    9 hours ago, SmartLifeSystems said:
    So I think, I can't use this device with the HC3...
    No
    Hi @cag014,
    • To receive the 'last modified' time of any property, add “Modified” to property name. For example, to get when the device was last changed, the property should be valueModified. Returned value is number of seconds from last change.
    {"Deurbel","sendEmail,2","vorige bel: @`Deurbel`>valueModified"},
    Content email:
    Deurbel
    vorige bel: 1174645
    I do not think that 1174645 is Returned value in number of seconds from last change.
    BTW, I am using email a lot in order to get the content of a value at a certain moment.
    Addition of {"Debug", "text", {value.1, value.2, value.3} }  (value.x is the value of a device or a GV or a LV), putting this info in the AOQ debug list, would make the lives of us happy AOQ developers still even happier ?
    Edited by Rover
    2 hours ago, Rover said:
    Hi @cag014,
    You mean to print this data in debug window?
    If so, you just reading my mine, that's exactly what I'm working on...
    Yes I ment the debug window.
    Content email:
    Deurbel
    vorige bel: 1174645
    Are you going to repair this?
    I thought I've answered...
    Have tested that several times and it works correctly, don't see any problem.
    Are you sure that Deurbel properties parameter "value" has changed recently?
    Edited by cag014
    Yes
    Deurbel
    vorige bel: 1174645
    Deurbel
    vorige bel: 1174642
    Edited by Rover
    Could you please go to
    http://api/devices/<DevID>/properties/value
    and post the value and modified data...
    It is a Fibaro D/W sensor
    and you still receive big number in valueModified ?
    Deurbel
    vorige bel: 126977
    Deurbel
    vorige bel: 127153
    Deurbel
    vorige bel: 127158
    It is not the number of seconds from last change, but the time since last change (in seconds). I need the number of seconds from last change to be able to use it in lineState. It is not possible to calculate the time difference in lineState.
    I need this function to be able to filter the bouncing of the doorbell button.
    Edited by Rover
    Deurbel
    vorige bel: 126977
    Deurbel
    vorige bel: 127153
    Deurbel
    vorige bel: 127158
    This is the time in seconds from the last change of value (either true or false).
    O.K. the value does not change by pushing the doorbell button, just scene activation is useable.
    Do you know a way to filter the bouncing of the doorbell button? Something with setValue?
    I have tried to do it in this way, but calculation in lineState is not accepted:
    {0,"`Deurbel`",{trigAll=true,lineState={"{?@`Deurbel`>valueModified - &LaatsteBel:value? > 15}"},trigAct={ --Deurbel geluid (niet als herhaald binnen 15 seconden)
          {"Deurbel","sendEmail,2","tijdverschil: ?@`Deurbel`>valueModified - &LaatsteBel?"},
          {"&LaatsteBel","setGlobal","@`Deurbel`>valueModified"}, --Bewaar tijd laatste bel
          {"Deurbel","sendEmail,2","vorige bel: @`Deurbel`>valueModified"},}}},
    Edited by Rover
    Let me see ...
    Edited by cag014
    An idea... move the calculation to the right side of the condition
    {0,"`Deurbel`",{trigAll=true,lineState={"{`Deurbel`:valueModified > ?&LaatsteBel+ 15?}"},trigAct={ --Deurbel geluid (niet als herhaald binnen 15 seconden)
    What do you think?
    Edited by cag014
    What do you think?
    AOQ accepts it and it works ?
    You are still genious ?
    To all, since upcoming HC3 new version doesn't support anymore api.get("/panels/events?type....)  please download attached version (using new api)
    In addition this version includes all available debug commands... follow format
    {"<string tag>","debug","message"}
    {"<string tag>","error","message"}
    {"<string tag>","warning","message"}
    {"<string tag>","trace","message"}
    You can leave the string tag empty  like {"","trace","message"} and standard tag (AOQ<DEVID>)  will be printed.
    I do suggest to use string tag because it could be easily filtered in debug window.
    The debug information printed in colors according to the type of the message.
    Hopefully next release will support actions based on GPS location
    Edited by cag014
    hi cag.
    Merry Christmas and a new question to you:
    i update to the last beta.
    aoq 9.1 doesnt even start,
    aoq 9.2 start very slowly with some strange debug lines
    [23.12.2020] [06:42:47] [DEBUG] [AOQ1385]: local: HC3-MAIN HC3-000040025.061.36...[23.12.2020] [06:42:55] [WARNING] [AOQ1385]: TimeResp over 7 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D534 [23.12.2020] [06:43:01] [WARNING] [AOQ1385]: TimeResp over 6 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D764 [23.12.2020] [06:43:07] [WARNING] [AOQ1385]: TimeResp over 6 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D769 [23.12.2020] [06:43:14] [WARNING] [AOQ1385]: TimeResp over 6 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D1030 [23.12.2020] [06:43:20] [WARNING] [AOQ1385]: TimeResp over 6 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D1157 [23.12.2020] [06:43:26] [WARNING] [AOQ1385]: TimeResp over 6 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D1161 [23.12.2020] [06:43:32] [WARNING] [AOQ1385]: TimeResp over 6 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D1162 [23.12.2020] [06:43:38] [WARNING] [AOQ1385]: TimeResp over 6 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D1169 [23.12.2020] [06:43:45] [WARNING] [AOQ1385]: TimeResp over 7 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D1228 [23.12.2020] [06:43:51] [WARNING] [AOQ1385]: TimeResp over 6 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D1233 [23.12.2020] [06:43:57] [WARNING] [AOQ1385]: TimeResp over 6 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D1240 [23.12.2020] [06:44:03] [WARNING] [AOQ1385]: TimeResp over 6 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D1245 [23.12.2020] [06:44:13] [WARNING] [AOQ1385]: TimeResp over 6 sec. to execute /events/history%3FobjectType%3Ddevice%26%26numberOfRecords%3D1%26objectId%3D1324
    Any hint
    8 hours ago, gggizmo said:
    hi cag.
    Any hint
    As far as I know there is a lot of problems with this beta.
    My HC3 has an issue with Nice memory and I cannot update to this new beta version.
    In any case, looks like the process to execute remote commands takes too long.
    If you can, update to previous version. Let's wait for official release.
    Hi Everybody!
    I wish every user Merry Christmas!
