Dear cag014,
First of all I would like to thank you for all you are doing for our community, both through software developments, but also through your support and advice. I really appreciate the effort.
Personally, I have 2 topics that I would need help with:
1.      I would like to use AOQ to send commands to ZenitGatekeeper (Text to speech) application.  I’m using an HC3 controller, I installed the ZenitGatekeeper application on an android tablet that will sit on the wall for Fibaro purposes and I would like to send TTS commands from AOQ to the tablet.
Do you have any code that I could use in AOQ to interact with that TTS application. ? I just found a LUA code for scenes in HC2 in download section
2.      I used a Fibaro double switch2 to control a light. In some circumstances I want to make that light flashing. To be able to do  that I have to change a parameter to switch, in fact to change parameter to the first device associated with, that is invisible, the Z-Wave device.
Unfortunately that kind of device is not recognized by AOQ, even if I make it visible.
Find below the line from JM table:
 {0,"`mSensor`",{state="value=true",trueAct={{"`gardenLightZWAVE`","setConfiguration,10,1,5",""},{"`gardenLight`","turnOn","2"}}}},
Despite existing, the gardenLightZWAVE device (Id=290) is not found in the system.
The error below:
[15.11.2020] [03:43:04] [DEBUG] [AOQ270]:  [15 Nov 03:43:04] AOQ270.jM hash table:8:~: {0, "`mSensor`"...}
{0,"33",{"state"="value=true","trueAct"={{"290","setConfiguration,10,1,5","1"},{"294","turnOn","2"}}}}
(35) Item ID 290 not found in the system.
What exactly should I do in order to resolve that issue ?
    Could you please post device 290 API?
    use
    http://<hc3-IP>/api.devices/290
    and please use latest AOQ...
    Regrading TTS , I'll post tomorrow Quick App for you
    Edited by cag014
    15 hours ago, Rover said:
    Question:
    {"&Tuinpomp2uur","setGlobal","~?2*60*60?~Uit","if {`Tuinpomp`:value=true}"},
    Does the event `Tuinpomp`:value went false before the execution of the setGlobal delay of ~?2*60*60?~ prevents the execution of the setGlobal?
    Or does "if {`Tuinpomp`:value=true}"} only prevent putting "&Tuinpomp2uur","setGlobal","~?2*60*60?~Uit" in the action queue?
    Hi @cag014, please advice.
    8 hours ago, cag014 said:
    Another try, please download attached.
    I don't understand. The v6.3 is working fine.
    19 hours ago, cag014 said:
    23 hours ago, Rover said:
    I see in the AOQ-Remote QA a feature to change the color of the labels when actived, but no color changing to be seen in Web UI and on iPhone.
    Thinking about a way to change the color of a AOQ-Remote label from AOQ. In fact just dynamicly changing from grey to red or green. Starting from creating a list of colors for every button in the QA.
    How to realise this?
    What you refer to? buttons color when activated or the label at the top of AOQ_remote?
    In any case:
    1. The buttons color changed by the mobile app. itself (when pressing)
    2. The label color at the top of the screen, is coded in AOQ_Remote.
    Edited 17 hours ago by cag014
    Edited by Rover
    I don't know what has happened, but the response time of HC2 devices (no slaves) has grown to about 2 minutes...
    I am using version 7.7.
    The condition will be tested after delay.... before execution.
    Where from the not AOQ debug lines come?
    could you please post user_data file?
    Edited by cag014
    @MBU
    Attached text to speech QA... please add it to HC3.
    Go to user_data file at TTS function section update as follow:
    Now you can use tts in AOQ, for example
    {0,"`motion`",{state="value=ture", trueAct={"","tts"," motion sensor breached"}}},
    In addition you can also use in AOQ direct call
    {0,"`motion`",{state="value=ture", trueAct={"`zTTS-ID`","zTTS,motion sensor breached,192.168.10.5:8080"}}},
    Since on startup tts commands are ignored, I recommend to use first option
    Please make sure to use your tablet IP
    Edited by cag014
    11 hours ago, cag014 said:
    The line should be like:
    {0,"`mEntree`",{lineState={"{`lSuspensionPressoir`:value=false}"},state="value=true",timeSlot="$sunsetHour~$sunriseHour",trueAct={{"`lSuspensionPressoir`","turnOn",""},{"`lSuspensionPressoir`","turnOff","180"}}}},
    This works perfectly! many thanks as usual!!!
    That's the heating scene, what do you see.
    Here is my user data.
    Edited by SmartLifeSystems
    Cag, TTS  works properly, you are blilliant :)
    Regarding the other topic with the setConfiguration device, I don't  understand what exactly means to post the device API:
    use
    I tried in LUA scene and there is not any problem to change the parameter, but AOQ does't recognize the device 290.
    Find below the list of devices associated to the physical  device :
    Somebody is ringing at the door: Notification after 20 minutes ?
    Edited by Rover
    Wow...
    What kind of notification? what is the jM line
    use
    OK, now I see the problem. device 290 is parent device and could not be used in AOQ.
    Please use 291 instead... let me know if it works
    Edited by cag014
    I already try that and unfortunately does't work
    I will create a LUA scene and I call it to be executed from AOQ. Or if you have a better idea....
    /monthly_2020_11/image.png.9207b2cf65ccf1a6b4c63b93e06db942.png" />
    Edited by MBU
    Please try
    {"291","+setConfiguration,10,1,5"....
    Perfect, It's working properly. Thanks a lot for your fast reaction and professional advice
    1 hour ago, cag014 said:
    Wow...
    It took that time between HC2 D/W sensor in doorbell and reaction in AOQ by pushover and Sonos bellsound.
    The same as reaction time between pushing Scenemaster button and wallswitch on/off.
    And reaction time between motion for motion sensor and light on...
    etc.
    All HC2 devices have a huge delay (again, but worse than before).
    All devices are <device>'hc2.
    Edited by Rover
    etc.
    What is HC2 CPU load? Try to reboot HC2..
    The HC2 CPU load does not seem a problem, but I will reboot HC2.
