I see in the AOQ-Remote QA a feature to change the color of the labels when actived, but no color changing to be seen in Web UI and on iPhone.
Thinking about a way to change the color of a AOQ-Remote label from AOQ. In fact just dynamicly changing from grey to red or green. Starting from creating a list of colors for every button in the QA.
How to realise this?
    23 hours ago, Sjakie said:
    Hi Cag,
    If I want to use
    jSlave={
        hc2={user=.........
    What to write in the j2Sn table?
    If I use HC2 ID's it give an error
    //Sjakie
    For example: motion sensor in HC2 defined in jS2n as
    jS2n={Motion="<DeviceID>'hc2"}
    21 hours ago, Rover said:
    How to stop a rptAction before all defined repetitions have been finished?
    Currently it's not possible...
    Why you need to stop it? I mean if you've defined to repeat the command then what is the reason to stop it?
    What you refer to? buttons color when activated or the label at the top of AOQ_remote?
    In any case:
    1. The buttons color changed by the mobile app. itself (when pressing)
    2. The label color at the top of the screen, is coded in AOQ_Remote.
    Edited by cag014
    In the alarm procedure I started alarmsound.mp3 on Sonos devices with rptAction for 1 hour. If the alarm has to be stopped by a disarm procedure then also all sirens and the "siren" on Sonos devices has to be stopped.
    I don't think that rptAct for siren (I assume when is breached) is the correct approach.
    Just create another line that every hour sounds alarm if it's breached.
    On 11/13/2020 at 7:53 AM, SmartLifeSystems said:
    This problem is only on my HC3?
    Again..
    Once again please post debug window where it happens.
    In addition please post the jM line of the last executed command before restart
    Edited by cag014
    The alarmsound.mp3 has a duration of only a few minutes so I have to repeat it until the hour has been reached. It is not the intention to hear every hour an alarm sound for a few minutes. BTW I have different alarm sounds for burglary, smoke or fire with different duration, so the number of repeats differ per type of alarm.
    The alternative for rptAct is of course a bunch of jM lines with different delays.
    Edited by Rover
    On 11/13/2020 at 7:56 AM, gggizmo said:
    No i'm talking about system global vars. Every system global var returns to false when i restart aoq, except the one calculated in oninit stage...
    Are you sure you don't have setting to false somewhere, which is executed/initialized  on startup?
    Please set initialize on startup to false.
    There are two options to do it:
    1. To avoid initialize for the entire line - initOnStartup=false
    2. If you need to avoid initialization only at specific command - {"&GV","setGlobal","Gvalue",false}
    Edited by cag014
    OK, so create a line for every type that will sound an alarm every XX minutes and stops after one hour or while the alarm state is breached.
    Please post the jM line of that?
    Edited by cag014
    I see now the @10der has in his newest SonosHub QA a function QuickApp:addToQueue(ipaddr, uris) by which it is possible to fill a playlist with mp3's. By function QuickApp:clearQueue(ipaddr) this can be stopped.
    I think sometime is better to have bunch of the lines rather than bunch of commands in the same line... based on my experience, after few weeks it is more understandable than searching in commands... could be very fast changed or removed.
    Edited by cag014
    3 minutes ago, cag014 said:
    OK, so create a line for every type that will sound an alarm every XX minutes and stops when after one hour or when the sensor state alarm is not breached.
    I did it this way, but the solution by direct steering of Sonos devices is more direct and elegant.
    Question:
    {"&Tuinpomp2uur","setGlobal","~?2*60*60?~Uit","if {`Tuinpomp`:value=true}"},
    Does the event `Tuinpomp`:value went false before the execution of the setGlobal delay of ~?2*60*60?~ prevents the execution of the setGlobal?
    Or does "if {`Tuinpomp`:value=true}"} only prevent putting "&Tuinpomp2uur","setGlobal","~?2*60*60?~Uit" in the action queue?
    Again..
    @cag014,
    Here is the debug window.
    Good evening all,
    I'm trying to replicate a working scene in AIO. The scene use a Hue Dimmer to switch off a light. The trouble I have is that I don't know how to set as trigger in a jm the conditions which are made of key attribute & key id.
    How could look such a jm line?
    Thanks!
      conditions = { {
          id = 493,
          isTrigger = true,
          operator = "==",
          property = "centralSceneEvent",
          type = "device",
          value = {
            keyAttribute = "Pressed",
            keyId = 4
      operator = "all"
    fibaro.call(424'turnOff')
    20 minutes ago, SmartLifeSystems said:
    @cag014,
    I think I have found the problem... not sure
    Please try attached. If it's still restarts, please post your jM line 70
    13 minutes ago, GaelP said:
    Good evening all,
    Thanks!
      conditions = { {
          id = 493,
          isTrigger = true,
          operator = "==",
          type = "device",
          value = {
            keyId = 4
      operator = "all"
    Very simple
    {0,"<remoteID>",{state="centralSceneSupport=4.Pressed", trueAct={.....}}},
    Sorry, but restart again.
    Here is the JM70:
    This is a Satel Integra door sensor. If I opening the door, the Hall Light turn on, and turn off, when the livingroom motion sensor is breached. The livingroom ms too a Satel Integra MS.
    it's just something that starts with new releases...but for now it's nothing to worry about.
    I'l investigate and analize my jm lines and send you a feedback asap
    Very simple
    many thanks!
    This was ... simple... yes.... once I had it in from of my eyes :-)
    Well another simple one for which I can't find the solution... which I'm sure is simple as well.
    Simple use case that I succeed (no merit): switch on a light when a motion sensor is breach then turn it down 3 mn later:
    {0,"`mEntree`",{state="value=true",timeSlot="$sunsetHour~$sunriseHour",trueAct={{"`lSuspensionPressoir`","turnOn",""},{"`lSuspensionPressoir`","turnOff","180"}}}},
    where mEntree is a motion sensor and lSuspensionPressoir a fibaro switch that triggers a light.
    The downside of the above is that if the light was already switched on -manually actioned for instance- then the above will switch it off. What I would like to is for the line not to be executed the light was already on but I can't find how to do so.
    4 hours ago, GaelP said:
    many thanks!
    In case this is a switch add
    lineState={"{`lSuspensionPressoir`:value=false}"}
    if it is a dimmer add
    lineState={"{`lSuspensionPressoir`:value=0}"}
    The line should be like:
    {0,"`mEntree`",{lineState={"{`lSuspensionPressoir`:value=false}"},state="value=true",timeSlot="$sunsetHour~$sunriseHour",trueAct={{"`lSuspensionPressoir`","turnOn",""},{"`lSuspensionPressoir`","turnOff","180"}}}},
    • Drag files here to attach, or
    Edited by cag014
    Here is the JM70:
    Another try, please download attached.
    Edited by cag014
