2 minutes ago, cag014 said:
Question, are these sensors included in HC3 alarm zones?
Yes.
Just now, SmartLifeSystems said:
Yes.
And in the AOQ too.
    Still don't see any reason for restart...
    Please post sensor API while it is breached...
    5 hours ago, SmartLifeSystems said:
    Hi @cag014,
    I think I find the restart problem. Look, this is very interesting.
    So I use the Satel Integra AlarmSystem's sensors. I think, the problem is the motion sensor.
    Example: If I breached the motion sensor in the livingroom, the AOQ is restarting. If I breached the MS 3 times, the AOQ is restarting 3 times, in every minutes.
    Look the times on the screenshot.
    When I breach the MS, the AOQ is restarting xx:xx:09, xx:yy:09, ...
    looks like this snapshot has several picture, I want to make sure that it's fails on startup, correct?
    Or it fails somewhere in other place?
    Could you please, breach the sensor and to restart AOQ and to post entire debug window ?
    Edited by cag014
    Yes, this is 3 screenshot. You don't seen anything in the debug window, because don't working at this time this sensor in the AOQ. I saw, when I don't moving in the livingroom, the AOQ don't restarted, when I moved in the livingroom, the AOQ is restarted. I tried at Satel D/W sensor, but at this devices, the AOQ don't restarted.
    Where I use this sensor, only the next line, but when I trying, the timeslot wasn't true.:
    /monthly_2020_11/2107083119_Kepernyofoto2020-11-14-17_48_59.thumb.png.a6169497f28ec8eefe48b2c9d531b6b9.png.69f8cb679b090724b6e3efa5d6a05be4.png" />
    Edited by SmartLifeSystems
    Could you identify on which AOQ version you have restarts?
    @SmartLifeSystems
    Please try attached
    Hi @cag014,
    I tried the v8.0, but restart, when I moving in the living room.
    Here is the sensor's API, when I breached, and screenshots. Is it very interesting for me, because the restarting allways at xy minute:09 sec starting. So I breaching the sensor, and at the next min:09 sec will restart.
    The first picture, when I upload the v8.0. While don't moving in the living room, the AOQ working fine (with very low CPU load, congratulations).
    The last version what is working correctly for me is the v6.3. The newest versions no.
    1 hour ago, SmartLifeSystems said:
    Hi @cag014,
    I think I have found the line causes the problem... working to fix it...
    Comment this line and see if AOQ restarts
    Edited by cag014
    OK. I commented these lines, and no restart.
    Finally have fixed that... let me know if it works
    To all please use attached
    Ohhh. Working nice. No restart. Thank you!
    On 11/17/2020 at 9:42 PM, cag014 said:
    Yes you have an error too many curly brackets at the end. Please remove one.
    {0,"`hoofdSlaapKamerlader`",{state="value=true",
    trueAct={"`woonKamerverlbasis`|`woonKamerverlabsent`|`woonKamerverltvuit`|`woonKamerverltvaan`","turnOff","","{`hoofdSlaapKamerlader`:value=on}"}}},
    OK, will try to see what the problem is...
    @cag014 Please have a look at it. For me it is important  in order to finish the alarm procedures.
    On 11/17/2020 at 11:13 AM, cag014 said:
    Add reboot command and I suggest with few seconds of delay (to make sure that notification sent)
    See marked changes...
    {0, "$RAM",{state="value>85",trueAct={{"RAM>85%","sendNote","Warning. \nSystem memory is $RAM%, rebooting... ",true},{"","reboot","10"},{"|$lineId|","setStateValue","80"}},falseAct={{"|$lineId|","setStateValue","85"},{"RAM<80%","sendNote","System memory is $RAM%"}}}},
    This line not is the HC3 rebooting. The AOQ restarting.
    Looks like fibaro.homeCenter.systemService.reboot() not supported in QuickApp ?
    Have reported to fibaro
    This RAM load is normaly? I rebooted the HC3 at this moorning.
    It reaches 85% in two days.
    /monthly_2020_11/1473243186_Kepernyofoto2020-11-21-16_27_36.png.9aae13831bec26a12c79285382d98bb4.png" />
    No... it's not...
    Do you have any other Lua scenes? If so please verify that you're not allocate variables again and again by mistake..
    Or Just disable scene after scene to find the cause
    No... it's not...
    me too 78% , but uptime is 3 days
    Edited by gggizmo
    that's it after reboot
    Hi @cag014,
    I had to delete the 2 Sonos ZC QA's of Krikroff because the CPU load paralyzed the HC3.
    With the 2 Sonos ZC's:
    Further only 2 AOQ's working. Do you have the same experience? Krikroff wrote that he has very low CPU load with 4 Sonos ZC's.
    Then I have to get the SonosHub of 10der working.
    playNotification works, but
    fibaro.call(212, "addToQueue", "192.168.1.19", {"//192.168.1.3/d/SonosGeluiden/Deurbel.mp3"})
    fibaro.call(212, "play", "192.168.1.19")
    does not work.
    I need that mechanism to queue 20 alarm sounds and then play it as siren for an hour,
    1 minute ago, Rover said:
    Hi @cag014,
    You mean doesn't work from scenes?
    By the way any new QA from them, or I can continue to debug the problem using latest Sonos_Hub
