2 hours ago, Rover said:
{"PortSwitch","sendEmail,2","1 1x"}, {"`DimmerLeeslamp`","turnOn;else;turnOff","if {`DimmerLeeslamp`:value=0}"} }}},
"works", but:
  • time between push button and reaction dimmer with SlaveRemote_centralScene-v2.fqa first edition: 9, 19, 8, 41 seconds.
  • very strange that toggling dimmer is not assured:
Why can the response time so bizar (while it is so continuously bizar, that there cannot be a relation with table updates)?
    51 minutes ago, Rover said:
    Where can I find "CPU & Scan elapsed time " popup menu?
    How does user function looks like?
    No, my network has no issues. I am the only moderate user of the LAN, no Netflix, etc.
    You can see that in hcWebEye by hovering over Z-wave traffic  statistics
    [26.10.2020] [21:20:01] [DEBUG] [AOQ66]: onAction: {"args":[],"deviceId":66,"actionName":"turnOff"}
    After a webEye Toggle, together with the famous email from Fibaro...
    Edited by Rover
    1 hour ago, Rover said:
    Could you please to reduce number of jM lines, just to verify that's the problem
    jM lines from more than 100 to 53 lines:
    Toggle webEye: [27.10.2020] [00:24:16] [DEBUG] [AOQ66]: onAction: {"actionName":"turnOff","deviceId":66,"args":[]}
    but no email from Fibaro.
    deviceID:66 is AOQ
    Edited by Rover
    deviceID:66 is AOQ
    So hcWebEye updated normally
    [DEBUG] [AOQ66]: onAction: {"actionName":"turnOff","deviceId":66,"args":[]} means webEye update?
    Yes... but do you see that on hcWebEye the data has been updated?
    That is hard to say, the last modified date left above is getting updated.
    Everything set back to 122 lines: webEye Toggle: again email from Fibaro. Further nothing special to be seen in webEye (except the two "Uit" GV's that should be &Alarmststatus). And the yellow detail rectangles work!
    Edited by Rover
    OK, found it... it's just wrong table arrangement (shifted by using same global name "Alarmstatus"  in HC3 and Hc2). FIXED.
    Attached version includes also verification for "alarm" property on slave controller devices.
    Edited by cag014
    I'm curious about that, is it means HC3 always reports to Fibaro?
    What will happen if no internet to outside?
    Just for testing, could you please turn off remote access?
    I have catched the mysterious GV "Uit".
    At the moment there are 5 GV's  "Uit", that should be GV &Alarmstatus:
    If a delete the line with &Alarmstatus'hc2 then the Uit GV's has been changed to GV &Alarmstatus, like it should!
    Also with remote access turned off, the Fibaro email comes when Toggle webEye.
    Yes, you're correct, did you try v6.1 - it should be fixed
    It could be a good idea to split the AOQ to two.
    One will control all alarm actions and other all the rest.
    That's what I do on HC2 - two AOS. To synchronize between them,  I use global variables.
    Edited by cag014
    To all,
    I'm trying to speed up command execution and to keep CPU low as much as possible.
    Please try attached version and report if it's faster and CPU load still low.
    Edited by cag014
    Before I am going to split, I should like to comprehence what is going on here.
    What is the HC3 problem with AOQ with a CPU load of 20%?
    Why is Fibaro send email to AOQ has been turned off? What means turned off here, while AOQ is still working?
    Could it be the fact that almost all devices are still HC2 devices? If yes, then the problem is temporary until migration of devices to HC3.
    What is the effect of splitting AOQ to HC3?
    Regarding the email from Fibaro, I think the best option is to submit ticket to Fibaro support.
    To verify the effect on CPU while two AOQ run, you can just run another instance of your AOQ and to see the effect.
    My HC3 CPU load is not a problem (20%). The only problems now are the response times of (HC2-)devices.
    So why do you do it yourself on HC2?
    What should be the advantage of splitting?
