger from this variable example the Hungary word?
    If the Hungarian team will play, turn on the TV. But from the calendar, every match will be in the variable before the match's time.
    Do you understand? :D
    Actually, yes there is an option to compare part of value. use "=="
    {0,"&GV",{state="value==Hungary", trueAct={}......}},
    it means when word Hungary will be found in &GV the trueAct{} executed.
    Edited by cag014
    Thanks, I will try.
    And you have idea for the os.Date-20 minutes?
    58 minutes ago, SmartLifeSystems said:
    Thanks, I will try.
    I tried the command, but I think the os.Date don't working.
    I tested a simple line, but the AOQ don't do anything.
    Here is the line:
    {0, "$osDate",{state="value=&CalendarDate",trueAct={{"`cinemaSystem`","turnOn",""},{"`sonyTV`","pressButton,26","6"},{"`sonyTV`","pressButton,11","10"},{"Foci EB","sendPush,3370","Hamarosan kezdődik a &Calendar , bekapcsoltam a TV-t!"}}}},
    Here is the line:
    So I tried with an another mode.
    I think, the "==" don't working too. Maybe I doing something wrong?
    {0, "&Calendar",{state="value==Hungary",trueAct={{"`cinemaSystem`","turnOn","","={$24clock:value=&CalendarDate}"},{"`sonyTV`","pressButton,26","6","={$24clock:value=&CalendarDate}"},{"`sonyTV`","pressButton,11","10","={$24clock:value=&CalendarDate}"}}}},
    After this third successful night with the timing function I declare the problem for solved ?
