4 hours ago, cag014 said:
Forgot about alarm property...
Hi @cag014
Looks like you fixed it ?
Disabled motion sensor slaves.
Measurements like before: 1-3 seconds response time .
Disabled Scenemaster slave: 1-2 seconds response time ?
    3 hours ago, Rover said:
    Hi @cag014
    OK, Thanks. Looks ,ike this is the direction...
    cag@14
    there's a problem in initialization of hue lights in 7.1
    [10 Nov 06:09:11] AOQ1385.jM hash table:17:~: {0, "`icucina`"...}
    {0,"358",{"state"="centralSceneSupport=2.Pressed","trueAct"={{"1253","changeBrightness,255",""},{"1253","turnOff;else;turnOn","","{1253:on=true}"}}}}
    (52) In device ID 1253, property 'on' not found.
    To retrieve last modification time, add 'Modified at end of property name (case sensitive)
    Available properties:
    - value
    - effect
    - state
    - currentProgram
    - userDescription
    - saturation
    - colormode
    - reachable
    - color
    [10.11.2020] [06:10:12] [ERROR] [QUICKAPP1385]: QuickApp crashed[10.11.2020] [06:10:12] [ERROR] [QUICKAPP1385]: main.lua:460: attempt to call a nil value (method 'stop')
    2 hours ago, gggizmo said:
    cag@14
    - value
    - effect
    - state
    - currentProgram
    - userDescription
    - saturation
    - colormode
    - reachable
    - color
    Did it work on previous versions?
    Pls try attached
    Edited by cag014
    Pls try attached
    works in very version before 7.
    May be in value init phase hue device give null value. It was a problem in early aos version
    Pls try attached
    yes 7.2 works
    tnx
    OK... is it works on 7.2?
    Hi, @cag014,
    I'am afraid, in the 7.2 the $profile, and the global variables don't working.
    Edited by SmartLifeSystems
    V7.1 crash, why?
    @Rover
    Due to new scanning, dead devices of slave controllers now take part of the table, fixed.
    @SmartLifeSystems
    Bug fixed.
    Edited by cag014
    Attached version includes bug fix for trigAct execution while monitoring scene instances.
    oninit section missing.
    How to make AOQ_Remote able to react on button doublepressed?
    Monring Cag, Morning everyone,
    Another beginer question: how to have several action triggered by the same conditions. Use case: turnon a light under certain condition, and then turn it off.
    The following kind of works:
    {0,"`dEntree`",{state="value=true",trueAct={{"`lSuspensionPressoir`","turnOn","","{{&Jour_Nuit:value=Nuit} and {if{`lSuspensionPressoir`:value=false}}}"},{"`lSuspensionPressoir`","turnOff","180"}}}},
    But as webeye show very clearly the Turnoff action is outside the if statement. Will always be executed. In this specific case, not an issue -beside turnoff a light which is already off-, but  there will be case when that's a problem. As a newbie, I don't know how to achieve this. Any suggestion?
    Many thanks
    Many thanks
    Yes, it should be outside because the condition defined in turnOn section.
    To set condition for all actions in the line use lineState
    lineState={"if {&Jour_Nuit:value=Nuit} and {`lSuspensionPressoir`:value=false}"},
    trueAct={{"`lSuspensionPressoir`","turnOn"},{"`lSuspensionPressoir`","turnOff","180"}}}},
    Edited by cag014
    Thanks for your very swift answer. As usual.
    when I add the lineState however, the resulting behaviour is not the one expected.
    1/ Starting with only one condition:
    lineState={"{`lSuspensionPressoir`:value=false}"},
    trueAct={{"`lSuspensionPressoir`","turnOn"},{"`lSuspensionPressoir`","turnOff","15"}}}},
    Screen capture 2 here below.
    In that case, the light does switch on but never switch off (I reduce to 15 sec for testing).
    In the debug window, I do see the turn on action but never see the turn off:  jM{11} TEntrée:266:Door[true] => turnOn{lSuspensionPressoir)
    If I take out the line state, in that case the light switch on and then switch off 15 sec after.: 11.11.2020] [15:20:28] [TRACE] [AOQ483]: 4.1jM{11} TEntrée:266:Door[true] => turnOn{lSuspensionPressoir)[11.11.2020] [15:20:43] [TRACE] [AOQ483]: 4.1jM{11} TEntrée:266:Door[false] => 15s>turnOff{lSuspensionPressoir)
    2/ if I put the two conditions with an "and" -which is indeed what I want- then it looks this is translated as a "or".
    See attached screen capture that show web eye showing an "or" instead of a and
    as a result the light switch on even if only of the two condition is fulfilled ("jour nuit" value was "nuit" , lsuspensionpressoir was off)
    For now, i'll stay with this {0,"`dEntree`",{state="value=true",trueAct={{"`lSuspensionPressoir`","turnOn","","{{&Jour_Nuit:value=Nuit} and {if{`lSuspensionPressoir`:value=false}}}"},{"`lSuspensionPressoir`","turnOff","180"}}}}, which gives the result expected even if the turnoff is useless as always executed even if the light was off.
    Edited by GaelP
    On 11/10/2020 at 8:48 AM, cag014 said:
    Have you checked the 7.4 attachment?
    I think that all lines of oninit secton are missing. I downloaded it 3 times...or maybe there's a problem with my browser
    OK... let's do some reorder...
    First of all lineState is always verified, so when you activate turnOff after delay the line is verified again and in this case the lineState is false.
    The question is it correct to use lineState in this case.
    Why not just:
    {0,"`dEntree`",{state="value=true",trueAct={{"`lSuspensionPressoir`","turnOn"},{"`lSuspensionPressoir`","turnOff","180"}}}},
    or may I suggest as follwoing
    {0,"`dEntree`",{state="value=true",trueAct={"`lSuspensionPressoir`","turnOn"},falseAct={"`lSuspensionPressoir`","turnOff","180"}}},
    The idea as I understand is to turn light on when motion detected, but in your case if someone will continue to move in front of the sensor the light will turn off after 180 sec. always and the person will find himself in the dark!!? So when motion sensor back to safe after 180 sec. turn Off the lights better aproach.
    In second scenario there is a syntax mistake. The and should be in same brackets.
    "{&Jour_Nuit:value=Nuit} and {`lSuspensionPressoir`:value=false}"
    the correct syntax is
    "{&Jour_Nuit:value=Nuit and `lSuspensionPressoir`:value=false}"
    In addition please try to keep Lua language syntax, I mean after and sgould be no if
    like
    if (....) and (...)
    not like
    if (...) and (if(...)
    The syntax is
    if {cond1 and cond2 and ….} or {cond1 and cond1 and ….} or..
    Please see Advance User guide (Conditional Parameter format) for more info
    Edited by cag014
    Why? Just add another button with the action name.
    Then more actions could be triggered by one smartphone screen. But indeed more buttons is no problem.
    Yes, it's correct, but (at least on my phone) there are a lot of space to accommodate about 15 buttons..
    You're absolutely correct...  when last function folded, it's not copied...
    Please check CPU load... I think it's decreased even more than before...
