3 minutes ago, cag014 said:
So all commands have a huge time response? not only command with delays?
indeed
    @Rover
    I think I've figured out what's the problem...
    try attached
    Edited by cag014
    May I suggest to reboot hc3 after upgrade...
    4 hours ago, cag014 said:
    @Rover
    try attached
    [QUICKAPP1385]: main.lua:1952: 'end' expected near
    reverted back to previous version. Looks like entire on init section is missing
    Edited by gggizmo
    8 hours ago, cag014 said:
    @Rover
    try attached
    The function QuickApp:onInit() content is absent, I took the one from v6.3 and it runs.
    Edited by Rover
    55 minutes ago, Rover said:
    But the delay is still more than 20 seconds, also after reboot HC3...
    I want to stop AOQ1, but every time I have pushed the stop button initiation followes and AOQ1 is again online ???
    Edited by Rover
    oops..
    That's strange ctrl+A doesn't copy last function if it's folded
    New measurements with Scenemaster as HC2 Slave and Wallplug switch direct on HC3, AOQ1 and AOQ2  each have 1 jM line:
    Booting HC3 starts both AOQ's and all slaves, HC3 CPU load again 40%.
    Measurements:
    • All on (with 3 slave smoke sensors and 4 slave switches on): HC2 CPU load 80%, HC3 CPU load 40%, response time wall switch 155 seconds.
    • With 2 slave smoke sensors on: HC2 CPU load 80%, HC3 CPU load 40%, response time wall switch 180 seconds.
    • With 1 slave smoke sensors on: HC2 CPU load 80%, HC3 CPU load 40%, response time wall switch 210 seconds.
    • With 0 slave smoke sensors on: HC2 CPU load 15%, HC3 CPU load 40%, response time wall switch 39 seconds.
    • With 3 slave switches on: HC2 CPU load 15%, HC3 CPU load 40%, response time wall switch 12, 50, 16 seconds.
    • With 2 slave switches on: HC2 CPU load 15%, HC3 CPU load 40%, response time wall switch 9, 18 seconds.
    • With 1 slave switches on: HC2 CPU load 15%, HC3 CPU load 40%, response time wall switch 9, 4, 4, 4 seconds.
    • With 0 slave switches on: HC2 CPU load 15%, HC3 CPU load 40%, response time wall switch 2, 2, 3, 3 seconds.
    Conclusion:
    • SlaveSensor-v2 with 14 D/W sensors: OK
    • SlaveSensor-v2 with 3 smoke sensors: delay
    • SlaveSwitch-v2 with 4 relay switches: hugh delay
    6 hours ago, cag014 said:
    oops..
    6.4 version in my system has again a relevant impact on cpu load.
    on idle, load is 10% on 6.2 and it's 25-30% on 6.4
    reverted back to 6.2
    Sorry cag014 if i report you just cpu load feedback, but it's the quickest and simplest feedback i can report . I have a lot of work to do these days so i temporary stopped every activity on hc3 ( lua-qa-aoq-alexa integration). I just update and briefly test every new aoq release and report you every small pieces of info i can collect
    Edited by gggizmo
    I agree that the CPU load is getting higher as times go by...
    On 10/27/2020 at 3:39 PM, Rover said:
    My HC3 CPU load is not a problem (20%). The only problems now are the response times of (HC2-)devices.
    So why do you do it yourself on HC2?
    What should be the advantage of splitting?
    I still have no idea what the advantage is of splitting AOQ code between two instances of AOQ.
    Two reasons:
    1. More convenient to maintain
    2. When you have many lines the delay is bigger, by splitting AOQ it should react faster
    9 hours ago, cag014 said:
    Two reasons:
    These are clear advantages, cag ?
    I am going to split my 137 lines till now in a AOQ1 for lighting and controllers and a AOQ2 for security/alarming features.
    Edited by Rover
    Hi @cag014,
    According to my experiences, I changed back to AOQv5.7, because the CPU load is the most ideal for this version. From 5.7+ the CPU load is rising.
    I don't know if somebody else also experiences it.
    1 hour ago, SmartLifeSystems said:
    Hi @cag014,
    Try that
    AOQ1 is now 62 lines and AOQ2 79 lines. But CPU load is going crazy:
    2 hours ago, cag014 said:
    Try that
    Nice job. The CPU working normaly.
    Try that
    Initiation of AOQ1 v6.5:
    Something wrong. The AOQ all the time restarted.
    Restarts ?..
    Anyone else has same issue?
